Freebsd 9.1 . MPD5.6 Используем только PPPoE . Роутеры и win unix машины авторизируются без проблем. Клиент захотел PPPoE на DVR (Модель Rvi R04-LA) и не поднимает сессию
startup:
   set user admin masterkey admin
   set console self 0.0.0.0 5005
   set console open
   set web self 0.0.0.0 5006
   set web open
   set radsrv peer 172.29.0.3 masterkey
   set radsrv open
default:
   #load pptp_server
   #load l2tp_server
   load pppoe_server
pptp_server:
   #set ippool add poolvpn 172.16.1.2 172.16.254.254
   set ippool add poolvpn 192.168.0.30 192.168.254.254
   create bundle template BP
   #set iface down-script /usr/local/etc/mpd5/scripts/pg_down.sh
   set iface idle 0
   set iface enable tcpmssfix
   set iface enable proxy-arp
   #set ipcp ranges 172.16.1.1/32 ippool poolvpn
   set ipcp ranges 192.168.0.29/32 ippool poolvpn
   set ipcp no vjcomp
   #set ipcp dns 192.168.0.12
   set ipcp dns 172.30.0.14 172.30.0.13
   set bundle enable compression
   set ccp yes mppc
   set mppc yes e40
   set mppc yes e128
   set mppc yes stateless
   #log +echo +radius +rep +auth +bund +iface +link
   create link template L pptp
   #load radius
   set link enable report-mac
   set link action bundle BP
   set link disable multilink
   set link yes acfcomp protocomp
   set link no pap chap
   set link yes chap chap-msv2 chap-msv1
   set link keep-alive 30 180
   set link max-children 3000
   load radius
   set link mtu 1460
   set link enable peer-as-calling
   set pptp self  172.29.0.9
   set link enable incoming
l2tp_server
       create bundle template BL
       #set bundle disable ipv6cp
       set iface idle 0
       set ipcp no vjcomp
#       log +echo +radius +rep +auth +bund +iface +link
       create link template LL l2tp
       set link action bundle BL
       set link no pap
       set link enable chap chap-msv2 chap-msv1
       set l2tp self 172.29.0.9
       load radius
pppoe_server
   create bundle template PP
   set iface idle 0
   set ipcp no vjcomp
   set ipcp ranges 172.30.0.2/32 172.30.0.0/16
   create link template common pppoe
   load radius
   set link action bundle PP
   set link disable  pap eap chap-msv1
   set link enable chap chap-msv2 chap-md5
   #set link keep-alive 10 80
   set pppoe service "*"
#vlan290
create link template vlan290 common
set pppoe iface vlan290
radius:
   #set radius config /usr/local/etc/mpd5/radius.conf
   set radius server 172.30.0.10  genbypfhflbec 1812 1813
   set radius retries 3
   set radius timeout 10
   set radius identifier mpd
   set radius me 172.30.0.2
   set auth disable internal
   set auth enable radius-auth
   #ACCT
   set auth enable radius-acct
   set auth acct-update 120
Лог MPD
Jan 31 13:46:48 pppoe2 mpd: [vlan290-643] Accepting PPPoE connection
Jan 31 13:46:48 pppoe2 mpd: [vlan290-643] Link: OPEN event
Jan 31 13:46:48 pppoe2 mpd: [vlan290-643] LCP: Open event
Jan 31 13:46:48 pppoe2 mpd: [vlan290-643] LCP: state change Initial --> Starting
Jan 31 13:46:48 pppoe2 mpd: [vlan290-643] LCP: LayerStart
Jan 31 13:46:48 pppoe2 mpd: [vlan290-643] PPPoE: connection successful
Jan 31 13:46:48 pppoe2 mpd: [vlan290-643] Link: UP event
Jan 31 13:46:48 pppoe2 mpd: [vlan290-643] LCP: Up event
Jan 31 13:46:48 pppoe2 mpd: [vlan290-643] LCP: state change Starting --> Req-Sent
Jan 31 13:46:48 pppoe2 mpd: [vlan290-643] LCP: SendConfigReq #1
Jan 31 13:46:48 pppoe2 mpd: [vlan290-643]   PROTOCOMP
Jan 31 13:46:48 pppoe2 mpd: [vlan290-643]   MRU 1492
Jan 31 13:46:48 pppoe2 mpd: [vlan290-643]   MAGICNUM bfd580d1
Jan 31 13:46:48 pppoe2 mpd: [vlan290-643]   AUTHPROTO CHAP MSOFTv2
Jan 31 13:46:49 pppoe2 mpd: [vlan290-643] LCP: rec'd Configure Request #1 (Req-Sent)
Jan 31 13:46:49 pppoe2 mpd: [vlan290-643]   MAGICNUM 0d1a66d8
Jan 31 13:46:49 pppoe2 mpd: [vlan290-643] LCP: SendConfigAck #1
Jan 31 13:46:49 pppoe2 mpd: [vlan290-643] LCP: state change Req-Sent --> Ack-Sent
