Здравствуйте.
Помогите с практикой поднятия пппое сервера на джуне (мой случай М320).
По примеру отсюда http://www.juniper.net/techpubs/software/junos/junos93/swconfig-network-interfaces/example-configuring-a-pppoe-server-interface-on-an-m120-router.html
не получается :(
Вот что видно:
borys@M320> show interfaces ge-1/0/0
Physical interface: ge-1/0/0, Enabled, Physical link is Up
 Interface index: 130, SNMP ifIndex: 585
 Link-level type: Ethernet, MTU: 1514, Speed: 1000mbps, BPDU Error: None, MAC-R
 Device flags   : Present Running
 Interface flags: SNMP-Traps Internal: 0x4000
 Link flags     : None
 CoS queues     : 8 supported, 8 maximum usable queues
 Current address: хх:хх:хх:хх:хх:хх, Hardware address: хх:хх:хх:хх:хх:хх
 Last flapped   : 2013-04-01 17:42:50 UTC (00:55:50 ago)
 Input rate     : 0 bps (0 pps)
 Output rate    : 0 bps (0 pps)
 Active alarms  : None
 Active defects : None
 Logical interface ge-1/0/0.0 (Index 70) (SNMP ifIndex 593)
   Flags: SNMP-Traps Encapsulation: PPP-over-Ethernet
   Input packets : 57
   Output packets: 0
   Protocol multiservice, MTU: Unlimited
     Flags: Is-Primary
borys@M320>
borys@M320>
borys@M320> show interfaces pp0
Physical interface: pp0, Enabled, Physical link is Up
 Interface index: 128, SNMP ifIndex: 501
 Type: PPPoE, Link-level type: PPPoE, MTU: 1532
 Interface flags: Point-To-Point SNMP-Traps
 Link type      : Full-Duplex
 Link flags     : None
 Logical interface pp0.0 (Index 73) (SNMP ifIndex 594)
   Flags: Hardware-Down Point-To-Point SNMP-Traps 0x4000 Encapsulation: PPPoE
   PPPoE:
     State: SessionDown, Session ID: None,
     Underlying interface: ge-1/0/0.0 (Index 70)
   Input packets : 0
   Output packets: 0
 Keepalive settings: Interval 10 seconds, Up-count 1, Down-count 3
 Keepalive: Input: 0 (never), Output: 0 (never)
 LCP state: Not-configured
 NCP state: inet: Not-configured, inet6: Not-configured, iso: Not-configured, m                                                  pls:
 Not-configured
 CHAP state: Closed
 PAP state: Closed
borys@M320>
borys@M320>
borys@M320> show pppoe statistics
Active PPPoE sessions: 0
 PacketType                       Sent         Received
   PADI                              0                0
   PADO                              0                0
   PADR                              0                0
   PADS                              0                0
   PADT                              0                0
   Service name error                0                0
   AC system error                   0                0
   Generic error                     0                0
   Malformed packets                 0                0
   Unknown packets                   0                0
borys@M320>
