Коллеги, помогите решить данный вопрос.
Есть SRX 650, на нем есть два интерфейса, один аггрегированный ae1 с которого надо зеркалировать трафик второй просто гигабитный куда надо сливать трафик.
Оба интерфейса находятся в одной routing-instances и в одной security зоне.
Вот такая конфа:
set interfaces ge-2/0/18 gigether-options 802.3ad ae1
set interfaces ge-2/0/19 gigether-options 802.3ad ae1
set interfaces ae1 description "# AGG #"
set interfaces ae1 aggregated-ether-options link-speed 1g
set interfaces ae1 aggregated-ether-options lacp active
set interfaces ae1 aggregated-ether-options lacp periodic slow
set interfaces ae1 unit 0 family inet filter input port-mirror
set interfaces ae1 unit 0 family inet filter output port-mirror
set interfaces ae1 unit 0 family inet address xx.xx.xx.x/27
set interfaces ge-0/0/0 unit 0 family inet address 10.20.20.1/30
set firewall family inet filter port-mirror term ALL from source-address 0.0.0.0/0
set firewall family inet filter port-mirror term ALL then port-mirror
set firewall family inet filter port-mirror term ALL then count pkt_count
set firewall family inet filter port-mirror term ALL then accept
set routing-instances SUPER-SERVERS instance-type virtual-route
set routing-instances SUPER-SERVERS forwarding-options port-mirroring input rate 1
set routing-instances SUPER-SERVERS forwarding-options port-mirroring input run-length 12
set routing-instances SUPER-SERVERS forwarding-options port-mirroring family inet output interface ge-0/0/0.0 next-hop 10.20.20.2
set routing-instances SUPER-SERVERS interface ge-0/0/0.0
set routing-instances SUPER-SERVERS interface ae1.0
set security zones security-zone SS-untrust host-inbound-traffic system-services all
set security zones security-zone SS-untrust host-inbound-traffic protocols all
set security zones security-zone SS-untrust interfaces ae1.0
set security zones security-zone SS-untrust interfaces ge-0/0/0.0
set security policies from-zone SS-untrust to-zone SS-untrust policy SS-untrust-to-SS-untrust match source-address any
set security policies from-zone SS-untrust to-zone SS-untrust policy SS-untrust-to-SS-untrust match destination-address any
set security policies from-zone SS-untrust to-zone SS-untrust policy SS-untrust-to-SS-untrust match application any
set security policies from-zone SS-untrust to-zone SS-untrust policy SS-untrust-to-SS-untrust then permit
Собственно на ge-0/0/0.0 трафика по нулям:
run show interfaces ge-0/0/0
Physical interface: ge-0/0/0, Enabled, Physical link is Up
 Interface index: 137, SNMP ifIndex: 507
 Link-level type: Ethernet, MTU: 1514, Link-mode: Full-duplex, Speed: 1000mbps, BPDU Error: None, MAC-REWRITE Error: None, Loopback: Disabled, Source filtering: Disabled, Flow control: Enabled, Auto-negotiation: Enabled,
 Remote fault: Online
 Device flags   : Present Running
 Interface flags: SNMP-Traps Internal: 0x0
 Link flags     : None
 CoS queues     : 8 supported, 8 maximum usable queues
 Current address: b0:c6:9a:86:66:00, Hardware address: b0:c6:9a:86:66:00
 Last flapped   : 2013-08-29 17:12:25 MSK (11:54:11 ago)
 Input rate     : 0 bps (0 pps)
 Output rate    : 0 bps (0 pps)
 Active alarms  : None
 Active defects : None
 Interface transmit statistics: Disabled
Хотя судя по всему на фильтр пакетики попадают:
# run show firewall counter filter port-mirror pkt_count
Filter: port-mirror
Counters:
Name Bytes Packets
pkt_count 34913243601 57433331
Даже без идей куда копать. Ни одного документа который бы описывал то, что я пытаюсь сделать (аггрегация+routing-instances) я не нашел.
Заранее спасибо.
Edited by myst
А использовать forwarding-options port-mirroring family inet output interface
не получается?
Так вот же оно:
Только в инстансе, поскольку интерфейсы находятся там...
Как только я выношу из инстанса интерфейсы и делаю:
set forwarding-options port-mirroring input rate 1
set forwarding-options port-mirroring input run-length 12
set forwarding-options port-mirroring family inet output interface ge-0/0/0.0 next-hop 10.20.20.2
Все начинает пахать. У меня закрадываются сомнения что джунипер вообще умеет мироринг в врф...
Ок, коллеги, в принципе судя по всему именно не умеет.
Вопрос намба два.
Нужно с него слить netflow в какой-либо опенсорсный коллектор. Я так понимаю он должен уметь IPFIX, но доки не нашел, хотелось бы убедиться.
Ну или J-Flow, если есть опенсорс софт для него...
  • 1 year later...
Добрый день Всем. Я тут в первый раз , быстро просмотрел темы и вроде свою не нашел.
Итак, просьба помочь в следующей ситуации:
Есть два juniper mx960 c ver 10.4R5.5 Junos
между ними проброшен L2vpn family ccc для транспортировки ТВ сигнала.
Задача , на первом настроить port-mirroring для подключения декодера и получения ТВ-потока , проходящего по L2vpn.
Делал попытки прописать как написано в доках, мониторинг интерфейса показал отгруженность трафика и снифером посмотрел , трафик тот и UDP, multicast параметры все как надо , а подключив декодер или комп с анализатор транспортных потоков ничего не выдает . Завернул с дальнего Juniper обратным каналом , проверил , все нормально.
Просьба помочь разобраться.
Спасибо
Добавлено через 5 часов 42 минуты
ищу и не нахожу ...можно прямую ссылку тогда ...
Ого, контракта я я так понимаю нет? Может это поможет? DO_Ambassadors_2014
Recipe 13
Port Mirroring.
Не ахти, какая "дока" но она мне помогла определиться, в какую сторону нужно было копать, когдя я на "шабашке" скрещивал мелкий srx с active directory.
