Подскажите это адекватный результат для PPPoE-сервера (FreeBSD8) на Core i7?
Руководство требует еще...
PPPoE3# netstat -hdw 1 -i
           input        (Total)           output
  packets  errs idrops      bytes    packets  errs      bytes colls drops
     496k     0     0       390M       528k     0       476M     0     0
     496k     0     0       386M       528k     0       474M     0     0
     487k     0     0       378M       515k     0       458M     0     0
     485k     0     0       377M       516k     0       468M     0     0
     476k     0     0       366M       506k     0       450M     0     0
     491k     0     0       379M       525k     0       476M     0     0
     496k     0     0       383M       533k     0       487M     0     0
     496k     0     0       382M       532k     0       488M     0     0
     496k     0     0       380M       531k     0       481M     0     0
     505k     0     0       389M       539k     0       488M     0     0
     473k     0     0       366M       505k     0       453M     0     0
     469k     0     0       361M       499k     0       450M     0     0
     473k     0     0       364M       509k     0       463M     0     0
     494k     0     0       381M       530k     0       485M     0     0
     518k     0     0       400M       556k     0       509M     0     0
     518k     0     0       402M       553k     0       512M     0     0
     493k     0     0       376M       530k     0       481M     0     0
     494k     0     0       382M       525k     0       476M     0     0
     126k     0     0       -38M       318k     0       448M     0     0
     488k     0     0       378M       520k     0       471M     0     0
     486k     0     0       380M       518k     0       469M     0     0
last pid:  8464;  load averages:  1.08,  1.10,  1.18                                  up 22+10:31:17  23:41:29
73 processes:  7 running, 51 sleeping, 15 waiting
CPU 0:  0.8% user,  0.0% nice, 28.9% system,  0.0% interrupt, 70.3% idle
CPU 1:  0.4% user,  0.0% nice, 42.5% system,  0.8% interrupt, 56.4% idle
CPU 2:  0.0% user,  0.0% nice, 29.3% system,  0.8% interrupt, 69.9% idle
CPU 3:  0.4% user,  0.0% nice, 34.6% system,  0.8% interrupt, 64.3% idle
Mem: 101M Active, 181M Inact, 559M Wired, 418M Buf, 3111M Free
Swap: 4096M Total, 4096M Free
 PID USERNAME PRI NICE   SIZE    RES STATE   C   TIME   WCPU COMMAND
  10 root     171 ki31     0K    64K RUN     0 353.3H 74.46% idle{idle: cpu0}
  10 root     171 ki31     0K    64K RUN     3 395.6H 73.58% idle{idle: cpu3}
  10 root     171 ki31     0K    64K RUN     2 374.3H 70.56% idle{idle: cpu2}
  10 root     171 ki31     0K    64K CPU1    1 384.6H 66.80% idle{idle: cpu1}
   0 root     -68    0     0K   240K -       1 128.4H 33.59% kernel{em2 que}
   0 root     -68    0     0K   240K -       1 133.8H 30.66% kernel{em1 que}
   0 root     -68    0     0K   240K CPU3    3 128.0H 29.98% kernel{em0 que}
   0 root     -68    0     0K   240K -       2 141.9H 29.20% kernel{em3 que}
em0@pci0:1:0:0: class=0x020000 card=0x115e8086 chip=0x105e8086 rev=0x06 hdr=0x00
   vendor     = 'Intel Corporation'
   device     = 'HP NC360T PCIe DP Gigabit Server Adapter (n1e5132)'
   class      = network
   subclass   = ethernet
em1@pci0:1:0:1: class=0x020000 card=0x115e8086 chip=0x105e8086 rev=0x06 hdr=0x00
   class      = network
   subclass   = ethernet
em2@pci0:2:0:0: class=0x020000 card=0x115e8086 chip=0x105e8086 rev=0x06 hdr=0x00
   class      = network
   subclass   = ethernet
em3@pci0:2:0:1: class=0x020000 card=0x115e8086 chip=0x105e8086 rev=0x06 hdr=0x00
   class      = network
   subclass   = ethernet
Feb  5 13:10:17 <kern.crit> PPPoE3 kernel: FreeBSD 8.3-RELEASE-p3 #9: Fri Jul 13 11:52:39 MSK 2012
Feb  5 13:10:17 <kern.crit> PPPoE3 kernel: root@PPPoE3:/usr/obj/usr/src/sys/PPPoE amd64
Feb  5 13:10:17 <kern.crit> PPPoE3 kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Feb  5 13:10:17 <kern.crit> PPPoE3 kernel: CPU: Intel(R) Core(TM) i7 CPU         950  @ 3.07GHz (3103.59-MHz K8-class CPU)
Feb  5 13:10:17 <kern.crit> PPPoE3 kernel: Origin = "GenuineIntel"  Id = 0x106a5  Family = 6  Model = 1a  Stepping = 5
Feb  5 13:10:17 <kern.crit> PPPoE3 kernel: Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Feb  5 13:10:17 <kern.crit> PPPoE3 kernel: Features2=0x98e3bd<SSE3,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,SSE4.1,SSE4.2,POPCNT>
