В сети работает функция Opt.82, IPTV через мультикаст. Вообщем пример конфига свича ниже. Что можно добавить, может приоретезировать мультикаст IPTV, может ещё что то добавить для ускорения выдачи IP
SNR-S2960-24G
service password-encryption
hostname r2d2
sysLocation CORUSCANT
sysContact xxx@yyy.ru
username admin2 privilege 15 password 7 sdrhasdrhsdfhsdrh62
username admin privilege 15 password 7 sdrtyhsdrhsdfrhsdrhsdrh
clock timezone MSK add 4 0
logging 91.2XX.XX.XX facility local7 level debugging
no ip http server
service dhcp
ip dhcp snooping enable
ip dhcp snooping vlan XX
ip dhcp snooping binding enable
ip dhcp snooping information enable
ip dhcp snooping information option subscriber-id format hex
ip dhcp snooping information option self-defined subscriber-id format hex
ip dhcp snooping information option self-defined remote-id format hex
spanning-tree
spanning-tree mode rstp
loopback-detection interval-time 5 2
loopback-detection control-recovery timeout 1
loopback-detection trap enable
vlan 1
vlan XX
name Clients
vlan ZZ
name Management
vlan XXX
name iptv
multicast-vlan
multicast-vlan association XX
interface ethernet1/1
switchport access vlan XX
loopback-detection specified-vlan XX
ip dhcp snooping binding user-control
ip dhcp snooping action shutdown recovery 10
ОДИНАКОВО ДЛЯ ВСЕХ ПОРТОВ
interface ethernet1/24
interface ethernet1/25
switchport mode trunk
switchport trunk allowed vlan XX;ZZ;XXX
ip dhcp snooping trust
interface ethernet1/26
interface ethernet1/27
interface ethernet1/28
interface VlanZZ
description -= Management =-
ip address 192.168.XX.XX 255.255.255.0
ip igmp snooping
ip igmp snooping vlan XXX
ip default-gateway 192.168.XX.XX
ntp enable
ntp server 91.2XX.XX.XX
no login
end
Edited by mefer
anti-arpscan enable
multicast destination-control
на аплинках: anti-arpscan trust supertrust-port
на клиентских портах:
no spanning-tree
igmp snooping drop query
Edited by namake