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: SendConfigReq #2
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643]   PROTOCOMP
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643]   MRU 1492
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643]   MAGICNUM bfd580d1
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643]   AUTHPROTO CHAP MSOFTv2
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: rec'd Configure Reject #2 (Ack-Sent)
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: SendConfigReq #3
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: rec'd Configure Reject #3 (Ack-Sent)
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: SendConfigReq #4
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: rec'd Configure Reject #4 (Ack-Sent)
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: SendConfigReq #5
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: rec'd Configure Reject #5 (Ack-Sent)
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: SendConfigReq #6
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: rec'd Configure Reject #6 (Ack-Sent)
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: SendConfigReq #7
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: rec'd Configure Reject #7 (Ack-Sent)
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: SendConfigReq #8
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: rec'd Configure Reject #8 (Ack-Sent)
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: SendConfigReq #9
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: rec'd Configure Reject #9 (Ack-Sent)
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: SendConfigReq #10
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: rec'd Configure Reject #10 (Ack-Sent)
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: not converging
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: parameter negotiation failed
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: state change Ack-Sent --> Stopped
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: LayerFinish
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] Link: DOWN event
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: Close event
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: state change Stopped --> Closed
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: Down event
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] LCP: state change Closed --> Initial
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] Link: SHUTDOWN event
Jan 31 13:46:50 pppoe2 mpd: [vlan290-643] Link: Shutdown
разрешите PAP
разрешал , тоже самое
А какое сообщение тогда появляется вместо
разрешите PAP
Incoming PPPoE connection request via vlan290: for service "" from 90:02:a9:89:09:85
[vlan290-3] Accepting PPPoE connection
[vlan290-3] Link: OPEN event
[vlan290-3] LCP: Open event
[vlan290-3] LCP: state change Initial --> Starting
[vlan290-3] LCP: LayerStart
[vlan290-3] PPPoE: connection successful
[vlan290-3] Link: UP event
[vlan290-3] LCP: Up event
[vlan290-3] LCP: state change Starting --> Req-Sent
[vlan290-3] LCP: SendConfigReq #1
[vlan290-3]   PROTOCOMP
[vlan290-3]   MRU 1492
[vlan290-3]   MAGICNUM bc4932e0
[vlan290-3]   AUTHPROTO CHAP MSOFTv2
[vlan290-3] LCP: rec'd Configure Request #1 (Req-Sent)
[vlan290-3]   MAGICNUM 6449e99a
[vlan290-3] LCP: SendConfigAck #1
[vlan290-3] LCP: state change Req-Sent --> Ack-Sent
[vlan290-3] LCP: SendConfigReq #2
[vlan290-3] LCP: rec'd Configure Reject #2 (Ack-Sent)
Подключилось, если только оставить разрешить только PAP
Edited by roysbike
roysbike
Что-то из логов не видно, что ваш сервер предлагает и PAP и CHAP при согласовании параметров соединения.
Выложите .pcap-файл, когда разрешён и pap и chap
roysbike
я не точно сказал. работает когда
set link no chap-msv2 chap-msv1
set link enable chap-md5
Edited by roysbike
