alexpn Posted June 21, 2013 Posted June 21, 2013 **************************************************************************** * WARNING: TCAM/SSRAM are filled with test pattern. Module 1 MUST be reset * **************************************************************************** Jun 21 02:27:20.317: %DIAG-SP-6-TEST_OK: Module 1: TestFibTcamSSRAM{ID=24} has completed successfully Jun 21 02:27:20.317: %DIAG-SP-6-TEST_RUNNING: Module 1: Running TestAclQosTcam{ID=25} ... Jun 21 02:27:20.329: SP: ****************************************************************** Jun 21 02:27:20.329: SP: * WARNING: Jun 21 02:27:20.329: SP: * ACL/QOS TCAM Memory test on module 1 may take up to 10min. Jun 21 02:27:20.329: SP: * During this time, please DO NOT perform any packet switching. Jun 21 02:27:20.329: SP: ****************************************************************** Jun 21 02:33:32.831: SP: ****************************************************************** Jun 21 02:33:32.831: SP: * WARNING: Jun 21 02:33:32.831: SP: * Netflow TCAM Memory test on module 1 may take up to 5min. Jun 21 02:33:32.831: SP: * During this time, please DO NOT perform any packet switching. Jun 21 02:33:32.831: SP: ****************************************************************** При тестировании платы вот такие ошибки кто знает что это значит ? особенно вот это * WARNING: TCAM/SSRAM are filled with test pattern. Module 1 MUST be reset * Циска иногда падает в креши .... сделано следующее 1. отформатировал все что форматировалось 2. сменил прошивку на 15.3 Запустил тест diagnostic start module 1 test all и вот ошибки Конфиг железа C7604_BGP#show module Mod Ports Card Type Model Serial No. --- ----- -------------------------------------- ------------------ ----------- 1 5 Route Switch Processor 720 10GE (Activ RSP720-3CXL-10GE SAL15066Z3J 3 0 ESM20G 7600-ES20-10G3CXL JAB1047041D 4 0 ESM20G 7600-ES20-10G3CXL JAB103501AA Mod MAC addresses Hw Fw Sw Status --- ---------------------------------- ----- ------------- ------------ ------- 1 c89c.1dfb.8710 to c89c.1dfb.8717 1.1 12.2(33r)SRD 15.3(1)S Ok 3 0019.55c9.97d0 to 0019.55c9.984f 1.0 12.2(33r)SRB 15.3(1)S PwrDown 4 00e0.aabb.cc00 to 00e0.aabb.cc00 0.64 12.2(33r)SRB 15.3(1)S PwrDown Mod Sub-Module Model Serial Hw Status ---- --------------------------- ------------------ ----------- ------- ------- 1 Policy Feature Card 3 7600-PFC3CXL-10GE JAE1218GY7K 1.1 Ok 1 C7600 MSFC4 Daughterboard 7600-MSFC4 JAE1403AFXL 1.4 Ok 3 ESM20G Distributed Forwardi 7600-ES20-D3CXL JAB1047043X 1.0 PwrDown 4 ESM20G Distributed Forwardi 7600-ES20-D3CXL JAB103501RW 0.16 PwrDown C7604_BGP#show version Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 15.3(1)S1, RELEASE) Technical Support: http://www.cisco.com/techsupport Copyright © 1986-2013 by Cisco Systems, Inc. Compiled Thu 07-Feb-13 07:20 by prod_rel_team ROM: System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1) BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 15.3(1)S1) C7604_BGP uptime is 4 hours, 31 minutes Uptime for this control processor is 4 hours, 31 minutes System returned to ROM by reload (SP by reload) System restarted at 00:49:31 UTC Fri Jun 21 2013 System image file is "disk0:c7600rsp72043-adventerprisek9-mz.153-1.S1.bin" Last reload type: Normal Reload Last reload reason: Reload Command Вставить ник Quote
zstas Posted June 21, 2013 Posted June 21, 2013 При тестировании платы вот такие ошибки кто знает что это значит ? особенно вот это * WARNING: TCAM/SSRAM are filled with test pattern. Module 1 MUST be reset * Циска иногда падает в креши .... Это не ошибки. Цыска говорит что модуль нужно будет передёрнуть после теста (т.к. он tcam забивает случайными байтиками). Вы полный вывод лога диагностики приложите. Вставить ник Quote
