G@riK Posted March 28, 2013 Posted March 28, 2013 День добрый. Есть GSM-шлюз Addpac GS1001a и Asterisk 1.8. При звонке на шлюз звонок редиректится на внутренний экстеншен. Далее нужно ввести доп.номер. И вот тут происходит задвоение части сигналов DTMF. Конфиг AddPac: ! ! APOS(tm) configuration saved from vty ! 2013/03/27 12:33:53 ! version 8.51.002 ! hostname GS1001 clock timezone MSK 4 ! username root password router administrator username guest password guest user ! ! script ntpdate default resynchronize 12 0 server ip 192.168.0.1 ! interface Loopback0 ip address 127.0.0.1 255.0.0.0 ! interface FastEthernet0/0 ip address 192.168.0.222 255.255.255.0 ip nat outside speed auto no qos-control ! interface FastEthernet0/1 ip address 192.168.10.1 255.255.255.0 ip nat inside speed auto no qos-control ! ip route 0.0.0.0 0.0.0.0 192.168.0.254 10 ! ! ! ! http server ! dns name-server 8.8.8.8 dns name-server 8.8.4.4 logging command logging event 4-warning logging on ! ! ! ! ! VoIP configuration. ! ! ! Voice service voip configuration. ! voice service voip protocol sip dtmf-relay rfc-2833 fax protocol t38 redundancy 0 fax rate 9600 h323 call start fast h323 call tunnel enable no call-barring unconfigured-ip-address no voip-inbound-call-barring enable ! ! ! Voice port configuration. ! ! GSM voice-port 0/0 connection plar 777 caller-id enable ! ! ! ! ! service port group configuration. ! ! ! ! Pots peer configuration. ! dial-peer voice 1 pots destination-pattern 9 port 0/0 user-password sip123 ! ! ! ! Voip peer configuration. ! dial-peer voice 0 voip destination-pattern 777 session target sip-server session protocol sip no vad dtmf-relay rtp-2833 ! ! ! ! ! ! gatekeeper ! ! ! Gateway configuration. ! gateway h323-id voip.192.168.0.222 no ignore-msg-from-other-gk ! ! ! Codec classes configuration. ! voice class codec 0 ! ! ! ! SIP UA configuration. ! sip-ua sip-server SIP_SERVER 5060 126 register e164 ! ! ! Tones ! ! ! ! line console ! line vty ! gsm dev-restart-by-unreg 300 ! gsm 0/0 sms-language utf8 ! На шлюзе и на АТС dtmfmode установлен rfc2833. Пробовал на Addpac "играться" с dtmfmode (совместно с астрериском). Гарантированно правильные символы на АТС передаются только при rfc-2833, но задвоения есть. Пробовал убирать/включать echo-cancellation, изменять параметры input/output gain - положительных результатов нет. Может кто сталкивался с таким и может помочь решить данную проблему? Вставить ник Quote
Morze Posted March 29, 2013 Posted March 29, 2013 (edited) dial-peer voice 0 voip ........ dtmf-relay rtp-2833 Может таки rfc ? =) Edited March 29, 2013 by Morze Вставить ник Quote
bos9 Posted March 29, 2013 Posted March 29, 2013 dial-peer voice 0 voip ........ dtmf-relay rtp-2833 Может таки rfc ? =) rtp-2833 DTMF relay by RTP payload defined by RFC 2833 Гарантированно правильные символы на АТС передаются только при rfc-2833, но задвоения есть. Пробовал убирать/включать echo-cancellation, изменять параметры input/output gain - положительных результатов нет. Может кто сталкивался с таким и может помочь решить данную проблему? встречал такое, но это был косяк конкретного аппарата. у вас ситуация повторяется на разных линиях/аппаратах ? Вставить ник Quote
Morze Posted March 29, 2013 Posted March 29, 2013 rtp-2833 DTMF relay by RTP payload defined by RFC 2833 Блин, действительно, чтото я стал подзабывать адпак. встречал такое, но это был косяк конкретного аппарата. Если точнее, линейки аппаратов панасоник, 23хх помоему. Вставить ник Quote
G@riK Posted April 1, 2013 Author Posted April 1, 2013 встречал такое, но это был косяк конкретного аппарата. у вас ситуация повторяется на разных линиях/аппаратах ? Есть addpac и АТС. Звонить на addpac пробовали с разным мобильников - ситуация одинакова. Вставить ник Quote
