Dimka88 Posted May 21, 2013 Posted May 21, 2013 (edited) Столкнулся с ситуацией производительности freeradius2 rlm_perl. Операционная система Gentoo. Биллинг Abills. В после аварии начинается многократная авторизация пользователей. После чего радиус начинает в лог кричать Error: Discarding duplicate request from client pptp2 port 35157 - ID: 205 due to unfinished request 7086426 Перл собран с поддержкой потоков, что бы request выполнялись параллельно. billing ~ # perl -V | grep USE_I USE_64_BIT_INTUSE_ITHREADS USE_LARGE_FILES ~ # cat /etc/raddb/radiusd.conf prefix = /usr exec_prefix = ${prefix} sysconfdir = /etc localstatedir = /var/lib sbindir = ${exec_prefix}/sbin logdir = /var/log/radius raddbdir = ${sysconfdir}/raddb radacctdir = ${logdir}/radacct name = radiusd confdir = ${raddbdir} run_dir =/var/run/radiusd db_dir = ${raddbdir} libdir = /usr/lib64/freeradius pidfile = ${run_dir}/${name}.pid user = radiusd group = radiusd max_request_time = 30 cleanup_delay = 5 max_requests = 3840000 #debug_level = 1 listen { type = auth ipaddr = * port = 0 } listen { ipaddr = * port = 0 type = acct } hostname_lookups = no allow_core_dumps = no regular_expressions = yes extended_expressions = yes log { destination = files file = ${logdir}/radius.log syslog_facility = daemon stripped_names = no auth = no auth_badpass = no auth_goodpass = no } checkrad = ${sbindir}/checkrad security { max_attributes = 200 reject_delay = 1 status_server = yes } proxy_requests = no $INCLUDE clients.conf thread pool { start_servers = 32 max_servers = 32 min_spare_servers = 3 max_spare_servers = 10 max_requests_per_server = 0 } modules { $INCLUDE ${confdir}/modules/ } instantiate { exec expiration logintime } $INCLUDE policy.conf $INCLUDE sites-enabled/default ~ # cat /etc/raddb/modules/perl perl { module = /usr/abills/libexec/rlm_perl.pl func_authorize = authorize func_accounting = accounting func_authenticate = authenticate func_preacct = preacct func_checksimul = checksimul func_xlat = xlat max_clones = 32 start_clones = 32 min_spare_clones = 0 max_spare_clones = 32 cleanup_delay = 5 max_request_per_clone = 0 } Вопрос: Как сделать радиус производительнее? И как диагностировать данную проблему? Edited May 21, 2013 by Dimka88 Вставить ник Quote
[anp/hsw] Posted May 21, 2013 Posted May 21, 2013 Не уверен, что это проблема производительности radius-сервера, по-моему дело в клиенте. У нас freeradius2 + UTM5, такие строчки в логе тоннами валятся. Каждый SQL-запрос руками писал, и потом делал бенчмарк на копии боевой базы. Могу с уверенностью сказать, что дело не в производительности radius-SQL и не в radius-perl (отключение perl-логики вообще никак не влияет на эти сообщения). Исходя из сообщения ошибки предположил, что в radiusclient'е слижком маленький таймаут, и он посылает повторный request, но radius-сервер отвечает менее чем за 100мс, и в клиенте я таких таймаутов не нашел. tcpdump вам подтвердит, что это именно два запроса от клиента с одинаковым ID, и никак не проблема сервера. Вставить ник Quote
Dimka88 Posted May 21, 2013 Author Posted May 21, 2013 ' timestamp='1369119765' post=840403]tcpdump вам подтвердит, что это именно два запроса от клиента с одинаковым ID, и никак не проблема сервера. Спасибо за пинок, стоит проработать данную мысль. Доп информация. В качестве NAS используется accel-pptp 0.8.5 патчи pppd на гигаворд и COA. Вставить ник Quote
