alcool Posted February 12, 2013 Posted February 12, 2013 AS5400 8E1 В состав входит: - шасси с 2хAC блоком питания. - 1x 8PRI 8E1 Trunk Card - 2x NP108 Universal Port Card - 1x NP60 Universal Port Card кабель каберль CISCO DFC-OCTAL (новый) Router#show version Cisco Internetwork Operating System Software IOS (tm) 5400 Software (C5400-IS-M), Experimental Version 12.2(20040202:193349) [biraja-qwest_feb2 100] Copyright (c) 1986-2004 by cisco Systems, Inc. Compiled Mon 02-Feb-04 12:03 by biraja Image text-base: 0x600089C8, data-base: 0x61200000 ROM: System Bootstrap, Version 12.2(1r)1, RELEASE SOFTWARE (fc1) BOOTLDR: 5400 Software (C5400-BOOT-M), Version 12.1(1)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2) Router uptime is 5 minutes System returned to ROM by power-on System image file is "flash:c5400-is-mz.XB10.qwest" cisco AS5400 (R7K) processor (revision T) with 524288K/131072K bytes of memory. Processor board ID JAE09075YK2 R7000 CPU at 250Mhz, Implementation 39, Rev 1.0, 256KB L2, 2048KB L3 Cache Last reset from power-on Channelized E1, Version 1.0. Bridging software. X.25 software, Version 3.0.0. SuperLAT software (copyright 1990 by Meridian Technology Corp). Primary Rate ISDN software, Version 1.1. Manufacture Cookie Info: EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x31, Board Hardware Version 3.34, Item Number 800-5171-02, Board Revision C0, Serial Number JAE09075YK2, PLD/ISP Version 2.2, Manufacture Date 8-Feb-2005. Processor 0x14, MAC Address 0x012801C6AAC Backplane HW Revision 1.0, Flash Type 5V 2 FastEthernet/IEEE 802.3 interface(s) 2 Serial network interface(s) 276 terminal line(s) 8 Channelized E1/PRI port(s) 512K bytes of non-volatile configuration memory. 65536K bytes of processor board System flash (Read/Write) 16384K bytes of processor board Boot flash (Read/Write) Configuration register is 0x2102 Router#show hardware Cisco Internetwork Operating System Software IOS (tm) 5400 Software (C5400-IS-M), Experimental Version 12.2(20040202:193349) [biraja-qwest_feb2 100] Copyright (c) 1986-2004 by cisco Systems, Inc. Compiled Mon 02-Feb-04 12:03 by biraja Image text-base: 0x600089C8, data-base: 0x61200000 ROM: System Bootstrap, Version 12.2(1r)1, RELEASE SOFTWARE (fc1) BOOTLDR: 5400 Software (C5400-BOOT-M), Version 12.1(1)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2) Router uptime is 5 minutes System returned to ROM by power-on System image file is "flash:c5400-is-mz.XB10.qwest" cisco AS5400 (R7K) processor (revision T) with 524288K/131072K bytes of memory. Processor board ID JAE09075YK2 R7000 CPU at 250Mhz, Implementation 39, Rev 1.0, 256KB L2, 2048KB L3 Cache Last reset from power-on Channelized E1, Version 1.0. Bridging software. X.25 software, Version 3.0.0. SuperLAT software (copyright 1990 by Meridian Technology Corp). Primary Rate ISDN software, Version 1.1. Manufacture Cookie Info: EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x31, Board Hardware Version 3.34, Item Number 800-5171-02, Board Revision C0, Serial Number JAE09075YK2, PLD/ISP Version 2.2, Manufacture Date 8-Feb-2005. Processor 0x14, MAC Address 0x012801C6AAC Backplane HW Revision 1.0, Flash Type 5V 2 FastEthernet/IEEE 802.3 interface(s) 2 Serial network interface(s) 276 terminal line(s) 8 Channelized E1/PRI port(s) 512K bytes of non-volatile configuration memory. 65536K bytes of processor board System flash (Read/Write) 16384K bytes of processor board Boot flash (Read/Write) Configuration register is 0x2102 Router# 8-909-152-52-11 Александр Москва. Отправлю транспортной компанией. Вставить ник Quote
