Прошу прощенья но почему-то подходящего раздела не нашёл, так что пишу здесь.
Начали приходить письма от copyright-compliance.com с просьбой закрыть раздачи у клиентов по торренту на якобы их контент
текст письма
Dear Sir or Madam:
Irdeto USA, Inc. (hereinafter referred to as "Irdeto") swears under penalty of perjury that Paramount Pictures Corporation ("Paramount") has authorized Irdeto to act as its non-exclusive agent for copyright infringement notification.  Irdeto's search of the protocol listed below has detected infringements of Paramount's copyright interests on your IP addresses as detailed in the below report.
Irdeto has reasonable good faith belief that use of the material in the manner complained of in the below report is not authorized by Paramount, its agents, or the law.  The information provided herein is accurate to the best of our knowledge.  Therefore, this letter is an official notification to effect removal of the detected infringement listed in the below report.  The Berne Convention for the Protection of Literary and Artistic Works, the Universal Copyright Convention, as well as bilateral treaties with other countries allow for protection of client's copyrighted work even beyond U.S. borders.  The below documentation specifies the exact location of the infringement.
We hereby request that you immediately remove or block access to the infringing material, as specified in the copyright laws, and insure the user refrains from using or sharing with others unauthorized Paramount's materials in the future.
Further, we believe that the entire Internet community benefits when these matters are resolved cooperatively.  We urge you to take immediate action to stop this infringing activity and inform us of the results of your actions.  We appreciate your efforts toward this common goal.
Please send us a prompt response indicating the actions you have taken to resolve this matter, making sure to reference the Notice ID number above in your response.
If you do not wish to reply by email, please use our Web Interface by clicking on the following link: http://webreply.copyright-compliance.com/WebReply?webreplyhash=ХХХХХХХХХХХХХХХХ
Nothing in this letter shall serve as a waiver of any rights or remedies of Paramount with respect to the alleged infringement, all of which are expressly reserved.  Should you need to contact me, I may be reached at the below address.
Regards,
Andrew Beck
Irdeto USA, Inc.
3255-3 Scott Blvd. Suite 101 Santa Clara, CA 95054
Phone: 408-492-8500  fax: 408-727-6743
paramount@copyright-compliance.com
*pgp public key is available on the key server at http://pgp.mit.edu
Note: The information transmitted in this Notice is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material.  Any review, reproduction, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited.  If you received this in error, please contact the sender and delete the material from all computers.
This infringement notice contains an XML tag that can be used to automate the processing of this data.  If you would like more information on how to use this tag please contact Irdeto.
Далее идёт IP, время, какой фильм, протоколы, размер файлов итд
и собственно вопрос. Как реагировать на такие письма?
Эта тема тут поднимается в 100500 раз. мы отправляли подобное абоненту (если из текста жалобы было легко понятно на кого жалуются, дольше 10 секунд не читалось) и забывали. По причинам, отмеченным выше, юридической силы все это не имеет. Ну так, пускай абонент думает сам, что с этим делать и делать ли :/
Обратно писать вообще бессмысленно, там роботы пишут.
Конструктивный ответ, спасибо
Когда такие организации еще появлялись, письма сыпались с весьма подробной статистикой там были наши ип и ип назначения), так вот - после отправления их адресов в фильтр (оставили хождение только icmp, 25 и 80 порт) письма счастья сыпаться перестали. Чего и всем советую.
P.S. Судя по гуглению сейчас уже видимо стали умнее, и и не пишут свой IP, только тот, на который идет жалоба. Но думаю по какому-нибудь ripe/arin вычислить их блоки адресов очень просто.
Edited by [anp/hsw]
