Продам роутер 1841, память расширена до 384Мб. Стоит модуль AIM-VPN/SSL-1, HWIC-4ESW и карта для потока T1 (покупалось на ebay, поэтому T1). Flash карта заменена с 32 на 512 Мб. Железка проверена - рабочая. Цена 12 т.р. Территориально в Москве.
Router#sh ver
Cisco IOS Software, 1841 Software (C1841-ADVENTERPRISEK9-M), Version 12.4(9)T7, RELEASE SOFTWARE (fc3)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jan-08 15:41 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Router uptime is 4 minutes
System returned to ROM by reload at 19:41:49 UTC Sun Jun 16 2013
System image file is "flash:c1841-adventerprisek9-mz.124-9.T7.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco 1841 (revision 6.0) with 354304K/38912K bytes of memory.
Processor board ID FTX1104W0J6
6 FastEthernet interfaces
1 Serial interface
1 Virtual Private Network (VPN) Module
WIC T1-DSU
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
500472K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2102
Router#sh flash:
410435584 bytes available (101679104 bytes used)
Router#sh env
Fan 1 Running sucessfully
ILP Power Supply -Absent