Dimka88 Posted May 21, 2013 Author Posted May 21, 2013 (edited) [anp/hsw] как вы и писали tcpdump(ом) увидел следующее 10:48:27.168728 IP 10.1.1.1.44973 > 10.0.0.1.radius-acct: RADIUS, Accounting Request (4), id: 0xb3 length: 161 10:48:27.169616 IP 10.1.1.1.44973 > 10.0.0.1.radius-acct: RADIUS, Accounting Request (4), id: 0xb3 length: 161 10:48:27.173274 IP 10.0.0.1.radius-acct > 10.1.1.1.44973: RADIUS, Accounting Response (5), id: 0xb3 length: 20 То есть бороться необходимо с NAS? В radiusclient-ng/radiusclient.conf есть такие строки radius_timeout 10 #Время ожидания ответа от RADIUS сервера radius_retries 3 #Повторит запрос 3 раза прежде чем начать подключение к следующему RADIUS серверу Интересно radius_timeout 10(Это секунды?) если секунды то почему так 10:48:27.168728 IP 10.1.1.1.44973 > 10.0.0.1.radius-acct: RADIUS, Accounting Request (4), id: 0xb3 length: 161 10:48:27.169616 IP 10.1.1.1.44973 > 10.0.0.1.radius-acct: RADIUS, Accounting Request (4), id: 0xb3 length: 161 Edited May 21, 2013 by Dimka88 Вставить ник Quote
[anp/hsw] Posted May 21, 2013 Posted May 21, 2013 Да, таймауты все в секундах. Видимо повторный пакет не является следствием превышения таймаута, и регулируется какой-то другой настройкой. accel-pptp тут непричем, rp-pppoe также флудит. Тут дело, думаю, в libradiusclient или libradiusclient-ng (я пробовал оба, но результат одинаков). Вставить ник Quote
Abram Posted May 21, 2013 Posted May 21, 2013 У меня похожим образом mpd5 флудит. Гуглил - проблема в libradiusclient, даже патч какой-то проскакивал. В конце концов забил. :) Вставить ник Quote
Dimka88 Posted May 21, 2013 Author Posted May 21, 2013 (edited) Если все с этим живут, тогда интересный вопрос, почему Abills считает, что ему не пришли аккаунтинг пакеты оn некоторых сессий? и он берёт их и просто ZAP. А потом выдаёт IP которые на NAS висят а в биллинге их уже нет. Есть ли способ ограничить количество авторизаций за секунду на стороне freeradius2, так как accel-pptp старые(с новыми не вышло получить такую производительность) со стороны NAS не получится? Дописывать файл авторизации Abills с счётчиками и посылать REJECT если лимит авторизаций превысил? Edited May 21, 2013 by Dimka88 Вставить ник Quote
~AsmodeuS~ Posted May 21, 2013 Posted May 21, 2013 Если все с этим живут, тогда интересный вопрос, почему Abills считает, что ему не пришли аккаунтинг пакеты оn некоторых сессий? и он берёт их и просто ZAP. А потом выдаёт IP которые на NAS висят а в биллинге их уже нет. Есть ли способ ограничить количество авторизаций за секунду на стороне freeradius2, так как accel-pptp старые(с новыми не вышло получить такую производительность) со стороны NAS не получится? Дописывать файл авторизации Abills с счётчиками и посылать REJECT если лимит авторизаций превысил? Абилс работает только с теми пакетами чсто пришли елси какотой пакет не пришёл попробуйте его найти в детализации акаунтинга очень сомниваюсь что он там будет скорее всего проблема в чёмто другом стоит смореть еще sql_errors Вставить ник Quote
Dimka88 Posted May 22, 2013 Author Posted May 22, 2013 скорее всего проблема в чёмто другом стоит смореть еще sql_errors Не исключаю, что проблема может быть в mysql но в sql_errors пару ошибок, и то с web интерфейса. Детализацию акаунтинга отключил, слишком много ресурсов потребляет. Специально аварию правоцировать не буду.