defaber Posted November 30, 2012 Posted November 30, 2012 (edited) Ребят, вопрос возможно немного глупый, но всеже! Как отменить команду: no spanning-tree vlan 18-50,112-120? conf t spanning-tree vlan 18-50,112-120 - не помогает! Необходимо включить spanning-tree. Конфиг: Building configuration... Current configuration : 5168 bytes ! version 12.1 no service pad service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname cisco-2950-24 ! enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX enable password XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX ! username defaber privilege 15 secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXXXX ip subnet-zero no ip igmp snooping ip rcmd rcp-enable ip rcmd rsh-enable ip rcmd source-interface Vlan111 ! no ip domain-lookup vtp mode transparent ! ! spanning-tree mode rapid-pvst no spanning-tree optimize bpdu transmission spanning-tree extend system-id no spanning-tree vlan 18-50,112-120 spanning-tree vlan 32 priority 24576 ! ! ! ! vlan 10-50,108-110 ! vlan 111 name cisco-private ! vlan 112-120,200-250 ! interface FastEthernet0/1 description UPLINK switchport mode trunk ! . . . . . . . . . . ! interface GigabitEthernet0/1 switchport access vlan 224 switchport mode access bandwidth 8196 storm-control broadcast level 5.00 1.00 storm-control multicast level 40.00 20.00 ! interface GigabitEthernet0/2 description UPLINK switchport mode trunk ! interface Vlan1 no ip address no ip route-cache shutdown ! interface Vlan111 ip address 172.27.0.4 255.255.255.224 no ip route-cache ! ip http server access-list 1500 permit 172.27.0.10 snmp-server community public RO 1500 ! line con 0 line vty 0 4 password XXXXXXXXXXXXXXXXX login local line vty 5 15 password XXXXXXXXXXXXXXXXX login ! ! end Edited November 30, 2012 by defaber Вставить ник Quote
nnm Posted November 30, 2012 Posted November 30, 2012 2950 поддерживает только 64 STP instance. Похоже они у Вас кончились. Может быть есть смысл задуматься о переходе на MSTP. Вставить ник Quote
defaber Posted November 30, 2012 Author Posted November 30, 2012 (edited) 2950 поддерживает только 64 STP instance. Похоже они у Вас кончились. Может быть есть смысл задуматься о переходе на MSTP. conf t spanning-tree mode mstp => о_О потеря доступа к киске. Теперь бежать на др. конец города ребутом её кормить :( Как мне её правильно перевести на MSTP чтоб не потерять? Работаю удаленно. Консольный провод практически не вариант, расположена она крайне неудобно, да и далеко :( Edited November 30, 2012 by defaber Вставить ник Quote
nnm Posted November 30, 2012 Posted November 30, 2012 Если это единственный коммутатор в сети, то нужно как минимум прочитать вот здесь: http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea11x/configuration/guide/swmstp.html, что нужно сделать перед тем как писать spanning-tree mode ... Если вокруг стаями стоят другие коммутаторы, то перед этим нужно понять, какие STP-протоколы на них сконфигурированы сейчас, прочитать вот здесь: http://www.cisco.com/en/US/tech/tk389/tk621/technologies_white_paper09186a0080094cfc.shtml о том, как они работают с MSTP, и что нужно сделать, чтобы они работали правильно. Одним словом вопрос не простой в двух предложениях не расскажешь :) Вставить ник Quote
defaber Posted November 30, 2012 Author Posted November 30, 2012 (edited) Если это единственный коммутатор в сети, то нужно как минимум прочитать вот здесь: http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea11x/configuration/guide/swmstp.html, что нужно сделать перед тем как писать spanning-tree mode ... Если вокруг стаями стоят другие коммутаторы, то перед этим нужно понять, какие STP-протоколы на них сконфигурированы сейчас, прочитать вот здесь: http://www.cisco.com/en/US/tech/tk389/tk621/technologies_white_paper09186a0080094cfc.shtml о том, как они работают с MSTP, и что нужно сделать, чтобы они работали правильно. Одним словом вопрос не простой в двух предложениях не расскажешь :) В сети 3 свитча настроенных одинаково. Я так понял что mstp и rstp протоколы несовместимы? я на др. свитче сделал: conf t spanning-tree mst configuration instance 1 vlan 20-50,100-120,200-250 name tratata revision 1 exit spanning-tree mode mst Тут я и второй свитч потерял :( он не чтоб с др. свитчами транками не обменивается, у него в пределах его самого сеть не работает. ( с третьего свитча идет конект к провайдеру и транки к обоим свитчам - боюсь его трогать ( Edited November 30, 2012 by defaber Вставить ник Quote