alexpn Posted June 21, 2013 Author Posted June 21, 2013 C7604_BGP#show diagnostic result Current bootup diagnostic level: minimal Module 1: Route Switch Processor 720 10GE (Active) SerialNo : SAL15066Z3J Overall Diagnostic Result for Module 1 : PASS Diagnostic level at card bootup: minimal Test results: (. = Pass, F = Fail, U = Untested) 1) TestScratchRegister -------------> . 2) TestSPRPInbandPing --------------> . 3) TestTransceiverIntegrity: Port 1 2 3 4 5 ------------------- U U U . U 4) TestActiveToStandbyLoopback: Port 1 2 3 4 5 ------------------- U U U U U 5) TestLoopback: Port 1 2 3 4 5 ------------------- . . . . . 6) TestNewIndexLearn ---------------> . 7) TestDontConditionalLearn --------> . 8) TestBadBpduTrap -----------------> . 9) TestMatchCapture ----------------> . 10) TestProtocolMatchChannel --------> . 11) TestFibDevices ------------------> . 12) TestIPv4FibShortcut -------------> . 13) TestL3Capture2 ------------------> . 14) TestIPv6FibShortcut -------------> . 15) TestMPLSFibShortcut -------------> . 16) TestNATFibShortcut --------------> . 17) TestAclPermit -------------------> . 18) TestQoSTcam ---------------------> . 19) TestL3VlanMet -------------------> . 20) TestIngressSpan -----------------> . 21) TestEgressSpan ------------------> . 22) TestFabricSnakeForward ----------> . 23) TestFabricSnakeBackward ---------> . 24) TestFibTcamSSRAM ----------------> . 25) TestAclQosTcam ------------------> . 26) TestNetflowTcam -----------------> . 27) ScheduleSwitchover --------------> U 28) FirmwareDiagStatus --------------> . 29) TestFabricFlowControlStatus -----> U 30) TestErrorCounterMonitor ---------> . Вставить ник Quote
zstas Posted June 21, 2013 Posted June 21, 2013 Криминала не видно, а в крэши после чего падает? просто так? Вставить ник Quote
Tosha Posted June 21, 2013 Posted June 21, 2013 А это не ошибки. Система пишет, что идет тестирование, что оно успешно закончено, но после теста модуль необходимо перезагрузить чтобы очистить память от остатков тестовых паттернов. По идее модуль должен сам перезагрузится. Вставить ник Quote
alexpn Posted June 24, 2013 Author Posted June 24, 2013 Криминала не видно, а в крэши после чего падает? просто так? Да сама по себе .... я грешил на модули 10G не родные сейчас купили родные вот ставлю под нагрузку там глянем Вставить ник Quote
alexpn Posted July 8, 2013 Author Posted July 8, 2013 Криминала не видно, а в крэши после чего падает? просто так? Да сама по себе .... я грешил на модули 10G не родные сейчас купили родные вот ставлю под нагрузку там глянем Креши повторяются crashinfo.tar.gz Вставить ник Quote
Alex/AT Posted July 8, 2013 Posted July 8, 2013 Попробуйте откатиться на 12.2SRE, если возможно - всё равно я так понимаю оно у вас сейчас нерабочее. Вполне возможно, что причина именно в каких-то граблях 15 релиза. У нас с 15.1 был опыт с граблями на апгрейде - супервизоры просто отказались подниматься. Вставить ник Quote
alexpn Posted July 8, 2013 Author Posted July 8, 2013 Попробуйте откатиться на 12.2SRE, если возможно - всё равно я так понимаю оно у вас сейчас нерабочее. Вполне возможно, что причина именно в каких-то граблях 15 релиза. У нас с 15.1 был опыт с граблями на апгрейде - супервизоры просто отказались подниматься. Кто поделится c7600rsp72043-adventerprisek9-mz.122-33.sre8 ? Крешь происходит после теста TestSPRPInbandPing Пробывал количество попыток увеличить доходит до 321 и роутер виснет в усмерть Вставить ник Quote
