skyll Posted January 19, 2013 Posted January 19, 2013 Помогите плиз, не могу понять что случилось. База больше 16мбит не отдает вот экспорт wlan /interface wireless security-profiles set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \ group-ciphers=aes-ccm group-key-update=5m interim-update=0s \ management-protection=disabled management-protection-key="" mode=none \ name=default radius-eap-accounting=no radius-mac-accounting=no \ radius-mac-authentication=no radius-mac-caching=disabled \ radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \ static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\ none static-key-0="" static-key-1="" static-key-2="" static-key-3="" \ static-sta-private-algo=none static-sta-private-key="" \ static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=\ none tls-mode=no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key=\ jnjgktybt wpa2-pre-shared-key=jnjgktybt /interface wireless set 0 adaptive-noise-immunity=ap-and-client-mode allow-sharedkey=no \ antenna-gain=0 area="" arp=enabled band=5ghz-onlyn basic-rates-a/g="" \ bridge-mode=enabled channel-width=20mhz compression=no country=\ no_country_set default-ap-tx-limit=0 default-authentication=no \ default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \ disable-running-check=no disabled=no disconnect-timeout=15s distance=\ dynamic frame-lifetime=0 frequency=5825 frequency-mode=superchannel \ frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0 ht-amsdu-limit=8192 \ ht-amsdu-threshold=8192 ht-basic-mcs=\ mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=long \ ht-rxchains=0,1 ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-\ 6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-1\ 7,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" ht-txchains=0,1 \ hw-fragmentation-threshold=disabled hw-protection-mode=rts-cts \ hw-protection-threshold=0 hw-retries=5 l2mtu=2290 mac-address=\ 00:0C:58:D7:E0:37 max-station-count=2007 mode=ap-bridge mtu=1500 \ multicast-helper=default name=wlan1 noise-floor-threshold=-115 \ nv2-cell-radius=15 nv2-noise-floor-offset=default nv2-preshared-key=\ jnjgktybt nv2-qos=default nv2-queue-count=2 nv2-security=enabled \ on-fail-retry-time=100ms periodic-calibration=enabled \ periodic-calibration-interval=10 preamble-mode=both \ proprietary-extensions=post-2.9.25 radio-name="" rate-selection=advanced \ rate-set=configured scan-list=5730-5860 security-profile=default ssid=\ BS3 station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g="" \ tdma-period-size=2 tx-power-mode=default update-stats-interval=disabled \ wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 \ wds-ignore-ssid=no wds-mode=disabled wireless-protocol=nv2 wmm-support=\ disabled /interface wireless manual-tx-power-table set wlan1 manual-tx-powers="1Mbps:1,2Mbps:27,5.5Mbps:27,11Mbps:27,6Mbps:27,9Mb\ ps:27,12Mbps:27,18Mbps:27,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:1\ 7,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT\ 40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7\ :17" /interface wireless nstreme set wlan1 disable-csma=yes enable-nstreme=yes enable-polling=yes \ framer-limit=3200 framer-policy=dynamic-size /interface wireless align set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\ 00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \ frames-per-second=25 receive-all=no ssid-all=no /interface wireless sniffer set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \ multiple-channels=no only-headers=no receive-errors=no streaming-enabled=\ no streaming-max-rate=0 streaming-server=0.0.0.0 /interface wireless snooper set channel-time=200ms multiple-channels=yes receive-errors=no Вставить ник Quote
NewUse Posted January 19, 2013 Posted January 19, 2013 Уберите PPPoE и плохих клиентов. Вставить ник Quote
skyll Posted January 19, 2013 Author Posted January 19, 2013 Уберите PPPoE и плохих клиентов. РРРОЕ не причем остальные базы нормально работают но там правда нет клиентов с сигналом -75 Какой сигнал не желателен, я всегда думал что -77...-78 это еще дозволенный уровень Вставить ник Quote
NewUse Posted January 19, 2013 Posted January 19, 2013 Вопрос не в уровне сигнала, а в уровне его разброса. В идеале нужно сводить к +-1дБ Для юбнт допустимы уровни -84 и выше, при уровне шума -90 и ниже. У микротика -- своя шкала я её не помню. Вставить ник Quote
skyll Posted January 19, 2013 Author Posted January 19, 2013 есть еще одна база с плохими клиентами но тут она выдает 30мбит и разброс тоже не маленький Вставить ник Quote
skyll Posted January 19, 2013 Author Posted January 19, 2013 не совсем сектора стоят на мачте РТПЦ но в предела 40мгц никого нет Вставить ник Quote
skyll Posted January 19, 2013 Author Posted January 19, 2013 не совсем моя база 5825 лицензия 5820-5850 Вставить ник Quote
NewUse Posted January 20, 2013 Posted January 20, 2013 Ну свалите, для эксперимента на 5.9, походу, Ваш канал занят, и, если,5825 -- Ваша частота, то Вы залезли в чужой диапазон --- канал занимает 5815-5835 Вставить ник Quote
