fency Posted December 19, 2012 Posted December 19, 2012 Добрый день! имеем пару ASR1002, столкнулись с проблемой: есть две б\у SFp GLC-T P\N 30-1410-02, которые ASR признает за родные, Router#show hw-module subslot 0/0 transceiver 2 idprom IDPROM for transceiver GigabitEthernet0/0/2: Description = SFP optics (type 3) Transceiver Type: = GE T (26) Product Identifier (PID) = N/A Vendor Revision = C Serial Number (SN) = 00000MTC100302BN Vendor Name = CISCO-METHODE Vendor OUI (IEEE company ID) = 00.00.00 (0) CLEI code = N/A Cisco part number = N/A Device State = Enabled. Date code (yy/mm/dd) = 06/01/24 Connector type = Unknown. Encoding = 8B10B NRZ Nominal bitrate = GE (1300 Mbits/s) Minimum bit rate as % of nominal bit rate = not specified Maximum bit rate as % of nominal bit rate = not specified и есть 8 новых GLT-T P/N 30-1410-02, которые опознаются как: Router#show hw-module subslot 0/0 transceiver 3 idprom IDPROM for transceiver GigabitEthernet0/0/3: Description = SFP optics (type 3) Transceiver Type: = GE T (26) Product Identifier (PID) = N/A Vendor Revision = 1. Serial Number (SN) = CL80T16482 Vendor Name = CL Vendor OUI (IEEE company ID) = 00.00.00 (0) CLEI code = N/A Cisco part number = N/A Device State = Enabled. Date code (yy/mm/dd) = 12/10/30 Connector type = LC. Encoding = 8B10B NRZ Nominal bitrate = GE (1300 Mbits/s) Minimum bit rate as % of nominal bit rate = not specified Maximum bit rate as % of nominal bit rate = not specified вот на этих восьми поднимать линки не хочет. Что делать? может перелить со старых SFP образ на новые? или есть иной бубен?? Вставить ник Quote