В дальнейшем возьмусь детальнее изучать slow_query и соответствие radius пакетов. В mysql наблюдаю следующее. Смущает количество неудачных попыток и перерванных запросов. Вот что говорят некоторые переменные Aborted clients = 651 #Количество прерванных соединений в связи с потерей связи и неверно закрытым соединением клиента. Aborted connects = 82 #Количество неудавшихся попыток соединения к серверу MySQL. Created tmp disk tables = 29.6 k #Количество временных таблиц, автоматически созданных сервером на диске, во время выполнения SQL-выражений. #tmp_table_size увеличу при следующих плановых работах до 400k Created tmp tables = 278.8 k #Количество временных таблиц в памяти, созданных сервером автоматически в процессе выполнения SQL-выражений. Handler read rnd = 6.4 M #Количество запросов, на чтение строки, основанных на ее позиции. Большое значение переменной может быть обусловлено #частым выполнением запросов использующих сортировку результата, выполнением большого числа запросов требующих полного #сканирования таблиц, наличием объединений не использующих индексы надлежащим образом. Handler read rnd next = 32.3 G #Количество запросов на чтение следующей строки из файла данных. Данное значение будет высоким, при частом #сканировании таблиц. Обычно это означает, что таблицы не проиндексированы надлежащим образом или запросы не #используют преимущества индексов. Innodb buffer pool reads = 3.7 k #Количество последовательных запросов на чтение, которые InnoDB не смог выполнить из буферного пула и использовал #постраничное чтение. Opened tables = 10.3 k #Общее количество открывавшихся таблиц. При большом значении переменной рекомендуется увеличить размер кеша таблиц Slow queries = 131 #Количество запросов, выполнявшихся более long_query_time секунд. Sort merge passes = 419 #Количество проходов, сделанных алгоритмом сортировки. Table locks waited = 135.4 k #Количество запросов на блокировку таблицы, которые были удовлетворены только после определенного периода ожидания. #Если значение велико и есть проблемы с производительностью, необходимо сначала оптимизировать свои запросы, а затем #разбить свою таблицу (или таблицы) или использовать репликацию. Необходимость оптимизировать БД присутствует это очевидно. Покажет кто конфиг оптимизированной mysql с таблицами MyISAM для биллинговых систем? Вставить ник Quote
pppoetest Posted May 22, 2013 Posted May 22, 2013 (edited) Тут с индексами надо воевать, которых вообще нет, имхо. Edited May 22, 2013 by pppoetest Вставить ник Quote
~AsmodeuS~ Posted May 22, 2013 Posted May 22, 2013 Тут с индексами надо воевать, которых вообще нет, имхо. ну ну пожалуста по подробней где нету индексов ? Вставить ник Quote
NiTr0 Posted May 22, 2013 Posted May 22, 2013 если секунды то почему так С сетью все в порядке? Мож свичик какой вызывает раздвоение пакетов? На брасе дамп снимали? Вставить ник Quote
~AsmodeuS~ Posted May 22, 2013 Posted May 22, 2013 скорее всего проблема в чёмто другом стоит смореть еще sql_errors Не исключаю, что проблема может быть в mysql но в sql_errors пару ошибок, и то с web интерфейса. Детализацию акаунтинга отключил, слишком много ресурсов потребляет. Специально аварию правоцировать не буду.В дальнейшем возьмусь детальнее изучать slow_query и соответствие radius пакетов. В mysql наблюдаю следующее. Смущает количество неудачных попыток и перерванных запросов. Вот что говорят некоторые переменные Aborted clients = 651 #Количество прерванных соединений в связи с потерей связи и неверно закрытым соединением клиента. Aborted connects = 82 #Количество неудавшихся попыток соединения к серверу MySQL. Created tmp disk tables = 29.6 k #Количество временных таблиц, автоматически созданных сервером на диске, во время выполнения SQL-выражений. #tmp_table_size увеличу при следующих плановых работах до 400k Created tmp tables = 278.8 k #Количество временных таблиц в памяти, созданных сервером автоматически в процессе выполнения SQL-выражений. Handler read rnd = 6.4 M #Количество запросов, на чтение строки, основанных на ее позиции. Большое значение переменной может быть обусловлено #частым выполнением запросов использующих сортировку результата, выполнением