Иногда происходит полное очищение сабскрайберов в SM по непонятно какой причине, вот логах вот такое:
"26-May 2013", "20:05:37.938 YEKT","[Clear LEG Domains of usr.engage]",INFO ,"com.pcube.management.smm.LEGLinkFailureHandler","Clearing domain inet due to failue of usr.engage"
"26-May 2013", "20:05:41.540 YEKT","[removeAllSubsFromSE-sce2020]",INFO ,"com.pcube.management.smm.SmmDomainHandler","Finished removing all subscribers from SCE sce2020"
"26-May 2013", "20:05:41.550 YEKT","[WaitForRemovalFinish-inet]",INFO ,"com.pcube.management.smm.SmmDomainHandler","Finished removing all subscribers from domain inet"
"26-May 2013", "20:05:43.947 YEKT","[Clear LEG Domains of usr.engage]",INFO ,"com.pcube.management.smm.SmmMbean","***** SMM_CLEAR: inet"
"26-May 2013", "20:05:43.947 YEKT","[Clear LEG Domains of usr.engage]",INFO ,"com.pcube.logger.userlog.UserLog","SM: Clearing subscribers mappings in domain inet, due to LEG usr.engage connection failure."
Подскажите плиз чё делать что бы такого не случалось более?
Посмотри в конфиге SM секцию [sM-LEG Failure Handling]
# The following parameter defines the behavior of the SM in case of LEG-SM connection failure.
# This parameter is relevant only for cases SM and LEG are running on different machines.
# Note that this parameter defines a behavior that is similar for ALL connected LEGs.
# If the parameter is set to true then in case of LEG-SM connection failure that is not
# recovered within the defined timeout, the mappings of all subscribers in the domains
# defined in the 'LEG-Domains Association' section for the LEG that was disconnected,
# will be removed
# IMPORTANT: LEG Domains must be defined in the following section in case this parameter is set to 'true'
# Optional values: [true/false]. Default: false.
clear_all_mappings=false
