Всем доброго дня.
Есть проблема с блокировкой url содержащих русские буквы пример:
http://yesche.biz/index.php/topic/369-скорость-в-новосибирскезакладки,
пробовал вот так:
http://yesche.biz/index.php/topic/369-% ... %BA%D0%B8/ - DIRECT/62.76.190.84 text/html
1354899351.114 55 10.10.21.6 TCP_CLIENT_REFRESH_MISS/200 733 GET http://yesche.biz/index.php/topic/369-% ... %BA%D0%B8/ - DIRECT/62.76.190.84 text/html
Где только не пробовал и стандартный url_regex и SquidGuard и dansguardian, все пропускают.
FreeBSD 9.0-RELEASE #0:
squid-3.1.21_1:
acl manager proto cache_object
acl localhost src 127.0.0.1/32 ::1
acl to_localhost dst 127.0.0.0/8 0.0.0.0/32 ::1
acl localnet src 10.0.0.0/8 # RFC1918 possible internal network
acl localnet src 172.16.0.0/12 # RFC1918 possible internal network
acl localnet src 192.168.0.0/16 # RFC1918 possible internal network
acl localnet src fc00::/7 # RFC 4193 local private network range
acl localnet src fe80::/10 # RFC 4291 link-local (directly plugged) machines
acl net_10_10_21 src 10.10.21.0/24 # test IPoE
acl deny_sites url_regex "/usr/local/etc/squid/deny_sites.acl"
acl SSL_ports port 443
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 443 # https
acl Safe_ports port 70 # gopher
acl Safe_ports port 210 # wais
acl Safe_ports port 1025-65535 # unregistered ports
acl Safe_ports port 280 # http-mgmt
acl Safe_ports port 488 # gss-http
acl Safe_ports port 591 # filemaker
acl Safe_ports port 777 # multiling http
acl CONNECT method CONNECT
http_access allow manager localhost
http_access deny manager
http_access deny !Safe_ports
http_access deny CONNECT !SSL_ports
http_access deny deny_sites
http_access allow localnet
http_access allow localhost
http_access allow net_10_10_21
http_access deny all
visible_hostname 10.10.30.2
http_port 3128 transparent
#wccp_version 4
wccp2_router 10.10.30.1
wccp2_forwarding_method 1
wccp2_return_method 1
wccp2_service standard 0
#wccp2_service dynamic 0
wccp2_service_info 0 protocol=tcp flags=src_ip_hash priority=240 ports=80
wccp2_assignment_method 2
coredump_dir /var/squid/cache
refresh_pattern ^ftp: &n... 1440 20% 10080
refresh_pattern ^gopher: 1440 0% 1440
refresh_pattern -i (/cgi-bin/|\?) 0 0% 0
refresh_pattern . 0 20% 4320
log_fqdn on
В squidGuard просто юникодом эти урлы добавьте; у меня работает
Спасибо Wing за ответ, попробую, так можно целиком файл конвертнуть iconv в UTF-8 и порядок.
Edited by OTMOPO3OK