ilili Posted July 9, 2013 Posted July 9, 2013 c7600rsp72043-adventerprisek9-mz.122-33.sre8 SRE3 есть, наливать? ) Вставить ник Quote
alexpn Posted July 9, 2013 Author Posted July 9, 2013 Залил show version Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRD5, RELE) Technical Support: http://www.cisco.com/techsupport Copyright © 1986-2010 by Cisco Systems, Inc. Compiled Sat 02-Oct-10 16:28 by prod_rel_team ROM: System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1) BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)S) c7600rsp72043-adventerprisek9-mz.122-33.sre8 SRE3 есть, наливать? ) Скажите где забрать буду благодарен очень Вставить ник Quote
ilili Posted July 9, 2013 Posted July 9, 2013 (edited) Скажите где забрать буду благодарен очень c7600rsp72043-adventerprisek9-mz.122-33.SRE3, линк отправил в ЛС Edited July 9, 2013 by ilili Вставить ник Quote
alexpn Posted July 11, 2013 Author Posted July 11, 2013 (edited) Спасибо всем за помощь Пробывал все IOS Креши продолжаются ..... думаем покупать тех поддержку вот прошивки 8cdb6a2a0a18e6641d66380bdbdab1e5 *c7600rsp72043-adventerprisek9-mz.122-33.SRD5.bin 065af3290a2e5f37a5488655d83ce2ab *c7600rsp72043-adventerprisek9-mz.151-3.S2.bin b5fdbff1059c3f1bbd5adcbdf1915474 *c7600rsp72043-adventerprisek9-mz.152-4.S1.bin e781bb3f69b972e2efff098e38ea3a69 *c7600rsp72043-adventerprisek9-mz.153-1.S1.bin ae995cdaa921fc85c71d33f186960dd5 *c7600rsp72043-adventerprisek9-mz.153-1.S2.bin Хеши сверил у остальных прошивок с торрентов не проходят хеши .... будьте осторожнее кому что нужно отдам .......... мысли у меня закончились Edited July 11, 2013 by alexpn Вставить ник Quote
ilili Posted July 11, 2013 Posted July 11, 2013 Если возможно - попробуйте etherchannel`ы убрать, если они есть. Мало ли, вдруг поможет. Супервизоры по слотам пробовали перетыкать ? Вставить ник Quote
alexpn Posted July 11, 2013 Author Posted July 11, 2013 (edited) Если возможно - попробуйте etherchannel`ы убрать, если они есть. Мало ли, вдруг поможет. Супервизоры по слотам пробовали перетыкать ? Модули пробывал претыкивать убирал все лишнее сейчас 1 процессор + 1 2-х портовая Прцессор в втором слоте плата в 3-м show module Mod Ports Card Type Model Serial No. --- ----- -------------------------------------- ------------------ ----------- 2 5 Route Switch Processor 720 10GE (Activ RSP720-3CXL-10GE SAL15066Z3J 3 2 ESM20G 7600-ES20-10G3CXL JAB1047041D Mod MAC addresses Hw Fw Sw Status --- ---------------------------------- ----- ------------- ------------ ------- 2 c89c.1dfb.8710 to c89c.1dfb.8717 1.1 12.2(33r)SRD 15.3(1)S Ok 3 0019.55c9.97d0 to 0019.55c9.984f 1.0 12.2(33r)SRB 15.3(1)S Ok Mod Sub-Module Model Serial Hw Status ---- --------------------------- ------------------ ----------- ------- ------- 2 Policy Feature Card 3 7600-PFC3CXL-10GE JAE1218GY7K 1.1 Ok 2 C7600 MSFC4 Daughterboard 7600-MSFC4 JAE1403AFXL 1.4 Ok 3 ESM20G Distributed Forwardi 7600-ES20-D3CXL JAB1047043X 1.0 Ok 3/0 1x10GE XFP Port 7600-ES20-2X10G JAB104704B3 1.0 Ok 3/1 1x10GE XFP Port 7600-ES20-2X10G JAB104704B3 1.0 Ok Mod Online Diag Status ---- ------------------- 2 Pass 3 Pass 3/0 Pass 3/1 Pass etherchannel убран .... на циске сейчас 2 BGP Full +iBGP+ OSPF для связи с другим оборудованием Загрузка 30 проц Остальное все убрано Прошивка ROM: System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1) BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 15.3(1)S2, RELEASE SOFTWARE (fc2) наработка Uptime for this control processor is 11 hours, 44 minutes Жду креша .... обычно на второй день XFP и X2 заводские .... схема включения проста на процессоре X2 модуль туда 2 BGP через виланы интерфеёсная плата портом 3/0/0 сморит в магистраль вот собственно и все Edited July 12, 2013 by alexpn Вставить ник Quote
