Добрый день. Имеется партия коммутаторов Dlink DES3200-28F verC1.
Возникли сложности при настройке IPTV. вот конфиг:
# IGMP_MULTICAST_VLAN
enable igmp_snooping multicast_vlan
config igmp_snooping multicast_vlan forward_unmatched disable
create igmp_snooping multicast_vlan_group_profile 1
config igmp_snooping multicast_vlan_group_profile 1 add 239.1.0.1-239.1.0.255
create igmp_snooping multicast_vlan 411 411
config igmp_snooping multicast_vlan 411 state enable replace_source_ip 0.0.0.0
config igmp_snooping multicast_vlan 411 add member_port 1-24
config igmp_snooping multicast_vlan 411 add source_port 26
config igmp_snooping multicast_vlan_group 411 add profile_name 1
# IGMP_SNOOPING
config igmp_snooping data_driven_learning max_learned_entry 128
config igmp_snooping vlan_name default fast_leave disable report_suppression enable state disable
config igmp_snooping querier vlan_name default query_interval 125  max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping data_driven_learning vlan_name default expiry_time 260 state enable aged_out disable
config igmp_snooping vlan_name 8 fast_leave disable report_suppression enable state disable
config igmp_snooping querier vlan_name 8 query_interval 125  max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping data_driven_learning vlan_name 8 expiry_time 260 state enable aged_out disable
config igmp_snooping vlan_name 14 fast_leave disable report_suppression enable state disable
config igmp_snooping querier vlan_name 14 query_interval 125  max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping data_driven_learning vlan_name 14 expiry_time 260 state enable aged_out disable
config igmp_snooping vlan_name 102 fast_leave disable report_suppression enable state disable
config igmp_snooping querier vlan_name 102 query_interval 125  max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping data_driven_learning vlan_name 102 expiry_time 260 state enable aged_out disable
config igmp_snooping vlan_name 411 fast_leave enable report_suppression enable
config igmp_snooping querier vlan_name 411 query_interval 125  max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 2
config igmp_snooping data_driven_learning vlan_name 411 expiry_time 260 state enable aged_out disable
config cpu_filter l3_control_pkt 1-28 all state disable
После настройки коммутатора происходит подключение к потоку, потом он отваливается по таймауту, т.к. не проходят Query и не продливается подписка. С аналогичными настройками на verA1 всё работало.
This topic is now closed to further replies.