большого числа запросов требующих полного #сканирования таблиц, наличием объединений не использующих индексы надлежащим образом. Handler read rnd next = 32.3 G #Количество запросов на чтение следующей строки из файла данных. Данное значение будет высоким, при частом #сканировании таблиц. Обычно это означает, что таблицы не проиндексированы надлежащим образом или запросы не #используют преимущества индексов. Innodb buffer pool reads = 3.7 k #Количество последовательных запросов на чтение, которые InnoDB не смог выполнить из буферного пула и использовал #постраничное чтение. Opened tables = 10.3 k #Общее количество открывавшихся таблиц. При большом значении переменной рекомендуется увеличить размер кеша таблиц Slow queries = 131 #Количество запросов, выполнявшихся более long_query_time секунд. Sort merge passes = 419 #Количество проходов, сделанных алгоритмом сортировки. Table locks waited = 135.4 k #Количество запросов на блокировку таблицы, которые были удовлетворены только после определенного периода ожидания. #Если значение велико и есть проблемы с производительностью, необходимо сначала оптимизировать свои запросы, а затем #разбить свою таблицу (или таблицы) или использовать репликацию. Необходимость оптимизировать БД присутствует это очевидно. Покажет кто конфиг оптимизированной mysql с таблицами MyISAM для биллинговых систем? уже больше 2 лет мы рекомендуем использовать исключительно innodb так ккак в системе используются транзации и другие возможности реляционых баз данных которых нет в myisam Вставить ник Quote
Dimka88 Posted May 22, 2013 Author Posted May 22, 2013 (edited) С сетью все в порядке? Мож свичик какой вызывает раздвоение пакетов? На брасе дамп снимали? Дамп снимал, с сетью все в порядке. уже больше 2 лет мы рекомендуем использовать исключительно innodb так ккак в системе используются транзации и другие возможности реляционых баз данных которых нет в myisam Очень полезная информация, куда мои глаза глядели когда сервер готовил. Ваш пост на форуме Abills(Пт апр 01, 2011 9:28 pm) следующая версия которая війдет скорее всего будет использовать по умолчанию не MyISAM єто произойдёт в ближайшие месяцы Рекомендую в вашем dokuwiki написать про это, лишним не будет. Тут с индексами надо воевать, которых вообще нет, имхо. Возможно Abills не причём к таким индексам, скорее всего мои специфические статистики (Очень нужные, выполняются не более 5 раз в месяц). Edited May 22, 2013 by Dimka88 Вставить ник Quote
NiTr0 Posted May 22, 2013 Posted May 22, 2013 Дамп снимал, с сетью все в порядке. Т.е. уже на ифейсе браса двоение? Если так - смотрите, не подгружается ли радиус-модуль дважды. Вставить ник Quote
Dimka88 Posted May 23, 2013 Author Posted May 23, 2013 Т.е. уже на ифейсе браса двоение? Радиус клиент отправляет пакет на сервер, радиус сервер не успевает ответить, тогда радиус клиент шлёт пакет повторно через 0.1 секунды. Если так - смотрите, не подгружается ли радиус-модуль дважды. Модуль подгружен один раз. Вставить ник Quote
Davion Posted May 23, 2013 Posted May 23, 2013 скорее всего проблема в чёмто другом стоит смореть еще sql_errors Не исключаю, что проблема может быть в mysql но в sql_errors пару ошибок, и то с web интерфейса. Детализацию акаунтинга отключил, слишком много ресурсов потребляет. Специально аварию правоцировать не буду.