Добрый день!
Есть линк между Сisco6509, SUP7203b, платой WS-X6502-10GE с WS-G6488 трансивером и D-Link DGS-3420-28SC.
На циске на инпут дикое количество CRC ошибок.
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  reliability 255/255, txload 62/255, rxload 79/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 10Gb/s
input flow-control is on, output flow-control is off
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:51, output never, output hang never
Last clearing of "show interface" counters 5d12h
Input queue: 0/2000/9/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 3109254000 bits/sec, 416705 packets/sec
5 minute output rate 2468828000 bits/sec, 395238 packets/sec
  192832788275 packets input, 187073323454404 bytes, 0 no buffer
  Received 12006470 broadcasts (6087653 multicasts)
  0 runts, 516 giants, 0 throttles
  420884241 input errors, 420884235 CRC, 698991989 frame, 9 overrun, 0 ignore
  0 watchdog, 0 multicast, 0 pause input
  0 input packets with dribble condition detected
  177182101822 packets output, 141612626858107 bytes, 0 underruns
  0 output errors, 0 collisions, 0 interface resets
  0 babbles, 0 late collision, 0 deferred
  0 lost carrier, 0 no carrier, 0 PAUSE output
  0 output buffer failures, 0 output buffers swapped out
sh int tenGigabitEthernet 3/1 counters errors
Port            Align-Err    FCS-Err   Xmit-Err    Rcv-Err UnderSize OutDiscards
Te3/1                   0  420907032          0  420907038         0           0
Port          Single-Col Multi-Col  Late-Col Excess-Col Carri-Sen     Runts
Giants
Te3/1                  0         0         0          0         0         0
   516
Port           SQETest-Err Deferred-Tx IntMacTx-Err IntMacRx-Err Symbol-Err
Te3/1                    0           0            0    420907032  699029340
Трафика в пиках до 6.7Gbit in / 4.31 Gbit out
Ошибок в пиках до почти 3000 в секунду, минимально 30.
Утилизация фабрики :
show platform hardware capacity fabric
Switch Fabric Resources
 Bus utilization: not supported
 Fabric utilization:     Ingress                    Egress
   Module  Chanl  Speed  rate  peak                 rate  peak
   3       0         8G   28%   92% @18:09 26Jan13   28%   62% @18:13 23Nov12
Со стороны DGS-3420 ошибок нет.
Меняли патчкорды и модуль на длинке, ситуация не изменилась.
Может быть проблема в автосогласовании, но на длинке нельзя принудительно задать 10G, только auto.
Прошу совета в чем может быть дело? Однозначно надо менять модуль на циске, или это у Длинка с буферами что-то не так и больше он не может.
Спасибо заранее!
Дело в том, что у этой карточки нестандартный interframe gap, а точнее он больше чем нужно. Поэтому при интенсивном трафике в сторону этой карты начинаются дропы =(
http://www.cisco.com/en/US/docs/ios-xml/ios/interface/command/ir-cr-book.pdf
Искать по слову gap =)
Edited by triam
Спасибо! Тобишь inter-packet gap 6502-mode мне должно помочь, или только замена модуля?
Думаю длинк не умеет менять gap. Пожтому только замена модуля. Хотя б я у поддержки длинка бы уточнил.
Спасибо! WS-X6704 подойдет?
Нужно ли покупать DFC3B к ней ?
При правильном обращении подойдет, опять же если вас WS-X6502-10GE устраивал всем кроме ошибок - вам и CFC хватит.