zi_rus Posted July 12, 2013 Posted July 12, 2013 Кто поделится c7600rsp72043-adventerprisek9-mz.122-33.sre8 ? https://docs.google.com/file/d/0B4fBtuYnHgZhLUcyZzlfR1JpM2c/edit?pli=1 Вставить ник Quote
alexpn Posted July 12, 2013 Author Posted July 12, 2013 (edited) Кто поделится c7600rsp72043-adventerprisek9-mz.122-33.sre8 ? https://docs.google.com/file/d/0B4fBtuYnHgZhLUcyZzlfR1JpM2c/edit?pli=1 Спасибо сейчас сумму проверю контрольная сумма неверная должна быть 12ea691835b257fe7de797a5c08c6c4c а у вас e0a2f659c37692c4f325c10216a3cad4 Edited July 12, 2013 by alexpn Вставить ник Quote
OKyHb Posted July 12, 2013 Posted July 12, 2013 e0a2f659c37692c4f325c10216a3cad4 - всё как и должно быть для "ADVANCED IP SERVICES SSH". P.S. Спасибо за IOS :) Вставить ник Quote
zi_rus Posted July 12, 2013 Posted July 12, 2013 это не мне спасибо, гуглите ссылку, найдете источник Вставить ник Quote
alexpn Posted July 14, 2013 Author Posted July 14, 2013 e0a2f659c37692c4f325c10216a3cad4 - всё как и должно быть для "ADVANCED IP SERVICES SSH". P.S. Спасибо за IOS :) не буду спорить но на cisco.com все подругому Вставить ник Quote
zi_rus Posted July 15, 2013 Posted July 15, 2013 (edited) видимо это какой-то другой cisco.com, потому что мой говорит Description: ADVANCED IP SERVICES SSH Release: 12.2.33-SRE8 Release Date: 19/Mar/2013 File Name: c7600rsp72043-advipservicesk9-mz.122-33.SRE8.bin Min Memory: DRAM 1024 MB Flash 256 MB Size: 141.56 MB (148437412 bytes) MD5 Checksum: e0a2f659c37692c4f325c10216a3cad4 ну да, это не совсем тот образ, просили adventerprisek9, а это advipservicesk9 Edited July 15, 2013 by zi_rus Вставить ник Quote
alexpn Posted July 15, 2013 Author Posted July 15, 2013 видимо это какой-то другой cisco.com, потому что мой говорит Description: ADVANCED IP SERVICES SSH Release: 12.2.33-SRE8 Release Date: 19/Mar/2013 File Name: c7600rsp72043-advipservicesk9-mz.122-33.SRE8.bin Min Memory: DRAM 1024 MB Flash 256 MB Size: 141.56 MB (148437412 bytes) MD5 Checksum: e0a2f659c37692c4f325c10216a3cad4 ну да, это не совсем тот образ, просили adventerprisek9, а это advipservicesk9 Точно сорри проглядел ..... Вставить ник Quote
an-denis Posted January 24, 2014 Posted January 24, 2014 (edited) Спасибо всем за помощь Пробывал все IOS Креши продолжаются ..... думаем покупать тех поддержку вот прошивки 8cdb6a2a0a18e6641d66380bdbdab1e5 *c7600rsp72043-adventerprisek9-mz.122-33.SRD5.bin 065af3290a2e5f37a5488655d83ce2ab *c7600rsp72043-adventerprisek9-mz.151-3.S2.bin b5fdbff1059c3f1bbd5adcbdf1915474 *c7600rsp72043-adventerprisek9-mz.152-4.S1.bin e781bb3f69b972e2efff098e38ea3a69 *c7600rsp72043-adventerprisek9-mz.153-1.S1.bin ae995cdaa921fc85c71d33f186960dd5 *c7600rsp72043-adventerprisek9-mz.153-1.S2.bin Хеши сверил у остальных прошивок с торрентов не проходят хеши .... будьте осторожнее кому что нужно отдам .......... мысли у меня закончились Добрый день! Озвученная проблема решилась? Коллеги, нет возможности скачать последние иосы, поделитесь пожалуйста. Интересуют указанные: c7600rsp72043-adventerprisek9-mz.122-33.SRD5.bin c7600rsp72043-adventerprisek9-mz.152-4.S1.bin c7600rsp72043-adventerprisek9-mz.153-1.S1.bin c7600rsp72043-adventerprisek9-mz.153-1.S2.bin Edited January 24, 2014 by an-denis Вставить ник Quote