В дальнейшем возьмусь детальнее изучать slow_query и соответствие radius пакетов. В mysql наблюдаю следующее. Смущает количество неудачных попыток и перерванных запросов. Вот что говорят некоторые переменные Aborted clients = 651 #Количество прерванных соединений в связи с потерей связи и неверно закрытым соединением клиента. Aborted connects = 82 #Количество неудавшихся попыток соединения к серверу MySQL. Created tmp disk tables = 29.6 k #Количество временных таблиц, автоматически созданных сервером на диске, во время выполнения SQL-выражений. #tmp_table_size увеличу при следующих плановых работах до 400k Created tmp tables = 278.8 k #Количество временных таблиц в памяти, созданных сервером автоматически в процессе выполнения SQL-выражений. Handler read rnd = 6.4 M #Количество запросов, на чтение строки, основанных на ее позиции. Большое значение переменной может быть обусловлено #частым выполнением запросов использующих сортировку результата, выполнением большого числа запросов требующих полного #сканирования таблиц, наличием объединений не использующих индексы надлежащим образом. Handler read rnd next = 32.3 G #Количество запросов на чтение следующей строки из файла данных. Данное значение будет высоким, при частом #сканировании таблиц. Обычно это означает, что таблицы не проиндексированы надлежащим образом или запросы не #используют преимущества индексов. Innodb buffer pool reads = 3.7 k #Количество последовательных запросов на чтение, которые InnoDB не смог выполнить из буферного пула и использовал #постраничное чтение. Opened tables = 10.3 k #Общее количество открывавшихся таблиц. При большом значении переменной рекомендуется увеличить размер кеша таблиц Slow queries = 131 #Количество запросов, выполнявшихся более long_query_time секунд. Sort merge passes = 419 #Количество проходов, сделанных алгоритмом сортировки. Table locks waited = 135.4 k #Количество запросов на блокировку таблицы, которые были удовлетворены только после определенного периода ожидания. #Если значение велико и есть проблемы с производительностью, необходимо сначала оптимизировать свои запросы, а затем #разбить свою таблицу (или таблицы) или использовать репликацию. Необходимость оптимизировать БД присутствует это очевидно. Покажет кто конфиг оптимизированной mysql с таблицами MyISAM для биллинговых систем? Не подскажете что за веб интерфейс используете для отчетов по MySQL? Вставить ник Quote
Dimka88 Posted May 23, 2013 Author Posted May 23, 2013 Не подскажете что за веб интерфейс используете для отчетов по MySQL? phpmyadmin версии 3.5.3 на главной странице в горизонтальном меню кнопка Состояние. Вставить ник Quote
NiTr0 Posted May 23, 2013 Posted May 23, 2013 Радиус клиент отправляет пакет на сервер, радиус сервер не успевает ответить, тогда радиус клиент шлёт пакет повторно через 0.1 секунды. Не через 0.1 сек. А чарез 0.001 сек. Т.е. - практически сразу же: 10:48:27.168728 IP 10.1.1.1.44973 > 10.0.0.1.radius-acct: RADIUS, Accounting Request (4), id: 0xb3 length: 161 10:48:27.169616 IP 10.1.1.1.44973 > 10.0.0.1.radius-acct: RADIUS, Accounting Request (4), id: 0xb3 length: 161 Вставить ник Quote
~AsmodeuS~ Posted May 23, 2013 Posted May 23, 2013 Не подскажете что за веб интерфейс используете для отчетов по MySQL? phpmyadmin версии 3.5.3 на главной странице в горизонтальном меню кнопка Состояние. уже добавлено недостающие отчёты в ABillS SQL commander Вставить ник Quote
