sartul Posted March 25, 2013 Posted March 25, 2013 Задача: 1)настроить Dynamic CLIPS с локальным DHCP сервером на SE600, 2) поднять на SE600 NAT, 3) терменировать абонентов через qinq. Пока не удается даже получить ip адреса с SE600 Вот конфиг SE600: context SHPD ! no ip domain-lookup ! interface CLIPS ip address 192.168.100.1/22 no logging console ! ! ! dhcp server policy subnet 192.168.100.0/22 range 192.168.100.2 192.168.103.254 option router 192.168.100.1 port ethernet 1/1 no shutdown encapsulation dot1q dot1q pvc 589 bind interface CLIPS SHPD из статистики видно что DHCP Discover приходят. [local]Redback(config)#sho dhcp ser stats Current time: Mon Mar 25 02:56:40 2013 Last cleared: Never Packets Received : 20 Packets Sent : 0 Packet received----------------------------------------------------- DHCP Discover : 8 DHCP Request : 0 DHCP Release : 0 DHCP Decline : 0 Packet Sent--------------------------------------------------------- DHCP Offer : 0 DHCP Ack : 0 DHCP Nack : 0 BOOTP Request : 0 BOOTP Reply : 0 Tx client error : 0 ------------------------------------------------------------------- Dropped packets----------------------------------------------------- Bad Ack : 0 Internal Error : 0 Bad Length : 0 Bad Circuit : 0 Bad Circuit UP : 0 Bad Circuit Kern : 0 Bad Circuit EOF : 0 Bad Circuit slot : 0 Bad Context : 0 Bad Server IP : 0 No Server : 0 No Interface : 0 Unbound Circuit : 0 Disabled Interface : 0 Bad options received : 0 Max Hops Error : 0 Bad IP : 0 Unknown Packet Type : 0 Dropped Discover : 0 Dropped Request : 0 Dropped Release : 0 max-addr dropped : 0 Lease awaiting delete : 0 EP Down : 0 Reply pkt create err : 0 Bad reply options : 0 non-clips mac : 0 Invalid mac-addr : 0 MAC entry not found : 0 Dup cct-cfg entry : 0 Mismatch ip/mac : 0 No renewal marked : 0 Dropped invalid server: 0 Bcast/Mcast mac : 0 Context not found : 0 Interface not found : 0 Circuit not found : 0 Request entry not found: 0 Drop dup disc/del req : 0 Drop dup discover : 0 Throttle dropped disc : 0 Timers------------------------------------------------------------- IP addr req timeouts : 0 Del Req : 8 Lease timer exp : 0 cfg lease exp : 0 Timer started : 0 Timer start failed : 0 Timer stopped : 8 IP addr req wait time : 0 IP addr req exp time : 0 Input pack Q full (packet drops):: 0 Input pack Q (enqueued) count:: 20 Input pack Q (dequeued) count:: 20 Recovery Signalled count:: 1 Packet Receive Blocked count:: 1 Packet Processing Blocked count:: 0 Вставить ник Quote
dmg Posted March 25, 2013 Posted March 25, 2013 Попросите лучше доступ в http://forum.nag.ru/forum/index.php?showforum=45 (если нет). И вопросы по SE там задвать. Вставить ник Quote
sartul Posted March 26, 2013 Author Posted March 26, 2013 Попросите лучше доступ в http://forum.nag.ru/forum/index.php?showforum=45 (если нет). И вопросы по SE там задвать. ссылка не работает. наверное имелась ввиду группа обладателей redback? Просил туда доступ, ответа не было. Может не так просил. Что нужно чтобы получить доступ в группу? Вставить ник Quote
