Пытаюсь поднять nondhcp clips l3
Конфигурация следующая
Current configuration:
! Configuration last changed by user 'root' at Thu Aug 15 22:29:21 2013
service-policy name nodhcp
allow clips ip range 10.10.0.0 10.10.255.254
allow clips ip range 10.12.0.0 10.12.255.254
service multiple-contexts
service inter-context routing
context main
no ip domain-lookup
nat fragments
interface Core
ip address 192.168.0.1/24
interface Subscriber multibind
ip address 10.12.0.1/16
ip mtu 1500
ip pool 10.12.0.0/16
interface uplink
ip address x.x.39.34/29
logging console
policy access-list nat
seq 100 permit ip 10.10.0.0 0.0.255.255 class nat-1
seq 110 permit ip 10.12.0.0 0.0.255.255 class nat-2
aaa authentication administrator local
aaa authentication administrator maximum sessions 1
aaa authentication subscriber radius
radius server x.x.171.44 encrypted-key xxxxxxxxxxxxx
radius attribute calling-station-id format description
radius attribute calling-station-id separator -
subscriber default
timeout absolute 1440
timeout idle 10
nat policy-name NAT
ip route 0.0.0.0/0 x.x.39.33
ip route 10.12.0.0/16 192.168.0.2
! ** End Context **
logging tdm console
logging active
logging standby short
!load balancing hash key config
service load-balance ip layer-3
link-group uplink dot1q
maximum-links 3
minimum-links 3
dot1q pvc 934
bind interface uplink main
port ethernet 1/1
! XCRP management port on slot 1
no shutdown
bind interface management local
card carrier 2
mic 1 ge-2-port
mic 2 ge-2-port
port ethernet 2/1
flow-control tx&rx
no shutdown
encapsulation dot1q
dot1q pvc 2300
bind interface Core main
service clips auto-detect context main service-policy nodhcp
port ethernet 2/2
flow-control tx&rx
no shutdown
encapsulation dot1q
port ethernet 2/3
flow-control tx&rx
no shutdown
encapsulation dot1q
port ethernet 2/4
flow-control tx&rx
no shutdown
encapsulation dot1q
link-group uplink
port ethernet 2/15
flow-control tx&rx
no shutdown
encapsulation dot1q
link-group uplink
port ethernet 2/16
flow-control tx&rx
no shutdown
encapsulation dot1q
link-group uplink
Сабскрайбер появляется
[main]SE100-1#sh subs act
10.12.1.4
Session state Up
Circuit 2/1 vlan-id 2300 clips 133740
Internal Circuit 2/1:511:63:31/13/2/2668
Interface bound Subscriber
Current port-limit unlimited
Session time left 84870
Protocol Stack IPV4
ip address 10.12.1.4 (applied)
timeout absolute 86400 (applied from sub_default)
timeout idle 600 (applied from sub_default)
nat policy-name NAT (applied from sub_default)
В маршрутах вижу следующее
Type Network Next Hop Dist Metric UpTime Interface
> S 0.0.0.0/0 x.x.39.33 1 0 02:10:05 uplink
> S 10.12.0.0/16 192.168.0.2 1 0 01:03:17 Core
> SUB A 10.12.1.4/32 10.12.1.4 15 0 00:27:00 Subscriber
> C 192.168.0.0/24 0 0 01:07:11 Core
> C x.x.39.32/29 0 0 02:10:06 uplink
sh ip rout 10.12.1.4 det
Longest match Routing entry for 10.12.1.4/32 is 10.12.1.4/32 , version 137
Route Uptime 00:29:23
Paths: total 2, best path count 2
Route has been downloaded to following slots
iPPA: 02
Path information :
Active path :
Known via subscriber address , distance 15, metric 0,
Tag 0, Next-hop 10.12.1.4, NH-ID 0x3450000C, Adj ID: slot number=1, adj id=0x17, Interface Subscriber
Active path :
Known via adjacency, type-hidden route, distance 254, metric 0,
Пинга нет, где тут может быть ошибка?
