Доброго времени суток, господа!
Есть 7600 с sup720 на который не получается обновить софт.
Лог загрузки
System Bootstrap, Version 12.2(33r)SRC4, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 2008 by cisco Systems, Inc.
Reading monitor variables from NVRAM
Reset reason for CPU board 0x0, baseboard 0x280 System Reset by Software.
Enabling interrupts
Initializing main memory
Initializing ATA controller
CPLD revision register is 0x1355
CPLD revision is 0x13
Disable CPU global Reset handler
Resetting Baseboard
Enable  CPU global Reset handler
Exiting init
C7600-RSP720-10GE/SP platform with 1048576 Kbytes of main memory
Autoboot executing command: "boot bootdisk:"
Initializing ATA monitor library...
string is bootdisk:c7600rsp72043-advipservicesk9-mz.122-33.SRC1.bin
Как видно она всегда грузит имидж командой Autoboot executing command: "boot bootdisk:"
Что имеем:
c7600#sh bootvar
BOOT variable = bootdisk:/c7600rsp72043-adventerprisek9-mz.153-1.S2.bin,1;bootdisk:/c7600rsp72043-advipservicesk9-mz.122-33.SRC1.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Configuration register is 0x2102
c7600#sh running-config all | i boot
boot-start-marker
boot system flash bootdisk:/c7600rsp72043-adventerprisek9-mz.153-1.S2.bin
boot system flash bootdisk:/c7600rsp72043-advipservicesk9-mz.122-33.SRC1.bin
boot-end-marker
c7600#dir bootdisk:/c7600rsp72043-adventerprisek9-mz.153-1.S2.bin
Directory of bootdisk:/c7600rsp72043-adventerprisek9-mz.153-1.S2.bin
  28  -rw-   181312460  Jun 17 2013 09:41:36 +04:00  c7600rsp72043-adventerprisek9-mz.153-1.S2.bin
512090112 bytes total (186990592 bytes free)
c7600#dir bootdisk:/c7600rsp72043-advipservicesk9-mz.122-33.SRC1.bin
Directory of bootdisk:/c7600rsp72043-advipservicesk9-mz.122-33.SRC1.bin
  29  -rw-   120180260  Jun 17 2013 09:43:00 +04:00  c7600rsp72043-advipservicesk9-mz.122-33.SRC1.bin
Пробовал грузиться также с sup-bootdisk, результат тот же.
На стенде есть 7600 с другим sup720, на ней воспроизвести не получилось, как ни крутил загружает то что ей сказали.
Нет мыслей куда копнуть?
NikAlexAn
Смогу только на следующей неделе проверить. Я на 99% уверен, что если удалить старый IOS с носителя, то она спокойно загрузиться с нужной мне версией, но это не снимает вопрос игнора bootvars.
  • 3 weeks later...
NikAlexAn
верно будет sup-bootdisk:
при загрузке не видно других девайсов кроме флешки и sup-bootdisk:
не поделитесь прошивкой ?