darkagent Posted December 1, 2012 Posted December 1, 2012 ну еще и третий добейте, чего уж там. как можно практически вслепую задействовать технологию, понимание которой отсутствует напрочь? прежде чем начинать такие телодвижения, сперва стоит почитать стандарт (хотя бы краткий обзор), почитать документацию по реализации технологии на выбранном типе оборудования, изучить подводные камни (да хотя бы поиском по нагу по словам "cisco mstp") и после этого собрать лабораторный стенд, на котором опробовать внедрение этой технологии. Только после того, как лабораторные испытания прошли успешно, и безболезненно, можно пытаться что-то делать на живой сети. Вставить ник Quote
defaber Posted December 1, 2012 Author Posted December 1, 2012 (edited) ну еще и третий добейте, чего уж там. как можно практически вслепую задействовать технологию, понимание которой отсутствует напрочь? прежде чем начинать такие телодвижения, сперва стоит почитать стандарт (хотя бы краткий обзор), почитать документацию по реализации технологии на выбранном типе оборудования, изучить подводные камни (да хотя бы поиском по нагу по словам "cisco mstp") и после этого собрать лабораторный стенд, на котором опробовать внедрение этой технологии. Только после того, как лабораторные испытания прошли успешно, и безболезненно, можно пытаться что-то делать на живой сети. Недождешся! Все проблему решил. Для тех у кого такая же задача, выкладываю порядок действий (ток под себя как надо переделайте :D) 1) Первый свитч: conf t spanning-tree mst configuration name DC1-MST revision 1 instance 1 vlan 20-50 instance 2 vlan 100-120 instance 3 vlan 200-250 spanning-tree mst 0-2 priority 8192 spanning-tree mst 3 priority 16384 2) Второй свитч: conf t spanning-tree mst configuration name DC2-MST revision 1 instance 1 vlan 20-50 instance 2 vlan 100-120 instance 3 vlan 200-250 spanning-tree mst 0-2 priority 16384 spanning-tree mst 3 priority 8192 3) Третий свитч: conf t spanning-tree mst configuration name DC3-MST revision 1 instance 1 vlan 20-50 instance 2 vlan 100-120 instance 3 vlan 200-250 spanning-tree mst 0-3 priority 32768 4) Первый свитч: spanning-tree mode mst spanning-tree vlan 18-50,112-120 5) Второй свитч: spanning-tree mode mst spanning-tree vlan 18-50,112-120 6) Третий свит: spanning-tree mode mst spanning-tree vlan 18-50,112-120 т.е. смысл прост. Стачала на ВСЕХ свитчах настраиваем MST и только потом по очереди их включаем. Во время выполнения команды spanning-tree mode mst связь теряется секунд на 15 и затем восстанавливается. Особая благодарность nnm. Тему можно закрыть. Edited December 1, 2012 by defaber Вставить ник Quote
YuryD Posted December 2, 2012 Posted December 2, 2012 А чтобы не скакать через весь город, почитать про команду reload at hh:mm, И не сохранять кривые конфиги, а просто покурить и подумать, почему отпало управление Вставить ник Quote
NikAlexAn Posted December 3, 2012 Posted December 3, 2012 name DC1-MST name DC2-MST name DC3-MST У Вас все три коммутатора в разных регионах MST - так и надо? 2950 поддерживает только pre-standart MSTP насколько помню. Вставить ник Quote
YuryD Posted December 3, 2012 Posted December 3, 2012 лучше reload in at лучше для клиентов, они подумают что что-то плановое в начале часа :) Вставить ник Quote
defaber Posted December 3, 2012 Author Posted December 3, 2012 лучше reload in Курибельно ;) Вставить ник Quote
