Добрый день, на нашем с150 в логах периодически пишутся такие вот сообщения:
Mar 20 20:04:30: %E48PB:0 %FIB6-6-FIB_CAM_FULL: FIB:0, IPv4 FIB CAM is full on linecard 0
Mar 20 20:04:30: %E48TB:3 %FIB6-6-FIB_CAM_FULL: FIB:3, IPv4 FIB CAM is full on linecard 3
Mar 20 20:04:00: %E48PB:0 %FIB6-6-FIB_CAM_FULL: FIB:0, IPv4 FIB CAM is full on linecard 0
Mar 20 20:04:00: %E48PB:0 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.114.56 into the hardware due to hash failure
Mar 20 20:04:00: %E48PB:0 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.181.44 into the hardware due to hash failure
Mar 20 20:04:00: %E48PB:0 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.106.207 into the hardware due to hash failure
Mar 20 20:04:00: %E48TB:3 %FIB6-6-FIB_CAM_FULL: FIB:3, IPv4 FIB CAM is full on linecard 3
Mar 20 20:04:00: %E48PB:0 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.128.143 into the hardware due to hash failure
Mar 20 20:04:00: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.122.72 into the hardware due to hash failure
Mar 20 20:04:00: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.189.207 into the hardware due to hash failure
Mar 20 20:04:00: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.111.47 into the hardware due to hash failure
Mar 20 20:03:59: %E48PB:0 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.181.65 into the hardware due to hash failure
Mar 20 20:03:59: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.178.44 into the hardware due to hash failure
Mar 20 20:03:59: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.177.63 into the hardware due to hash failure
Mar 20 20:03:59: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.122.91 into the hardware due to hash failure
При этом периодически на L3 возникают задержки по пингам до 1000 мс.
Причем происходит это хаотично. Один и тот же адрес с разных адресов может пинговаться по разному - с одного меньше 1 мс, а с другого 1000...
Может кто-то с таким встречался? В данное время залит FTOS 8.4.2.6. Может у кого-то есть 8.4.2.7?
а сколько всего маршрутов в FIB ? по сообщением FIB переполнено, - на с150 всего 12 000 ipv4.
если логи не врут то ничего удивительного в задержках нет.
Сейчас получается вот так:
krd-core#show ip fib linecard 0 summary
Total Number of Routes in the FIB database is 4101
Total Number of Routes in the CAM is 4073
Total Number of Routes which can be entered in CAM is 16383
IPC Messages Received from RTM 7940
[Add route requests 4768; Delete Route requests 2130]
[Clear Route requests 1]
IPC Messages Received from ARPM 340432
Section Current Use
32 3969
29 1
24 129
Пока переполнения не наблидается, но вчера в моменты переполнения, маршрутов было около 5000.
Сейчас в консоль постоянно валятся такие сообщения:
Mar 21 10:09:19: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.101.246 into the hardware due to hash failure
Mar 21 10:09:19: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.106.33 into the hardware due to hash failure
Mar 21 10:09:19: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.101.215 into the hardware due to hash failure
Mar 21 10:09:19: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.124.25 into the hardware due to hash failure
Mar 21 10:09:19: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.101.30 into the hardware due to hash failure
Mar 21 10:09:19: %E48TB:2 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.168.140 into the hardware due to hash failure
Mar 21 10:09:18: %E48PB:0 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.102.28 into the hardware due to hash failure
Mar 21 10:09:18: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.168.140 into the hardware due to hash failure
Mar 21 10:09:18: %E48TB:2 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.162.27 into the hardware due to hash failure
Mar 21 10:09:18: %E48PB:1 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.132.196 into the hardware due to hash failure
Mar 21 10:09:18: %E48PB:0 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.205.23 into the hardware due to hash failure
Mar 21 10:09:18: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.162.27 into the hardware due to hash failure
Mar 21 10:09:18: %E48PB:0 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.111.27 into the hardware due to hash failure
Mar 21 10:09:18: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.164.59 into the hardware due to hash failure
Mar 21 10:09:18: %E48PB:0 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.132.196 into the hardware due to hash failure
