serg_sk Posted November 30, 2012 Posted November 30, 2012 (edited) Приветствую. Есть проблема. Но начну с оборудования. Имеется Cisco 6509 + Sup7203B. Mod Ports Card Type Model Serial No.--- ----- -------------------------------------- ------------------ ----------- 1 1 1 port 10-Gigabit Ethernet Module WS-X6502-10GE SAD063102CJ 2 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45 SAL0605HBEM 3 16 16 port 1000mb GBIC ethernet WS-X6416-GBIC SAD05060THH 4 16 16 port 1000mb GBIC ethernet WS-X6416-GBIC SAL0540CS1A 5 2 Supervisor Engine 720 (Active) WS-SUP720-BASE SAD080403YE 6 1 1 port 10-Gigabit Ethernet Module WS-X6502-10GE SAD0617007T Mod Sub-Module Model Serial Hw Status ---- --------------------------- ------------------ ----------- ------- ------- 1 10GBASE-LR Serial 1310nm lo WS-G6488 SAD0631017B 1.1 Ok 2 Inline Power Module WS-F6K-VPWR 1.0 Ok 5 Policy Feature Card 3 WS-F6K-PFC3B SAD0914053A 2.1 Ok 5 MSFC3 Daughterboard WS-SUP720 SAD072504WS 1.5 Ok 6 10GBASE-LR Serial 1310nm lo WS-G6488 SAD0729064P 1.1 Ok System Resources PFC operating mode: PFC3B Supervisor redundancy mode: administratively sso, operationally sso Switching resources: Module Part number Series CEF mode 1 WS-X6502-10GE CEF256 CEF 2 WS-X6348-RJ-45 classic CEF 3 WS-X6416-GBIC classic CEF 4 WS-X6416-GBIC classic CEF 5 WS-SUP720-BASE supervisor CEF 6 WS-X6502-10GE CEF256 CEF Для сбора статистики для биллинга запущен netflow, который отжирает 100% TCAM. Netflow Resources TCAM utilization: Module Created Failed %Used 5 130946 0 100% ICAM utilization: Module Created Failed %Used 5 2 247451 1% Flowmasks: Mask# Type Features IPv4: 0 reserved none IPv4: 1 Intf Ful Intf NDE L3 Feature IPv4: 2 unused none IPv4: 3 reserved none IPv6: 0 reserved none IPv6: 1 unused none IPv6: 2 unused none IPv6: 3 reserved none # show mls netflow table-contention detailed Earl in Module 5Detailed Netflow CAM (TCAM and ICAM) Utilization ================================================ TCAM Utilization : 100% ICAM Utilization : 3% Netflow TCAM count : 130948 Netflow ICAM count : 4 Netflow Creation Failures : 5309 Netflow CAM aliases : 0 netflow собирает со всех юзерских вланов, + на вланах на первом модуле. 10г аплинк. Конфигурация такая: ip flow-cache timeout inactive 120 ip flow-cache timeout active 1 mls ip nat netflow-frag-l4-zero no mls acl tcam share-global mls aging fast time 16 threshold 50 mls aging long 300 mls aging normal 64 mls netflow interface mls flow ip interface-full mls nde sender version 5 mls qos mls cef error action reset Подскажите как можно разгрузить TCAM. Edited November 30, 2012 by serg_sk Вставить ник Quote
uxcr Posted December 1, 2012 Posted December 1, 2012 (edited) Манипуляции с aging редко дают результат, уменьшение таймеров вызывает опять нагрузку на проц, из-за учащения выдёргивания данных начинает проваливаться io. Может помочь, но обычно никому не нужно, сохранение только полей dst ip+dst-port. Переходите на DFC, там нетфлоу собирается на каждой карте отдельно, но и то на практике установленного dfc на обычного интернет-трафика хватает на 400мбит/с, потом те же беды. Вдвое большей ёмкостью обладают 3bxl, это означает замену супервизора тьфу, pfc, и установку соответствующих dfc. Почесав репу, в своё время забили на эти изыски, и отправили траф в span для разбора на 8-core ng_netflow. Edited December 1, 2012 by uxcr Вставить ник Quote
