В логах постоянно повторяется:
May 23 21:01:05.120 UTC: %HARDWARE-2-FAN_ERROR: Fan 1 Failure
May 23 21:01:05.120 UTC: %PLATFORM_ENV-1-FAN: Faulty fan detected
May 23 21:01:05.120 UTC: %PLATFORM_ENV-1-TEMP: Abnormal temperature detected
May 23 21:01:57.566 UTC: %HARDWARE-5-FAN_OK: Fan 1 works fine
May 23 21:03:45.579 UTC: %HARDWARE-2-FAN_ERROR: Fan 1 Failure
May 23 21:03:45.579 UTC: %PLATFORM_ENV-1-FAN: Faulty fan detected
May 23 21:03:45.579 UTC: %PLATFORM_ENV-1-TEMP: Abnormal temperature detected
May 23 21:04:38.025 UTC: %HARDWARE-5-FAN_OK: Fan 1 works fine
May 23 21:05:59.882 UTC: %HARDWARE-2-FAN_ERROR: Fan 1 Failure
May 23 21:05:59.882 UTC: %PLATFORM_ENV-1-FAN: Faulty fan detected
May 23 21:06:00.931 UTC: %HARDWARE-5-FAN_OK: Fan 1 works fine
May 23 21:06:08.271 UTC: %PLATFORM_ENV-1-TEMP: Abnormal temperature detected
May 23 21:06:24.000 UTC: %HARDWARE-2-FAN_ERROR: Fan 1 Failure
May 23 21:06:24.000 UTC: %PLATFORM_ENV-1-FAN: Faulty fan detected
May 23 21:06:24.000 UTC: %PLATFORM_ENV-1-TEMP: Abnormal temperature detected
May 23 21:07:16.429 UTC: %HARDWARE-5-FAN_OK: Fan 1 works fine
May 23 21:08:07.835 UTC: %HARDWARE-2-FAN_ERROR: Fan 1 Failure
May 23 21:08:07.835 UTC: %PLATFORM_ENV-1-FAN: Faulty fan detected
May 23 21:08:08.883 UTC: %HARDWARE-5-FAN_OK: Fan 1 works fine
May 23 21:09:01.330 UTC: %HARDWARE-2-FAN_ERROR: Fan 1 Failure
May 23 21:09:01.330 UTC: %PLATFORM_ENV-1-FAN: Faulty fan detected
May 23 21:09:01.330 UTC: %PLATFORM_ENV-1-TEMP: Abnormal temperature detected
May 23 21:09:54.841 UTC: %HARDWARE-5-FAN_OK: Fan 1 works fine
May 23 21:10:27.364 UTC: %HARDWARE-2-FAN_ERROR: Fan 1 Failure
May 23 21:10:27.364 UTC: %PLATFORM_ENV-1-FAN: Faulty fan detected
May 23 21:10:28.413 UTC: %HARDWARE-5-FAN_OK: Fan 1 works fine
Может кто знает чего там за вентиляторы (модель, отдельные или блоком, аналоги, etc ) и где их можно купить? Чтобы, если уж затевать работы и останавливать сервис, то иметь все что нужно в наличие...
На сколько помню, там турбины стоят с воздуховодом. В продаже не видел ни разу. Еще попутно они БП охлаждают. Пробуйте смазать/чинить.
Могут быть проблемы и со схемой управления, и сдох БП. У меня было - починить не удалось - запустили улитку напрямую от +12. Шумно, но пока живет.
Да меня тоже смущает переодический характер проблемы.. хотя наверное какие-то проблемы с механикой могут так сносить мозг контроллеру.
Так и есть... повспухали электролиты на плате. Никогда не паял цисковские платы, как там с припоем, не тугоплавкий?
Вобщем на плате 5 вхдутых кондёров одного номинала (1800мкф, 6.3в), кроме них рядом на плате еще 5 визуально нормальных (3-и 1000мкф 16в, 2-а 1200мкф 6.3в). Вот сижу в раздумьях - менять только вспухшие или все поголовно? Учитывая, что родные - японские (nichicon), а для замены мне доступен только китай (capxon).
Не могу ждать, сроки горят ) Дело в том, что железо, установленное на замену 3750 на время ремонта, как бы взято "на тест" и его надо очень скоро вернуть =)
А что capxon совсем печаль? Может есть какие-то более доступные марки, которые более-менее?
ЗЫ Заметил, что один из вентиляторов таки вращается с неким призвуком... ведь теоретически ухудшения в механике вентилятора могли увеличить расходуемую им мощность и повлиять на самочувствие кондеров в цепи его питания?
А по вентиляторам что посоветуете?
Есть смысл измерить и сравнить ток в цепи каждого вентилятора, запитав их от внешнего БП?
Edited by bos9
Вскрылись новые подробности...
БП при старте после продолжительного пререрыва начинает выдавать напряжение только спустя 1-2 минуты. При последующих выключениях-включениях стартует сразу.
Что можно посмотреть? Высохшие ёмкости дольше заряжаются?
Edited by bos9
Нет. Крупные емкости обычно служат как фильтры, т.е. если их емкость уменьшилась - они будут плохо фильтровать помехи. Если ухудшился таких ESR емкостей - будут "травить" ВЧ помехи.
Мелкие емкости используются как фильтры и возможно как рабочие элементы к примеру в схеме импульсного БП.
В вашем случае или потеря контакта (микротрещины), или к примеру в колебательном контуре один из элементов потерял свои свойства и только с повышением температуры кое-как стартует. Или же один из параметров выходит за пределы допустимого и какой-нить PMIC не дает команду на запуск, пока он не прийдет в норму.
Учитывая что такие железки обычно не для офисов и стоят немало, если не хотите лотереи работает-не работает, и возможно жареной основной платы - советую заменить БП и не изобретать колесо. Но есть шанс, что проблема не в БП, а в основной плате, и соответственно замена БП ничего не даст.
Подал через RPS 12 вольт от писишного БП, все сразу заводится, но циска переодически не проходит селф-тесты при загрузке, впрочем как и с родным БП... Возможно тому виной неперепаянные кондеры (те что не вздулись), а возможно и нет. Похоже пациент скорее мертв, чем нет... С кондерами намучался, мало того что припой тугой, так еще и дырки прям впритирку сделаны, только толкать. В принципе уже присмотрел на ебае и БП, и кондеры, и вентиляторы, но теперь вот думаю, а поможет ли.
Вот фрагменты нескольких загрузок с ошибками:
Initializing flashfs...
flashfs[1]: 8 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 8773120
flashfs[1]: Bytes available: 7225856
flashfs[1]: flashfs fsck took 1 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Checking for Bootloader upgrade.. not needed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: Cannot bring up both Stack Rings in PhyLoopback
POST: Failed Packet Receive asic 2 queue 0
POST: PortASIC RingLoopback Tests : End, Status Failed
POST: port-asic ring loopback test failed
driver class subsystem initialization failed
flashfs[1]: 9 files, 2 directories
flashfs[1]: Bytes used: 8969728
flashfs[1]: Bytes available: 7029248
Sasq-Yeti Reset Failed(# of PortASICs Detected 0,configured 7)MIC Conf reg value 110 0
Error: MIC PCS INfo 0x1F
supervisor subsystem initialization failed
%Software-forced reload
... далее вываливает crashinfo и по новой. Причем, если отключить питание и заного включить, то может и с первого раза загрузиться.
Edited by bos9
