Всем привет.
Вопрос в названии темы.
TestNet2811#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 15.1(4)M5, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 04-Sep-12 15:56 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
TestNet2811 uptime is 1 hour, 2 minutes
System returned to ROM by power-on
System image file is "flash:c2800nm-adventerprisek9-mz.151-4.M5.bin"
Last reload type: Normal Reload
Cisco 2811 (revision 1.0) with 245760K/16384K bytes of memory.
Processor board ID FCZ113271W3
18 FastEthernet interfaces
2 Low-speed serial(sync/async) interfaces
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
2 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
500472K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2811             FCZ113271W3
Configuration register is 0x2102
TestNet2811#sh inv
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V05 , SN: FCZ113271W3
NAME: "WAN Interface Card - Serial 2A/S on Slot 0 SubSlot 1", DESCR: "WAN Interface Card - Serial 2A/S"
PID: WIC-2A/S=         , VID: 1.0, SN: 18154642
NAME: "2nd generation two port FXS voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation two port FXS voice interface daughtercard"
PID: VIC2-2FXS         , VID: V01 , SN: FOC11273SW5
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 3", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1  , VID: V01 , SN: FOC11505XTA
NAME: "PVDMII DSP SIMM with one DSP on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with one DSP"
PID: PVDM2-16          , VID: V01 , SN: FOC11296V37
NAME: "16 Port 10BaseT/100BaseTX EtherSwitch on Slot 1", DESCR: "16 Port 10BaseT/100BaseTX EtherSwitch"
PID: NM-16ESW=         , VID: 1.0, SN: FOC09344XJ8
NAME: "Power daughter card for 16 port EtherSwitch NM on Slot 1 SubSlot 0", DESCR: "Power daughter card for 16 port EtherSwitch NM"
PID: PPWR-DCARD-16ESW  , VID: V01 , SN: FOC09490F34
TestNet2811#sh diag
Slot 0:
       C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
       Port adapter is analyzed
       Port adapter insertion time 01:03:56 ago
       Onboard VPN             : v2.3.3
       EEPROM contents at hardware discovery:
       PCB Serial Number        : FOC11295FLJ
       Hardware Revision        : 1.0
       Top Assy. Part Number    : 800-26920-04
       Board Revision           : A0
       Deviation Number         : 0
       Fab Version              : 04
       RMA Test History         : 00
       RMA Number               : 0-0-0-0
       RMA History              : 00
       Processor type           : 87
       Hardware date code       : 20070722
       Chassis Serial Number    : FCZ113271W3
       Chassis MAC Address      : 0007.0e62.f238
       MAC Address block size   : 24
       CLEI Code                : COM7R00ARA
       Product (FRU) Number     : CISCO2811
       Part Number              : 73-10258-05
       Version Identifier       : V05
       EEPROM format version 4
       EEPROM contents (hex):
         0x00: 04 FF C1 8B 46 4F 43 31 31 32 39 35 46 4C 4A 40
         0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 04 42 41 30
         0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04 00
         0x30: 09 87 83 01 32 41 42 C2 8B 46 43 5A 31 31 33 32
         0x40: 37 31 57 33 C3 06 00 07 0E 62 F2 38 43 00 18 C6
         0x50: 8A 43 4F 4D 37 52 30 30 41 52 41 CB 8F 43 49 53
         0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
         0x70: 05 89 56 30 35 20 D9 02 40 C1 FF FF FF FF FF FF
       PVDM Slot 0:
       16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
       Hardware Revision        : 4.0
       Part Number              : 73-8538-05
       Board Revision           : B0
       Fab Version              : 04
       PCB Serial Number        : FOC11296V37
       RMA History              : 00
       Processor type           : 00
       Product (FRU) Number     : PVDM2-16
       Version Identifier       : V01
         0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 42 30
         0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 31 32 39
