Здравствуйте, помогите пожалуйста: пытаюсь настроить ipsec между Racoon (Debian Squeeze) и Huawei USG2110-A-GW-W
Туннель устанавливается, но траффик внутри не ходит, помогите разобраться, в чём дело?
path pre_shared_key "/etc/racoon/psk.txt";
path certificate "/etc/racoon/certs";
log info;
listen {
   isakmp racoon_ip [500];
   isakmp racoon_ip [4500];
remote huawei_ip
   ph1id 1;
   exchange_mode main;
   my_identifier address racoon_ip;
   peers_identifier address huawei_ip;
   ike_frag on;
   generate_policy = off;
   initial_contact = on;
   nat_traversal = on;
   support_proxy on;
   proposal_check claim;
   proposal
       authentication_method pre_shared_key;
       encryption_algorithm des;
       hash_algorithm sha1;
       dh_group 1;
       lifetime time 28800 secs;
sainfo subnet 192.168.70.0/24 any subnet 192.168.17.0/24 any
   remoteid 1;
   encryption_algorithm aes 256, aes 192, aes 128, blowfish 256, blowfish 248, blowfish 240, blowfish 232, blowfish 224, blowfish 216, blowfish 208, blowfish 200, blowfish 192, blowfish 184, blowfish 176, blowfish 168, blowfish 160, blowfish 152, blowfish 144, blowfish 136, blowfish 128, 3des, cast128, des;
   authentication_algorithm hmac_sha1,hmac_md5;
   lifetime time 3600 secs;
   compression_algorithm deflate;
/etc/ipsec.conf
spdadd 192.168.70.0/24 192.168.17.0/24 any -P out ipsec esp/tunnel/racoon_ip-huawei_ip/unique;
spdadd 192.168.17.0/24 192.168.70.0/24 any -P in ipsec esp/tunnel/huawei_ip-racoon_ip/unique;
Настройки Huawei:
Phase 1:
Encryption Algorithm: DES-CBC
DH Group: DH-Group 1
Authentication Algorithm: SHA1
SA Timeout: 86400
DPD Mode: none
Nat traversal: enabled
Phase 2:
Encapsulation Mode: Tunnel Mode
Security Protocol: ESP
ESP Encryption Algorithm: DES
ESP Authentication Algorithm: MD5
PFS: none
SA Timeout based on time 3600 Second
SA Timeout based on traffic 1843200 KB
iptables:
root@gw:/etc/racoon# iptables -L INPUT |grep 192.168.17
ACCEPT     all  --  192.168.17.0/24      anywhere
root@gw:/etc/racoon# iptables -L FORWARD |grep 192.168.17
ACCEPT     all  --  anywhere             192.168.17.0/24
