Конфиги:
/etc/dahdi/modules
opvxd115
/etc/dahdi/system.conf
span=1,1,0,ccs,hdb3
bchan=1-15,17-31
dchan=16
loadzone = us
defaultzone = us
/etc/yate/zapcard.conf
[general]
format=mulaw
[span1]
type=E1
offset=0
sigchan=16
voicechans=1-15.17-31
/etc/yate/ysigchan.conf
[trunk1]
type=isdn-pri-cpe
switchtype=euro-isdn-e1
sig=span1
voice=span1
format=mulaw
/etc/yate/regexroute.conf
.....*=trunk1/1-15; format=mulaw
/etc/yate/regfile.conf
[100]
password=test
Yate клиентом упешно подключаюсь к серверу по sip, пытаюсь звонить ((((
В логах пишет об ошибках:
<INFO> Routing call to '79192345674' in context 'default' via 'trunk1/1-15' in 94 usec
<sip/3:ALL> NAT address is '(null)'
<sip/3:MILD> Call rejected error='noconn' reason='Could not connect to target'
<trunk1/Q931:NOTE> Error parse IE ('Call state'): unsupported coding standard
STATUS
[From initiator=false CallRef=0] 08 02 80 00 7d
Cause (codeset=0 type=8) 08 03 82 e5 46
Cause.coding=CCITT
Cause.location=LN
Cause=wrong-state-message
Cause.diagnostic=46
Call state (codeset=0 type=20) 14 01 3e
coding=32
error=unsupported coding standard
error-data=3e
dahdi_scan
[1]
active=yes
alarms=OK
description=D130 (E1|T1) Card 0 Span 1
name=D130/0/1
manufacturer=Openvox
devicetype=OpenVox D130P/E
location=PCI Bus 03 Slot 01
basechan=1
totchans=31
irq=0
type=digital-E1
syncsrc=0
lbo=0 db (CSU)/0-133 feet (DSX-1)
coding_opts=AMI,HDB3
framing_opts=CCS,CRC4
coding=HDB3
framing=CCS
status zaptel
name=zaptel,type=misc,format=Type|ZaptelType|Span|SpanPos|Alarms|UsedBy;active=1,count=31;1=E1||-1|-1|not-open|trunk1/B/1;2=E1||-1|-1|not-open|trunk1/B/2;3=E1||-1|-1|not-open|trunk1/B/3;4=E1||-1|-1|not-open|trunk1/B/4;5=E1||-1|-1|not-open|trunk1/B/5;6=E1||-1|-1|not-open|trunk1/B/6;7=E1||-1|-1|not-open|trunk1/B/7;8=E1||-1|-1|not-open|trunk1/B/8;9=E1||-1|-1|not-open|trunk1/B/9;10=E1||-1|-1|not-open|trunk1/B/10;11=E1||-1|-1|not-open|trunk1/B/11;12=E1||-1|-1|not-open|trunk1/B/12;13=E1||-1|-1|not-open|trunk1/B/13;14=E1||-1|-1|not-open|trunk1/B/14;15=E1||-1|-1|not-open|trunk1/B/15;17=E1||-1|-1|not-open|trunk1/B/17;18=E1||-1|-1|not-open|trunk1/B/18;19=E1||-1|-1|not-open|trunk1/B/19;20=E1||-1|-1|not-open|trunk1/B/20;21=E1||-1|-1|not-open|trunk1/B/21;22=E1||-1|-1|not-open|trunk1/B/22;23=E1||-1|-1|not-open|trunk1/B/23;24=E1||-1|-1|not-open|trunk1/B/24;25=E1||-1|-1|not-open|trunk1/B/25;26=E1||-1|-1|not-open|trunk1/B/26;27=E1||-1|-1|not-open|trunk1/B/27;28=E1||-1|-1|not-open|trunk1/B/28;29=E1||-1|-1|not-open|trunk1/B/29;30=E1||-1|-1|not-open|trunk1/B/30;31=E1||-1|-1|not-open|trunk1/B/31;16=DChan|HDLCFCS|1|16||span1/Dspan1/D
Я в телефонии новичок, помогите, пожалуйста, разобраться.
