сторона а)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 9/255, rxload 9/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is T
output flow-control is XON, input flow-control is XON
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/1549/0 (size/max/drops/flushes); Total output drops: 1399947
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 38740000 bits/sec, 7402 packets/sec
30 second output rate 38803000 bits/sec, 7175 packets/sec
2664265644 packets input, 2099081446 bytes, 0 no buffer
Received 20125110 broadcasts, 16118 runts, 0 giants, 38 throttles
160924 input errors, 139191 CRC, 0 frame, 4 overrun, 5611 ignored
0 watchdog, 0 multicast, 0 pause input
0 input packets with dribble condition detected
300795668 packets output, 139190804 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 9390 pause output
0 output buffer failures, 0 output buffers swapped out
сторона б)
MTU 1546 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 10/255, rxload 9/255
Encapsulation ARPA, loopback not set
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsuppor
Last input 00:00:50, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total outp
5 minute input rate 38762000 bits/sec, 6347 packets/sec
5 minute output rate 39254000 bits/sec, 7242 packets/sec
78011645 packets input, 56660215371 bytes, 0 no buffer
Received 10671 broadcasts (10184 multicasts)
111 runts, 0 giants, 0 throttles
111 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 10184 multicast, 10 pause input
88188476 packets output, 57613031872 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier, 0 PAUSE output
смена мту на стороне А ни к чему не приводит. в чем же проблема?
ведь если бы это была физическая проблема, ошибки быди бы с 2х сторон
Если повреждены только несколько пар (или при плохом обжиме), а не все, то ошибки вполне могут быть только на одной стороне.
Статистика ни о чем. Last clearing of "show interface" counters never. Очистите счетчики, затем сравнивайте.