Dimka88 Posted June 10, 2013 Author Posted June 10, 2013 (edited) Решил переехать с MyISAM на InnoDB. Будут ли подводные камни, кто сталкивался? Если не сложно поделитесь my.cnf под Abills для InnoDB. UPD// нашёл в abills/misc/mysql/my.cnf [client] port = 3306 #socket = /tmp/mysql.sock # The MySQL server [mysqld] port = 3306 #socket = /tmp/mysql.sock skip-external-locking query_cache_size=128M query-cache-type=1 join_buffer_size=256K key_buffer=640M query_cache_limit=2M max_allowed_packet=1M #table_cache=512 sort_buffer=12M read_buffer_size=12M net_buffer_length=16K myisam_sort_buffer_size=64M thread_cache_size=4 server-id = 1 max_connections = 1500 slave-compressed = 1 #log-bin=abills-bin.log #log-bin long_query_time = 5 slow_query_log slow_query_log_file = mysqld-slow-query.log #log=mysql_query.log #------------------ #_REPLICATION_ #------------------ # innodb default-storage-engine = innodb innodb_file_per_table innodb_additional_mem_pool_size = 16M #x8 #innodb_buffer_pool_size = 2G # or 9G on x64 innodb_thread_concurrency = 4 innodb_flush_log_at_trx_commit = 2 innodb_log_buffer_size = 8M innodb_log_file_size = 128M innodb_log_files_in_group = 2 innodb_max_dirty_pages_pct = 90 innodb_lock_wait_timeout = 120 # innodb_flush_method = O_DIRECT ## [mysqldump] quick max_allowed_packet=32M [mysql] no-auto-rehash # Remove the next comment character if you are not familiar with SQL #safe-updates [isamchk] key_buffer=40M sort_buffer=40M read_buffer=10M write_buffer=10M [myisamchk] key_buffer=40M sort_buffer=40M read_buffer=10M write_buffer=10M [mysqlhotcopy] interactive-timeout Edited June 10, 2013 by Dimka88 Вставить ник Quote
NiTr0 Posted June 10, 2013 Posted June 10, 2013 Посмотрите этот гайд. Доступно описано, откуда у параметров ноги растут. Хоть и не под абиллс, но принцип тот же, да и нагрузка от заббикса, кхм, "несколько" побольше буде, эдак на 1-2 порядка (sata raid1 на 7200рпм упрется в потолок по iops где-то при объеме записей порядка 3 ГБ/сутки). Вставить ник Quote
~AsmodeuS~ Posted June 10, 2013 Posted June 10, 2013 вновом движке sql более интелектуальный конструктор уменьшает нагрузку на базу Вставить ник Quote
Dimka88 Posted June 12, 2013 Author Posted June 12, 2013 вновом движке sql более интелектуальный конструктор уменьшает нагрузку на базу Пока не планирую на новый движок бежать. Переделал базу c MyISAM на InnoDB. Выполнял следующие процедуры: # Сохраняем базу данных в файл mysqldump abills > abills.sql -p # Меняем ENGINE sed 's/ENGINE=MyISAM/ENGINE=InnoDB/g' abills.sql > abills.innodb.sql # Удаляем базу mysqladmin -p drop abills # Создаём базу mysqladmin -p create abills # Заливаем изменённый дамп базы mysql -p abills < abills.innodb.sql Далее изменил my.cnf, привёл к следующему виду. [client] port = 3306 socket = /var/run/mysqld/mysqld.sock [mysqld_safe] err-log = /var/log/mysql/mysql.err [mysqld] character-set-server = utf8 user = mysql port = 3306 socket = /var/run/mysqld/mysqld.sock pid-file = /var/run/mysqld/mysqld.pid log-error = /var/log/mysql/mysqld.err basedir = /usr datadir = /database/mysql/ skip-external-locking query_cache_size = 512M query-cache-type = 1 join_buffer_size = 256K key_buffer = 640M query_cache_limit = 256M max_allowed_packet = 1M sort_buffer = 12M read_buffer_size = 12M net_buffer_length = 16K myisam_sort_buffer_size = 64M thread_cache_size = 4 server-id = 1 max_connections = 1500 slave-compressed = 1 long_query_time = 2 slow_query_log slow_query_log_file = mysqld-slow-query.log tmp_table_size = 256M max_heap_table_size = 256M table_cache = 512 # innodb default-storage-engine = innodb innodb_file_per_table innodb_additional_mem_pool_size = 16M innodb_buffer_pool_size = 12G innodb_thread_concurrency = 48 innodb_flush_log_at_trx_commit = 2 innodb_log_buffer_size = 8M innodb_log_file_size = 128M innodb_log_files_in_group = 2 innodb_max_dirty_pages_pct = 90 innodb_lock_wait_timeout = 120 innodb_flush_method = O_DIRECT innodb_data_home_dir = /database/mysql/ innodb_log_group_home_dir = /database/mysql/ innodb_data_file_path = ibdata1:100M:autoextend [mysqldump] quick max_allowed_packet = 32M character-sets-dir = /usr/share/mysql/charsets default-character-set = utf8 [mysql] no-auto-rehash character-sets-dir = /usr/share/mysql/charsets default-character-set = utf8 [isamchk] key_buffer = 40M sort_buffer = 40M read_buffer = 10M write_buffer = 10M [myisamchk] key_buffer = 40M sort_buffer = 40M read_buffer = 10M write_buffer = 10M [mysqlhotcopy] interactive-timeout Железяка X2 Xeon, 48Gb ram, 4 SAS, задействованы под X2 RAID 1 под систему и X2 RAID 1 под базу. При старте радиуса, mysql сервер прыгнул в полку на 10 секунд, но после выровнялся. load averages: 0.01, 0.02, 0.05 Есть конечно еще нюансы над которыми необходимо работать. Версия mysqld 5.1.66 (Запланировал через пару недель на 5.6.10, если не добьюсь производительности) Aborted clients 3 Количество прерванных соединений в связи с потерей связи и неверно закрытым соединением клиента. Aborted connects 1 Количество неудавшихся попыток соединения к серверу MySQL. Created tmp disk tables 39 Количество временных таблиц, автоматически созданных сервером на диске, во время выполнения SQL-выражений. Если значение Created_tmp_disk_tables велико, следует увеличить значение переменной tmp_table_size, чтобы временные таблицы располагались в памяти, а не на жестком диске. Handler read rnd 5.1 k Количество запросов, на чтение строки, основанных на ее позиции. Большое значение переменной может быть обусловлено частым выполнением запросов использующих сортировку результата, выполнением большого числа запросов требующих полного сканирования таблиц, наличием объединений не использующих индексы надлежащим образом. Handler read rnd next 121.2 M Количество запросов на чтение следующей строки из файла данных. Данное значение будет высоким, при частом сканировании таблиц. Обычно это означает, что таблицы не проиндексированы надлежащим образом или запросы не используют преимущества индексов. Innodb buffer pool pages dirty 43 Текущее количество "грязных" страниц. Innodb buffer pool reads 17.3 k Количество последовательных запросов на чтение, которые InnoDB не смог выполнить из буферного пула и использовал постраничное чтение. Opened tables 529 Общее количество открывавшихся таблиц. При большом значении переменной рекомендуется увеличить размер кеша таблиц (table_cache). Slow queries 86 Количество запросов, выполнявшихся более long_query_time секунд. Просмотрел журнал, записи следующего виде SET timestamp=1371000864; SELECT DECODE(password, 'secret') FROM users WHERE id='anylogin1'; # User@Host: abills[abills] @ localhost [] # Query_time: 2.526582 Lock_time: 0.000351 Rows_sent: 1 Rows_examined: *** SET timestamp=1371000864; SELECT DECODE(password, 'secret') FROM users WHERE id='anylogin2'; # User@Host: abills[abills] @ localhost [] # Query_time: 2.332391 Lock_time: 0.000207 Rows_sent: 1 Rows_examined: *** Проверил выполнение DECODE, в 0.0003 вкладывается без кеш. В пик при включении запросы сыпались, сейчас ничего не пишет. Table locks waited 11.4 k Количество запросов на блокировку таблицы, которые были удовлетворены только после определенного периода ожидания. Если значение велико и есть проблемы с производительностью, необходимо сначала оптимизировать свои запросы, а затем разбить свою таблицу (или таблицы) или использовать репликацию. C недавних пор занялся детально изучать mysql. Если видите, что то очевидное для оптимизации, буду рад совету. Вставить ник Quote
NiTr0 Posted June 12, 2013 Posted June 12, 2013 А ничего, что innodb_file_per_table - бессмысленна сама по себе, ибо, исходя из мануала, должно быть innodb_file_per_table=1 ? Ну и да, мануал от заббикса я привел. По сравнению с дефолтными значениями - у меня iops упал с 200 до 40. Как по мне - результат налицо. Вставить ник Quote