Mar 21 10:09:17: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.189.162 into the hardware due to hash failure
Mar 21 10:09:17: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.168.148 into the hardware due to hash failure
Mar 21 10:09:17: %E48TB:2 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.164.59 into the hardware due to hash failure
Mar 21 10:09:17: %E48TB:2 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.189.162 into the hardware due to hash failure
Mar 21 10:09:17: %E48TB:2 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.168.148 into the hardware due to hash failure
Mar 21 10:09:17: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.183.46 into the hardware due to hash failure
Mar 21 10:09:17: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.108.72 into the hardware due to hash failure
Mar 21 10:09:17: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.189.149 into the hardware due to hash failure
Mar 21 10:09:17: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.124.28 into the hardware due to hash failure
Mar 21 10:09:16: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.101.193 into the hardware due to hash failure
Mar 21 10:09:16: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.183.27 into the hardware due to hash failure
Mar 21 10:09:16: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.108.114 into the hardware due to hash failure
Mar 21 10:09:16: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.180.96 into the hardware due to hash failure
Mar 21 10:09:16: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.101.201 into the hardware due to hash failure
Mar 21 10:09:16: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.111.98 into the hardware due to hash failure
Mar 21 10:09:16: %E48TB:3 %FIB6-2-FIB6_HASH_FAIL: Couldn't write IP 10.160.124.49 into the hardware due to hash failure
Откатил FTOS до 7.8.1.0, будем перезагружать ночью, посмотрим что получится...
А вот еще интересная вещь. Окуда цифра initial size 4480 в 32 префиксах? И как ее изменить?
krd-core#show ip cam linecard 0 port-set 0 summary
Total number of CAM entries = 16384
Number of CAM entries used by ARP entries = 3848
Number of CAM entries used by Prefix entries = 262
Section Current Use Initial Size
32 3978 4480
31 0 372
30 0 372
29 1 372
28 0 372
27 0 372
26 0 372
25 0 372
24 129 372
23 0 372
22 0 372
21 0 372
20 0 372
19 0 372
18 0 372
17 0 372
16 2 372
15 0 372
14 0 372
13 0 372
12 0 372
11 0 372
10 0 372
9 0 372
8 0 372
7 0 372
6 0 372
5 0 372
4 0 372
3 0 372
2 0 372
1 0 372
0 0 372
Edited by snn
tcam с150 как и в других l3 свичах память на расхват - т.е это и ipv4 роуты, мас таблица и ACL or QOS и все таки она скорее всего переполняется. что еще есть на свиче ? я так вижу на нем достаточно много серых сетей /24 и как следствия не маленькие mac таблицы. Кстати не нашел по C150 есть ли у него templates по настройке использования tcam - типа что, кому, сколько.
меня больше вот это смущает
потому как переполнения конкретно FIB таки нету - но tcam кончается.
Свич выполняет роль ядра в сети с ~8K абонентов. Покупался на замену устаревшему Extreme BD6800. На нем работает маршрутизация между вланами с серыми сетями и pim с мультикастом. Вланы сведены на брасы с pppoe. И больше по сути ничего нет. Все было хорошо, пока не перенесли на него всю маршрутизацию. Теперь, вот и не знаю что с ним делать... Можно вынести с него маршрутизацию на отдельную железку, но это как-то не правильно... Можно конечно попытаться его вернуть и взять что-то типа cisco 6500, но старье тоже брать не охота... В общем хорошая железка, но с Л3 беда... Переназначение памяти есть, но какое-то странное. Есть всего 13 блоков и эти блоки распределяются между функционалом. По умолчанию так:
-- Line card 0 --
          Current Settings(in block sizes)  Next Boot(in block sizes)
L2Acl      :         6                                      5
Ipv4Acl    :         5                                      6
Ipv6Acl    :         0                                      0
Ipv4Qos    :         1                                      1
L2Qos      :         1                                      1
В колонке Next Boot мои изменеия. Ночью перезагрузим и посмотрим, что получится. Но, что-то уже не верится, что поможет...
Edited by snn
  • 4 years later...
Добрый день,
Может кто-то объяснить чем занимается процесс aclAgent на плате (show processes cpu lp) и по каким причинам он может сильно грузить проц?
