Добрый день
Есть топология r1 em0 <-> r2 em0 (em0 потому что эмуляция, а не настоящий juniper)
Не понимаю по какому принципу выбирается nexthop для generated route:
root@r2# run show route ::/0 exact extensive
inet6.0: 11 destinations, 12 routes (11 active, 0 holddown, 0 hidden)
::/0 (1 entry, 1 announced)
TSI:
KRT in-kernel ::/0 -> {2000::1}
       *Aggregate Preference: 130
               Next hop type: Router, Next hop index: 548
               Address: 0x9334178
               Next-hop reference count: 4
               Next hop: 2000::1 via em0.10, selected
               State: <Active Int Ext>
               Local AS:    18
               Age: 2:19:35
               Task: Aggregate
               Announcement bits (1): 0-KRT
               AS path: I
                               Flags: Generate	Depth: 0	Active
               Contributing Routes (3):
               	2001::/62 proto BGP
               	2a00:2::/63 proto BGP
               	2a00:2::1/128 proto BGP
Почему выбирается 2000::1 via em0.10 ?
+ = Active Route, - = Last Active, * = Both
::/0               *[Aggregate/130] 02:20:22
                   > to 2000::1 via em0.10
2000::/127         *[Direct/0] 00:54:25
                   > via em0.10
2000::/128         *[Local/0] 00:54:25
                     Local via em0.10
2000:1::/127       *[Direct/0] 00:54:25
                   > via em0.20
2000:1::/128       *[Local/0] 00:54:25
                     Local via em0.20
2001::/62          *[bGP/170] 00:12:04, localpref 100
                     AS path: 196613 I
2a00:2::/63        *[bGP/170] 00:12:00, localpref 100
                     AS path: 196613 I
                   > to 2000:1::1 via em0.20
2a00:2::1/128      *[bGP/170] 00:12:00, localpref 100
                     AS path: 196613 I
fe80::/64          *[Direct/0] 00:54:25
                   > via em0.10
                   [Direct/0] 00:54:25
                   > via em0.20
fe80::2ab:b100:ac4:7200/128
                  *[Local/0] 00:54:25
                     Local via em0.10
fe80::2ab:b100:14c4:7200/128
                  *[Local/0] 00:54:25
                     Local via em0.20
root@r2# show
## Last changed: 2013-08-28 16:51:33 UTC
version 12.1R1.9;
system {
   host-name r2;
   root-authentication {
       encrypted-password "$1$62gr6sV1$U4Qu7LpE7lCCQJMYgJTMm1"; ## SECRET-DATA
   syslog {
       user * {
           any emergency;
       file messages {
           any notice;
           authorization info;
       file interactive-commands {
           interactive-commands any;
interfaces {
   em0 {
       vlan-tagging;
       unit 10 {
           vlan-id 10;
           family inet6 {
               address 2000::0/127;
       unit 20 {
           vlan-id 20;
           family inet6 {
               address 2000:1::0/127;
   em1 {
       disable;
routing-options {
   rib inet6.0 {
       generate {
           route ::/0;
   router-id 1.1.1.2;
   autonomous-system 18;
protocols {
   bgp {
       group ext {
           type external;
           neighbor 2000::1 {
               peer-as 3.5;
           neighbor 2000:1::1 {
               peer-as 3.5;
[edit]
root@r1# show
## Last changed: 2013-08-28 17:31:01 UTC
version 12.1R1.9;
system {
   host-name r1;
       encrypted-password "$1$lWW6LJkL$chJ5dkjYDoD1OZ6SpvQP0/"; ## SECRET-DATA
   syslog {
       user * {
           any emergency;
       file messages {
           any notice;
           authorization info;
interfaces {
   em0 {
       vlan-tagging;
       unit 10 {
           vlan-id 10;
           family inet6 {
               address 2000::1/127;
       unit 20 {
           vlan-id 20;
           family inet6 {
               address 2000:1::1/127;
   em1 {
       disable;
   em4 {
       disable;
   lo0 {
       unit 0 {
           family inet6 {
               address 2001::1/62;
               address 2a00:2::1/63 {
                   preferred;
routing-options {
   rib inet6.0 {
       static {
           inactive: route 2001::0/64 reject;
   router-id 1.1.1.1;
   autonomous-system 3.5;
protocols {
   bgp {
       inactive: traceoptions {
           file bgp.log;
           flag all;
       group ext {
           type external;
           neighbor 2000::0 {
               export bgp-ext-1;
               peer-as 18;
           neighbor 2000:1::0 {
               export bgp-ext-2;
               peer-as 18;
policy-options {
   policy-statement bgp-ext-1 {
       term 1 {
           from {
               route-filter 2001::0/62 exact accept;
   policy-statement bgp-ext-2 {
       term 1 {
           from {
               route-filter 2a00:2::/63 orlonger accept;
[edit]
Если с r1 вместо 2001::/62 анонсировать 2001::/64, то всё равно nexthop-ом для v6-дефолта выбирается 2000::1 via em0.10
Вообще чтобы не иметь не очевидных next-hop'Ов лучше делать aggregate =)
Ну а generate от aggregate отличается тем, что в качестве next-hop'а подставляется тот next-hop, который указан у маршрута, на основе которого generate и сгенерирован.
Edited by triam
мне нужно понять как оно работает...
В данном случае у ::/0 есть 3 contributing routes:
                        2001::/62 proto BGP
Почему-то берётся nexthop маршрута 2001::/62. Это просто рандом или есть какой-то критерий?
http://www.juniper.net/us/en/training/certification/JNCIA_studyguide.pdf
page 123
Primary Contributing Route
Each generated route selects one of the contributing routes to be the primary contributing
route. This route is the contributor with the numerically smallest prefix.
This topic is now closed to further replies.
