MikeO Posted December 19, 2012 Posted December 19, 2012 при звонке на сип номер циска не передает голос в обе строны.. TCL-ы все нормально отрабатывают посоветуйте что нибудь? cisco 5350 конфиг version 12.4 no service pad service timestamps debug datetime localtime service timestamps log datetime localtime service password-encryption ! hostname KRIT-2 ! boot-start-marker boot system flash c5350-is-mz.124-18.bin no boot startup-test boot-end-marker ! logging queue-limit 100 logging buffered 10000 debugging enable secret 5 fdgdfhrtyrhgfhdfghfgh enable password 7 fdghdfghdfghdfhgdfgh ! ! ! resource-pool disable aaa new-model ! ! aaa group server radius BG-VOIP server 80.76.xxx auth-port 1812 acct-port 1813 ! aaa authorization exec bg-card group BG-VOIP aaa accounting connection bg-card start-stop group BG-VOIP ! aaa session-id common clock timezone MSK 4 spe default-firmware spe-firmware-1 spe 1/00 1/09 firmware location flash:np.0.10.7.0.spe ! no voice-fastpath enable ! ! ip cef ip name-server 8.8.8.8 ! ! no ip bootp server ip address-pool local isdn switch-type primary-5ess ! voice hunt user-busy voice call send-alert voice rtp send-recv ! voice service pots fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw ! voice service voip allow-connections h323 to sip allow-connections sip to h323 allow-connections sip to sip redirect ip2ip fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw h323 sip no call service stop ! ! ! voice class codec 3 codec preference 1 g729r8 codec preference 2 g729br8 codec preference 4 g723ar63 bytes 48 codec preference 5 g723ar53 bytes 40 codec preference 6 g726r32 codec preference 7 gsmfr codec preference 8 g711alaw codec preference 9 clear-channel codec preference 10 g726r16 codec preference 11 g711ulaw codec preference 12 g723r53 codec preference 13 g723r63 codec preference 14 g726r24 ! voice class codec 2 codec preference 8 g711alaw codec preference 9 g711ulaw ! ! ! voice class h323 1000 call start fast ! voice class h323 1001 call start slow ! voice class h323 3 h245 caps mode restricted ! ! ! ! voice class aaa 2 authentication method bg-card authorization method bg-card accounting method bg-card ! ! ! ! ! application package ru builtin:lang_package ! service bg-card tftp://80.76.xx/alania.tcl paramspace ru index 1 paramspace ru language ru paramspace ru location tftp://80.76.xx/au/ paramspace ru prefix ru ! service notebook tftp://80.76.xx/notebook.tcl ! ! ! fax interface-type fax-mail ! username root password 7 dfgsdfgsdfgsdgsdgf username cis password 7 sdgdsgfsdgfsdgsg ! ! controller E1 3/0 framing NO-CRC4 pri-group timeslots 1-31 ! controller E1 3/1 framing NO-CRC4 pri-group timeslots 1-31 ! gw-accounting aaa acct-template bg-card ! ! translation-rule 1 Rule 0 ^8 78 ANY unknown ! ! translation-rule 2 Rule 0 ........ 846xxxxx ! ! ! interface Loopback1 no ip address ! interface FastEthernet0/0 no ip address no ip mroute-cache shutdown duplex full speed 10 ! interface FastEthernet0/1 no ip address no ip mroute-cache duplex full speed 100 ! interface FastEthernet0/1.2 encapsulation dot1Q 2 ip address 80.237.xx 255.255.255.xx no ip mroute-cache ! interface FastEthernet0/1.6 encapsulation dot1Q 6 no cdp enable ! interface Serial0/0 no ip address rate-limit input access-group 102 256000 8000 8000 conform-action transmit exceed-action drop no ip mroute-cache shutdown clock rate 2000000 ! interface Serial0/1 no ip address no ip mroute-cache shutdown clock rate 2000000 ! interface Serial3/0:15 no ip address encapsulation hdlc isdn switch-type primary-net5 isdn incoming-voice modem isdn send-alerting isdn bchan-number-order ascending isdn sending-complete isdn outgoing-voice info-transfer-capability 3.1kHz-audio no cdp enable ! interface Serial3/1:15 no ip address encapsulation hdlc isdn switch-type primary-net5 isdn incoming-voice modem isdn send-alerting isdn bchan-number-order ascending isdn sending-complete isdn outgoing-voice info-transfer-capability 3.1kHz-audio no cdp enable ! interface Async1/00 no ip address encapsulation slip ........................................................... ! interface Async1/59 no ip address encapsulation slip ! interface Group-Async0 no ip address encapsulation slip no group-range ! ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 80.237.xx no ip http server ! ! ! ! radius-server attribute 44 include-in-access-req radius-server attribute 8 include-in-access-req radius-server attribute 32 include-in-access-req radius-server attribute 55 include-in-acct-req radius-server attribute nas-port format e UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU radius-server host 80.76.xx auth-port 1812 acct-port 1813 non-standard key 7 dfgdfgdfgdfgd radius-server unique-ident 34 radius-server vsa send accounting radius-server vsa send authentication ! control-plane ! ! call progress tone country russia ! ! voice-port 3/0:D disc_pi_off echo-cancel coverage 32 cptone RU timeouts call-disconnect 1 bearer-cap 3100Hz ! voice-port 3/1:D disc_pi_off echo-cancel coverage 32 cptone RU bearer-cap 3100Hz ! ! ! dial-peer voice 2 pots permission orig huntstop service bg-card voice-class aaa 2 incoming called-number T direct-inward-dial port 3/0:D ! dial-peer voice 8 voip preference 1 destination-pattern T translate-outgoing calling 1 voice-class codec 2 session target ipv4:80.237.xx dtmf-relay h245-signal fax-relay ecm disable fax rate 4800 fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback pass-through g711alaw ip qos dscp cs5 media ip qos dscp cs5 signaling clid restrict no vad ! dial-peer voice 116 voip service notebook translate-outgoing called 2 voice-class codec 2 session protocol sipv2 session target dns:sip.telphin.com:5068 session transport udp incoming called-number 0007 dtmf-relay rtp-nte no vad ! ! dial-peer no-match disconnect-cause 1 gateway timer receive-rtp 1200 ! sip-ua retry invite 3 retry response 3 retry bye 3 retry cancel 3 timers trying 1000 sip-server dns:sip.telphin.com:5068 ! ss7 mtp2-variant Bellcore 0 ss7 mtp2-variant Bellcore 1 ss7 mtp2-variant Bellcore 2 ss7 mtp2-variant Bellcore 3 ! line con 0 logging synchronous speed 115200 line aux 0 logging synchronous line vty 0 4 exec-timeout 60 0 password 7 sdfasfasfasf line vty 5 15 exec-timeout 0 0 line 1/00 1/59 modem InOut ! end Вставить ник Quote
All is not what it seems Posted December 20, 2012 Posted December 20, 2012 Задуматься не хотим, сражу пишем в интернетик? Вставить ник Quote
