Здравствуйте !
После обновления прошивки в логах
Dec 18 02:53:02: %PPAINFRA-3-QUEUE_ERROR: 43b692ea/0000077178/219100000:01/IPPA/EU00:Attempt to e
nqueue singly linked element 0x1dc84b60 next 0xff260000 - 0007ce48 000eeb70 0007c9b4 000fe5ba 000
fe616 0014fde4 00145e0e 0014ede2 0014d080 001431e0 0014d678 000fc78a 0014d612 000ea86
Dec 18 02:53:02: %PPAINFRA-3-QUEUE_ERROR: 43b8bf7e/0000077178/219400000:01/IPPA/EU00:Attempt to e
nqueue singly linked element 0x7dc85820 next 0xece70000 - 0007ce48 000eeb70 0007c9b4 000fe5ba 000
Dec 18 02:54:51: %PPAINFRA-3-QUEUE_ERROR: b17a02a3/0000077287/299500000:01/IPPA/EU00:Attempt to e
nqueue singly linked element 0x7dc29720 next 0x0000a960 - 0007ce48 000eeb70 0007c9b4 000fe5ba 000
Dec 18 02:55:44: %PPAINFRA-3-QUEUE_ERROR: 322b4cf7/0000077339/819400000:01/IPPA/EU00:Attempt to e
nqueue singly linked element 0x5dc4a2e0 next 0xc2600000 - 0007ce48 000eeb70 0007c9b4 000fe5ba 000
и карта падает 10G
Dec 18 05:34:55: %CSM-6-CARD: card 10ge-4-port REMOVED from slot 1
Dec 18 05:34:56: %PM-1-ALERT: Process EPPA IPC SLOT 1, pid 0x81010008, is not responding.
Dec 18 05:35:05: %CSM-6-CARD: card 10ge-4-port INSERTED in slot 1
Dec 18 05:35:12: %QOS-6-INFO: qos info: PPA just reborn 0
Dec 18 05:35:12: %CSM-6-CARD: card 10ge-4-port INSERTED in slot 1 READY
Dec 18 05:35:12: %PPAINFRA-6-ISTART_INFO: 5a6c5829/0000000003/273200000:01/EPPA/EU00:Ready to rec
eive packets
Может кто сталкивался ?
в тех поддержки эриксона ничего вразумительного не говорят
Redback SE600
show version
Redback Networks SmartEdge OS Version SEOS-11.1.2.6-Release
Built by sysbuild@SWB-node19 Thu Oct 25 11:58:04 PDT 2012
Copyright © 1998-2012, Redback Networks Inc. All rights reserved.
System Bootstrap version is Mips,rev2.0.2.66
Installed minikernel version is 11.7
Router Up Time - 4 days, 9 hours 1 minute 44 secs
Edited by alexpn
решилось с прошивкой
Redback Networks SmartEdge OS Version SEOS-11.1.2.6p3-Release
Built by sysbuild@swb-node33 Fri Dec 14 13:00:17 PST 2012
Router Up Time - 4 hours 13 minutes 3 secs
Hardware detail на этот слот покажите .
Slot : 1 Type : 10ge-4-port
Serial No : F702D2211D1TV9 Hardware Rev : 02
EEPROM id/ver : 0x5a/4 Mfg Date : 27-MAY-2011
HubFpga rev : 0xd HubFpga file rev : 0xd
SpiFpga rev : 0x33 SpiFpga file rev : 0x33
IPPA memory : 2048 MB EPPA memory : 2048 MB
Voltage 1.200V : 1.206 (+1%) Voltage 1.200V : 1.201 (+0%)
Voltage 1.200V : 1.206 (+1%) Voltage 1.800V : 1.807 (+0%)
Temperature : NORMAL (40 C)
Card Status : HW initialized POD Status : Success
ODD Status : Not Available
Fail LED : Off Active LED : On
Standby LED : Invalid
Chass Entitlement : All (0x0)
Ports Entitled : All
Active Alarms : NONE
Port : 1 XFP / Media Type : LR / SM
CLEI code : RedbackApproved : No
XFP Serial No : XF96L0001
Wavelength : 1310.00[nm] Temperature : 29
TxPwrMin[dbm] : -8.00 TxPwrMax[dbm] : 0.00
RxPwrMin[dbm] : -20.00 RxPwrMax[dbm] : 0.00
Additional Features : None Power Level : Normal
Port : 2 XFP / Media Type : DWDM / SM
XFP Serial No : EMC12177394
Wavelength : 0.00 [nm] Temperature : 0
TxPwrMin[dbm] : -40.00 TxPwrMax[dbm] : 8.15
RxPwrMin[dbm] : -40.00 RxPwrMax[dbm] : 8.15
Port : 3 XFP / Media Type : LR / SM
XFP Serial No : DLXFD33008
Wavelength : 1330.00[nm] Temperature : 28
Port : 4 XFP / Media Type : LR / SM
CLEI code : IPUIANWCAA RedbackApproved : Yes
XFP Serial No : RBXF96L000
Wavelength : 1310.00[nm] Temperature : 19
даунгрейд прошивки эту проблему решает?
вопрос: где брать адекватные новые прошивки ?
к сожалению тех поддержка очень медленно реагирует на проблемы
