megahertz0 Posted April 23, 2013 Posted April 23, 2013 Как это сделать? logging executed-commands disable делал. Вот что говорит статус: Gorkogo_26(config)#sh logging executed-commands sta Logging executed command state is disable А в лог все равно сыпется: 13 %Apr 23 13:20:22 2013 <critical> DEFAULT[zIMI]:Type:Telnet, User:megahertz, IP:10.0.100.100:43612, Command:sh logging buffered 12 %Apr 23 13:20:21 2013 <critical> DEFAULT[zIMI]:Type:Telnet, User:megahertz, IP:10.0.100.100:43612, Command:sh logging buffered \ 11 %Apr 23 13:19:50 2013 <critical> DEFAULT[zIMI]:Type:Telnet, User:megahertz, IP:10.0.100.100:43612, Command:sh logging executed-commands sta 10 %Apr 23 13:19:20 2013 <critical> DEFAULT[zIMI]:Type:Telnet, User:megahertz, IP:10.0.100.100:43612, Command:conf t 9 %Apr 23 13:17:20 2013 <critical> DEFAULT[zIMI]:Type:Telnet, User:megahertz, IP:10.0.100.100:43612, Command:sh logg buff level warnings 8 %Apr 23 13:17:08 2013 <critical> DEFAULT[zIMI]:Type:Telnet, User:megahertz, IP:10.0.100.100:43612, Command:sh logg buff 7 %Apr 23 13:17:07 2013 <critical> DEFAULT[zIMI]:Type:Telnet, User:megahertz, IP:10.0.100.100:43612, Command:sh logg buff 6 %Apr 23 13:17:07 2013 <critical> DEFAULT[zIMI]:Type:Telnet, User:megahertz, IP:10.0.100.100:43612, Command:sh logg buff 5 %Apr 23 13:17:06 2013 <critical> DEFAULT[zIMI]:Type:Telnet, User:megahertz, IP:10.0.100.100:43612, Command:sh logg buff 4 %Apr 23 13:17:05 2013 <critical> DEFAULT[zIMI]:Type:Telnet, User:megahertz, IP:10.0.100.100:43612, Command:sh logg buff 3 %Apr 23 13:17:01 2013 <critical> DEFAULT[zIMI]:Type:Telnet, User:megahertz, IP:10.0.100.100:43612, Command:sh logg buff 2 %Apr 23 13:16:56 2013 <critical> DEFAULT[zIMI]:Type:Telnet, User:megahertz, IP:10.0.100.100:43612, Command:show logging executed-commands state 1 %Apr 23 13:16:46 2013 <critical> DEFAULT[zIMI]:Type:Telnet, User:megahertz, IP:10.0.100.100:43612, Command:clear logging sdram Вообще идеально было бы свернуть лог команд в TACACS. Авторизация работает, все в порядке. А вот аккаунтинг не нашел как, да и можно ли? Вставить ник Quote