dignity Posted December 1, 2012 Posted December 1, 2012 только через span, мне кажется может быть даже проще заменять железку на что-то с поддержкой sflow, если Вас погрешность не смущает. Вставить ник Quote
avtomax.com.ua Posted December 1, 2012 Posted December 1, 2012 Только перешли с суп2 на суп720, так что заменить суп неу возможности. Кроме того топикстартер не сказал главное. Как поставили новый суп720б и плату с портом 10Г, циска стала падать рандомно. Вот и обратили внимание на вышеуказаную проблему, думая о том что циска падает именно из за этого. Вставить ник Quote
uxcr Posted December 2, 2012 Posted December 2, 2012 Вряд ли, есть такой же перегруженный суп720, терминирует в L2 ~7-8гбит , стоит без ребута несколько лет. А в "show platform hardware capacity" никакого криминала? Вставить ник Quote
serg_sk Posted December 3, 2012 Author Posted December 3, 2012 #show platform hardware capacity System Resources PFC operating mode: PFC3B Supervisor redundancy mode: administratively sso, operationally sso Switching resources: Module Part number Series CEF mode 1 WS-X6502-10GE CEF256 CEF 2 WS-X6348-RJ-45 classic CEF 4 WS-X6416-GBIC classic CEF 5 WS-SUP720-BASE supervisor CEF 6 WS-X6502-10GE CEF256 CEF 7 WS-X6516A-GBIC CEF256 CEF Power Resources Power supply redundancy mode: administratively redundant operationally redundant System power: 2331W, 0W (0%) inline, 1108W (48%) total allocated Powered devices: 0 total, 0 Class3, 0 Class2, 0 Class1, 0 Class0, 0 Cisco Flash/NVRAM Resources Usage: Module Device Bytes: Total Used %Used 5 SP disk0: 256540672 184492032 72% 5 SP disk1: 127840256 73547776 58% 5 SP sup-bootflash: 65536000 34933760 53% 5 SP const_nvram: 129004 30324 24% 5 SP nvram: 1964024 121557 6% 5 RP bootflash: 65536000 1558868 2% CPU Resources CPU utilization: Module 5 seconds 1 minute 5 minutes 5 RP 70% / 3% 46% 37% 5 SP 20% / 2% 27% 27% Processor memory: Module Bytes: Total Used %Used 5 RP 391739920 109179292 28% 5 SP 367044960 107497804 29% I/O memory: Module Bytes: Total Used %Used 5 RP 67108864 13902404 21% 5 SP 67108864 15705560 23% EOBC Resources Module Packets/sec Total packets Dropped packets 5 RP Rx: 56 29231731 789 Tx: 44 25099734 0 5 SP Rx: 31 26649825 235 Tx: 38 30779608 0 VLAN Resources VLANs: 4094 total, 501 VTP, 7 extended, 14 internal, 3572 free L2 Forwarding Resources MAC Table usage: Module Collisions Total Used %Used 5 0 65536 3569 5% VPN CAM usage: Total Used %Used 512 0 0% L3 Forwarding Resources FIB TCAM usage: Total Used %Used 72 bits (IPv4, MPLS, EoM) 196608 13778 7% 144 bits (IP mcast, IPv6) 32768 8 1% detail: Protocol Used %Used IPv4 13778 7% MPLS 0 0% EoM 0 0% IPv6 1 1% IPv4 mcast 4 1% IPv6 mcast 3 1% Adjacency usage: Total Used %Used 1048576 3345 1% Forwarding engine load: Module pps peak-pps peak-time 5 231063 783847 20:20:13 Ukraine Wed Nov 28 2012 Netflow Resources TCAM utilization: Module Created Failed %Used 5 130947 0 100% ICAM utilization: Module Created Failed %Used 5 3 731319 2% Flowmasks: Mask# Type Features IPv4: 0 reserved none IPv4: 1 Intf Ful Intf NDE L3 Feature IPv4: 2 unused none IPv4: 3 reserved none IPv6: 0 reserved none IPv6: 1 unused none IPv6: 2 unused none IPv6: 3 reserved none CPU Rate Limiters Resources Rate limiters: Total Used Reserved %Used Layer 3 9 4 1 44% Layer 2 5 3 3 60% ACL/QoS TCAM Resources Key: ACLent - ACL TCAM entries, ACLmsk - ACL TCAM masks, AND - ANDOR, QoSent - QoS TCAM entries, QOSmsk - QoS TCAM masks, OR - ORAND, Lbl-in - ingress label, Lbl-eg - egress label, LOUsrc - LOU source, LOUdst - LOU destination, ADJ - ACL adjacency Module ACLent ACLmsk QoSent QoSmsk Lbl-in Lbl-eg LOUsrc LOUdst AND OR ADJ 5 15% 17% 1% 1% 1% 1% 0% 0% 0% 0% 1% L3 Multicast Resources IPv4 replication mode: ingress Bi-directional PIM Designated Forwarder Table usage: 4 total, 0 (0%) used Replication capability: Module IPv4 IPv6 1 ingress - 2 ingress - 4 ingress - 5 egress - 6 ingress - 7 egress - MET table Entries: Module Total Used %Used 5 65516 6 1% QoS Policer Resources Aggregate policers: Module Total Used %Used 5 1024 1 1% Microflow policer configurations: Module Total Used %Used 5 64 1 1% Switch Fabric Resources Bus utilization: not supported Fabric utilization: Ingress Egress Module Chanl Speed rate peak rate peak 1 0 8G 9% 0% 10% 0% 5 0 20G 1% 0% 1% 0% 6 0 8G 0% 0% 0% 0% 7 0 8G 7% 0% 10% 0% Switching mode: Module Switching mode 1 crossbar 5 bus 6 crossbar 7 crossbar Interface Resources Interface drops: Module Total drops: Tx Rx Highest drop port: Tx Rx 1 0 83145 0 1 2 1133 0 6 0 4 7054 2303 2 2 5 578 2051 1 1 7 639 382 9 7 Interface buffer sizes: Module Bytes: Tx buffer Rx buffer 1 67107840 262080 2 112640 80896 4 442368 81920 6 67107840 262080 7 901120 147456 IBC Resources Module Packets/sec Total packets Dropped packets 5 RP Rx: 311 131447394 0 Tx: 87 29554480 0 5 SP Rx: 14 6450212 0 Tx: 427 189957767 0 SPAN Resources Source sessions: 16 maximum, 0 used Type Max Used Local 2(*) 0 Local-tx 14 0 RSPAN source 2(*) 0 ERSPAN source 2(*) 0 Service module 1(*) 0 OAM loopback 1(*) 0 * - shared source sessions and the total can not exceed 2 Destination sessions: 64 maximum, 0 used Type Max Used RSPAN destination 64(*) 0 ERSPAN destination 24(*) 0 * - shared destination sessions and the total can not exceed 64 Multicast LTL Resources Usage: 30656 Total, 2051 Used Вставить ник Quote
alks Posted December 3, 2012 Posted December 3, 2012 Убирайте netflow с тазика, что 6500 что 7600 серия не тянет его в больших объемах Вставить ник Quote
serg_sk Posted December 3, 2012 Author Posted December 3, 2012 И каким образом тогда собирать статистику? :) Вставить ник Quote
dignity Posted December 3, 2012 Posted December 3, 2012 SPAN на linux и там же netflow генератор и сенсор... Кстати WS-X6502-10GE - это экзотичная экзотика... Вам бы WS-x6704-10GE, и SPAN по 2м десяткам на linux. Вставить ник Quote
alks Posted December 3, 2012 Posted December 3, 2012 И каким образом тогда собирать статистику? :) ну как выше предлагали, ну или вынести на другую железку 650 760 реально быстро плохеет от netflow Вставить ник Quote
avtomax.com.ua Posted December 3, 2012 Posted December 3, 2012 У нас (serg_sk это коллега) в циске сейчас две платы по 10Г стоит. В каждой свой аплинк. Это сейчас надо ставить третью, из нее в какой то тазик с линухом... Может есть другой вариант? Да и основной вопрос это не 100% загрузка, а то что циска падает тогда когда ей захотелось. Вставить ник Quote
Ajar Posted December 26, 2012 Posted December 26, 2012 У вас циска работает неоптимально т.е. на ней почти все кроме ната , покупка 6502 модуля ситуацию не спасет . В скайпе я не писал , но вам нужно сделать планирование сети . Почти те же задачи у нас в одной домомсети делает старый древний SUP2 c массой аггрегированных портов , acl - мы убрали . Итого вам нужно принципиально вынести доступ с этой циски , оставить на ней только аггрегацию и внешнюю маршрутизацию. Доступ сделайте на обычном X86 Вставить ник Quote
