Приветствую.
Имеется кошка с кучкой route-map на SVI. Профиль tcam сейчас routing.
Собственно вопрос следующий: можно ли сменить на access и при этом не погнуть не поламать роутмапы? В смущение вводит тот факт, что на цискокоме написано:
To use PBR, you must first enable the routing template by using the sdm prefer routing global configuration command. PBR is not supported with the VLAN or default template. For more information on the SDM templates, see Chapter 8, "Configuring SDM Templates."
Лишний раз перегружать работающую под нагрузкой кошку считается кощунством.
Edited by passer
3750G-12S
#sh sdm prefer access
"aggregator access IPv4" template:
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
 number of unicast mac addresses:                  6K
 number of IPv4 IGMP groups + multicast routes:    1K
 number of IPv4 unicast routes:                    12K
   number of directly-connected IPv4 hosts:        6K
   number of indirect IPv4 routes:                 6K
 number of IPv4 policy based routing aces:         0.5K
 number of IPv4/MAC qos aces:                      1.125k
 number of IPv4/MAC security aces:                 4K
#sh sdm prefer routing
"aggregate routing" template:
 number of IPv4 unicast routes:                    20K
   number of indirect IPv4 routes:                 14K
 number of IPv4/MAC qos aces:                      0.75K
 number of IPv4/MAC security aces:                 1K
3750G-24TS
"desktop access IPv4" template:
 number of unicast mac addresses:                  4K
 number of IPv4 unicast routes:                    6K
   number of directly-connected IPv4 hosts:        4K
   number of indirect IPv4 routes:                 2K
 number of IPv4/MAC qos aces:                      0.5K
 number of IPv4/MAC security aces:                 2K
"desktop routing" template:
 number of unicast mac addresses:                  3K
 number of IPv4 unicast routes:                    11K
   number of directly-connected IPv4 hosts:        3K
   number of indirect IPv4 routes:                 8K
работать будет.