         0x20: 36 56 33 37 03 00 81 00 00 00 00 04 00 09 00 CB
         0x30: 88 50 56 44 4D 32 2D 31 36 89 56 30 31 20 D9 02
         0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
         0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
         0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
         0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
       WIC Slot 1:
       Serial 2A/S (12in1)
       Hardware revision 1.0           Board revision C0
       Serial number     18154642      Part number    800-03182-01
       FRU Part Number     WIC-2A/S=
       Test history      0x0           RMA number     00-00-00
       Connector type    PCI
       EEPROM format version 1
         0x20: 01 13 01 00 01 15 04 92 50 0C 6E 01 00 00 00 00
         0x30: 60 00 00 00 00 02 07 00 FF FF FF FF FF FF FF FF
       WIC Slot 2:
       2nd generation - FXS Voice daughter card (2 port)
       Hardware Revision        : 3.1
       Top Assy. Part Number    : 800-21341-02
       Board Revision           : B0
       Deviation Number         : 0-0
       Fab Version              : 01
       PCB Serial Number        : FOC11273SW5
       RMA History              : 00
       Product (FRU) Number     : VIC2-2FXS
       CLEI Code                : CNUIAPPAAA
         0x00: 04 FF 40 00 47 41 03 01 C0 46 03 20 00 53 5D 02
         0x10: 42 42 30 80 00 00 00 00 02 01 C1 8B 46 4F 43 31
         0x20: 31 32 37 33 53 57 35 03 00 81 00 00 00 00 04 00
         0x30: CB 89 56 49 43 32 2D 32 46 58 53 89 56 30 31 20
         0x40: C6 8A 43 4E 55 49 41 50 50 41 41 41 FF FF FF FF
       WIC Slot 3:
       Hardware Revision        : 0.0
       Top Assy. Part Number    : 800-22628-05
       Board Revision           : B0
       Fab Version              : 04
       PCB Serial Number        : FOC11505XTA
       RMA History              : 00
       Product (FRU) Number     : VWIC2-1MFT-T1/E1
         0x00: 04 FF 40 03 FD 41 00 00 C0 46 03 20 00 58 64 05
         0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
         0x20: 31 35 30 35 58 54 41 03 00 81 00 00 00 00 04 00
         0x30: CB 90 56 57 49 43 32 2D 31 4D 46 54 2D 54 31 2F
         0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
Slot 1:
       FastEthernet Port adapter, 16 ports
       Top Assy. Part Number    : 800-15156-01
       Board Revision           : E0
       Fab Version              : 03
       PCB Serial Number        : FOC09344XJ8
       RMA History              : 00
       Base MAC Address         : 0014.6a76.462c
       MAC Address block size   : 17
       Product (FRU) Number     : NM-16ESW=
         0x00: 04 FF 40 02 A9 41 01 00 C0 46 03 20 00 3B 34 01
         0x10: 42 45 30 80 00 00 00 00 02 03 C1 8B 46 4F 43 30
         0x20: 39 33 34 34 58 4A 38 03 00 81 00 00 00 00 04 00
         0x30: CF 06 00 14 6A 76 46 2C 43 00 11 FF FF FF FF FF
         0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
       16-Port Power Daughter Card
       PCB Serial Number        : FOC09490F34
       Part Number              : 73-6610-02
       Board Revision           : A1
       RMA History              : 00
       Top Assy. Part Number    : 65535-16777215-255
       CLEI Code                : CNSPN10AAA
       Product (FRU) Number     : PPWR-DCARD-16ESW
         0x00: 04 FF 40 02 B3 41 01 00 C1 8B 46 4F 43 30 39 34
         0x10: 39 30 46 33 34 82 49 19 D2 02 42 41 31 03 00 81
         0x20: 00 00 00 00 04 00 80 00 00 00 00 C0 46 FF FF FF
         0x30: FF FF FF C6 8A 43 4E 53 50 4E 31 30 41 41 41 CB
         0x40: 90 50 50 57 52 2D 44 43 41 52 44 2D 31 36 45 53
         0x50: 57 89 56 30 31 20 FF FF FF FF FF FF FF FF FF FF
вопрос поддержки Overview of Cisco Network Modules for Cisco Access Routers
Ммда. Отвечу сам себе, а мож кому станет легче.
1. Integrated internal inline power supply (such as PWR-28XX-AC-IP) or an
external power supply (such as PWR-CHASSIS-360W) is recommended for the
NM-XXESW-PWR selection made.
2. Power Over Ethernet (POE) requires an AC plus IP system power supply
(such as PWR-28XX-AC-IP).
Edited by sunrise333
