EnemyPain Posted August 30, 2013 Posted August 30, 2013 Добрый день. Столкнулся с неприятной ситуацией, есть сервер с FreeBSD: uname -a FreeBSD gw 8.3-RELEASE FreeBSD 8.3-RELEASE #1: Fri Jun 7 13:42:48 EEST 2013 root@gw:/usr/obj/usr/src/sys/NAS amd64 На этом сервере поднят mpd5: mpd5 -v Version 5.6 (root@gw 20:38 5-Jun-2013) Сам конфиг mpd: startup: # configure mpd users set user admin password admin set console self 127.0.0.1 5005 set console open set web self 0.0.0.0 82 set web open set netflow peer xx.xx.xx.xx 9996 create link template tPPTP pptp load pptp_server load radius pptp_server: create bundle template B set iface enable proxy-arp set iface enable tcpmssfix set iface enable netflow-in set iface enable netflow-out set ipcp no vjcomp set ipcp dns zzz.zzz.zzz.zzz set bundle enable encryption set ccp yes mppc set mppc yes e40 set mppc yes e56 set mppc yes e128 set mppc yes stateless create link template L pptp set link action bundle B set link enable multilink set link no pap chap set link enable chap set link keep-alive 60 600 set link mtu 1460 set link enable peer-as-calling set pptp self yy.yy.yy.yy set link enable incoming radius: set radius config /usr/local/etc/mpd5/radius.conf set radius server xx.xx.xx.xx password 1812 1813 set radius retries 3 set radius timeout 5 set auth acct-update 300 set auth max-logins 1 set auth enable acct-mandatory set auth enable radius-auth set auth enable radius-acct set radius enable message-authentic Проблема в том, что у некоторых абонентов сессия поднимается и через минуту падает, в дебаге видно следующее: Aug 30 02:50:40 gw mpd: pptp33: no reply to EchoRequest after 60 sec Aug 30 02:50:40 gw mpd: pptp33: ctrl state ESTABLISHED --> DYING Aug 30 02:50:40 gw mpd: pptp33: killing connection with 172.16.2.163 3832 Aug 30 02:50:40 gw mpd: pptp33-0: killing channel Aug 30 02:50:40 gw mpd: [L-17] PPTP call terminated Aug 30 02:50:40 gw mpd: [L-17] device: DOWN event Aug 30 02:50:40 gw mpd: [L-17] Link: DOWN event Aug 30 02:50:40 gw mpd: [L-17] LCP: Close event Aug 30 02:50:40 gw mpd: [L-17] LCP: state change Opened --> Closing Aug 30 02:50:40 gw mpd: [L-17] LCP: phase shift NETWORK --> TERMINATE Aug 30 02:50:40 gw mpd: [L-17] Link: Leave bundle "B-30" Пробовал играться с keep-alive, и даже ставить в 0(если судить по документации, должно отключить отправку LCP EchoRequest'ов) однако эффекта ноль, пробовал выключать mppc/mppe со стороны сервера, эффекта ноль. Те же абоненты к соседнему серверу подключаются и работают. Может кто сталкивался с подобным? Может просто глаз замылился и не вижу очевидной вещи(на что втайне надеюсь). Заранее спасибо Вставить ник Quote
boco Posted September 1, 2013 Posted September 1, 2013 это не lcp echo, а pptp echo. ходит по 1723/tcp Вставить ник Quote
