leveler Posted June 25, 2013 Posted June 25, 2013 День добрый! Есть модуль SPA-1X10GE-WL-V2 в ASR1002. sh ver Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISE-M), Version 15.2(4)S2, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2012 by Cisco Systems, Inc. Compiled Tue 11-Dec-12 18:17 by mcpre IOS XE Version: 03.07.02.S Cisco IOS-XE software, Copyright (c) 2005-2012 by cisco Systems, Inc. All rights reserved. Certain components of Cisco IOS-XE software are licensed under the GNU General Public License ("GPL") Version 2.0. The software code licensed under GPL Version 2.0 is free software that comes with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such GPL code under the terms of GPL Version 2.0. For more details, see the documentation or "License Notice" file accompanying the IOS-XE software, or the applicable URL provided on the flyer accompanying the IOS-XE software. ROM: IOS-XE ROMMON ASR1002 uptime is 20 weeks, 4 days, 13 hours, 17 minutes Uptime for this control processor is 20 weeks, 4 days, 13 hours, 19 minutes System returned to ROM by reload at 06:00:00 NOVST Fri Feb 1 2013 System restarted at 06:03:56 NOVST Fri Feb 1 2013 System image file is "bootflash:asr1000rp1-adventerprise.03.07.02.S.152-4.S2.bin" Last reload reason: Critical software exception, check bootflash:crashinfo_RP_00_00_20120208-171700-NOVST cisco ASR1002 (2RU) processor with 1694460K/6147K bytes of memory. Processor board ID XXXXXXXXXXX 9 Gigabit Ethernet interfaces 1 Ten Gigabit Ethernet interface 32768K bytes of non-volatile configuration memory. 4194304K bytes of physical memory. 7798783K bytes of eUSB flash at bootflash:. Configuration register is 0x2102 sh platform Chassis type: ASR1002 Slot Type State Insert time (ago) --------- ------------------- --------------------- ----------------- 0 ASR1002-SIP10 ok 20w4d 0/0 4XGE-BUILT-IN ok 20w4d 0/1 SPA-5X1GE-V2 ok 20w4d 0/2 SPA-1X10GE-WL-V2 ok 4w5d R0 ASR1002-RP1 ok, active 20w4d F0 ASR1000-ESP5 ok, active 20w4d P0 ASR1002-PWR-AC ok 20w4d P1 ASR1002-PWR-AC ok 20w4d Slot CPLD Version Firmware Version --------- ------------------- --------------------------------------- 0 07120202 12.2(33r)XNC R0 08011017 12.2(33r)XNC F0 07091401 12.2(33r)XNC Цыска подключена к Длинку. Всё в апе: ASR1002#sh int te0/2/0 TenGigabitEthernet0/2/0 is up, line protocol is up Hardware is SPA-1X10GE-WL-V2, address is c471.fe9b.1520 (bia c471.fe9b.1520) MTU 9216 bytes, BW 10000000 Kbit/sec, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set Keepalive not supported Full Duplex, 10000Mbps, link type is force-up, media type is 10GBase-LR output flow-control is on, input flow-control is on ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output 00:03:02, output hang never Last clearing of "show interface" counters never Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 21000 bits/sec, 32 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 2014491509 packets input, 2558729516632 bytes, 0 no buffer Received 16919382 broadcasts (0 IP multicasts) 0 runts, 0 giants, 0 throttles 1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 1919054791 multicast, 0 pause input 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 23 interface resets 0 unknown protocol drops 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 pause output 0 output buffer failures, 0 output buffers swapped out Плата в режиме LAN: ASR1002#sh controllers wanphy 0/2/0 TenGigabitEthernet0/2/0 Mode of Operation: LAN Mode Вот конфиг интерфейсов: ASR1002#sh ru int te0/2/0 Building configuration... Current configuration : 66 bytes ! interface TenGigabitEthernet0/2/0 mtu 9216 no ip address end ASR1002#sh ru int te0/2/0.910 Building configuration... Current configuration : 177 bytes ! interface TenGigabitEthernet0/2/0.910 description Test Interface for Vlan910 | 2013-06-25 | Taras Kotov encapsulation dot1Q 910 ip address 10.255.11.2 255.255.255.252 end Но пакетики даже до 10.255.11.1 не ходят. Если внимательно приглядеться на вывод команды show int te0/2/0, то можно увидеть, что исходящих пакетов нет вообще. Подскажите пожалуйста, куда копать? В чём может быть трабла? Вставить ник Quote
leveler Posted June 26, 2013 Author Posted June 26, 2013 ASR1002#sh int te0/2/0.910 TenGigabitEthernet0/2/0.910 is up, line protocol is up Hardware is SPA-1X10GE-WL-V2, address is c471.fe9b.1520 (bia c471.fe9b.1520) Description: Test Interface for Vlan910 | 2013-06-25 | Taras Kotov Internet address is 10.255.11.2/30 MTU 9216 bytes, BW 10000000 Kbit/sec, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation 802.1Q Virtual LAN, Vlan ID 910. ARP type: ARPA, ARP Timeout 04:00:00 Keepalive not supported Last clearing of "show interface" counters never Вставить ник Quote
leveler Posted June 26, 2013 Author Posted June 26, 2013 Да: ASR1002#ping 10.255.11.2 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 10.255.11.2, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms Так же 10.255.11.2 пингуется с других устройств в сети (ICMP-пакеты на ASR попадают через другой интерфейс). Вставить ник Quote
zstas Posted June 26, 2013 Posted June 26, 2013 Ну на всякий случай sh route 10.255.11.1 и конфиг длинка покажите Вставить ник Quote
leveler Posted June 26, 2013 Author Posted June 26, 2013 ASR1002#sh ip route 10.255.11.1 Routing entry for 10.255.11.0/30 Known via "connected", distance 0, metric 0 (connected, via interface) Routing Descriptor Blocks: * directly connected, via TenGigabitEthernet0/2/0.910 Route metric is 0, traffic share count is 1 Конфиг D-Link'а сейчас пока показать не могу. Но я не думаю, что там проблема, ибо исходящий пакетов вообще нет. Вставить ник Quote
leveler Posted July 12, 2013 Author Posted July 12, 2013 Up! Пробовал другие слоты. Пробовал без VLAN (IP-адрес на интерфейсе без каких-либо сабинтерфейсов). Пробовал перезагружать железку. Шины пинал, зеркала протирал, дверью хлопал... Хз, что делать дальше. ( Вставить ник Quote
Vadic Posted July 12, 2013 Posted July 12, 2013 (edited) Другой модуль не пробывали? Была такая засада. Edited July 12, 2013 by Vadic Вставить ник Quote
leveler Posted July 12, 2013 Author Posted July 12, 2013 Других в наличии нет. ( Но спасибо за наводку. Если получится, попробуем другой. Вставить ник Quote
Foxeevna Posted July 31, 2013 Posted July 31, 2013 у меня такой же валяется. асрка его видит но он не пашет. в итоге купили другой модуль и прекрасно работает. Вставить ник Quote
Alex780 Posted September 27, 2013 Posted September 27, 2013 Я так понимаю не WL купили? Вставить ник Quote
Foxeevna Posted April 9, 2014 Posted April 9, 2014 новая инфа: на последней прошивке в ASR-1002 модуль SPA-1X10GE-WL-V2 завелся и прекрасно работает. Вставить ник Quote
