Подключили поток от АТС МС-240, проверяем входящие. При попытке позвонить на на номер получаем такой трейс:
Nov 29 11:13:07: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x000D
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838C
Exclusive, Channel 12
Progress Ind i = 0x8081 - Call not end-to-end ISDN, may have in-band info
Nov 29 11:13:07: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0x800D callID = 0x0047 switch = primary-net5 interface = User
Nov 29 11:13:07: ISDN Se0/0/0:15 Q931: TX -> SETUP_ACK pd = 8 callref = 0x800D
Progress Ind i = 0x8188 - In-band info or appropriate now available
Nov 29 11:13:07: ISDN Se0/0/0:15 Q931: RX <- INFORMATION pd = 8 callref = 0x000D
Called Party Number i = 0xC1, '6'
Plan:ISDN, Type:Subscriber(local)
Called Party Number i = 0xC1, '7'
Called Party Number i = 0xC1, '3'
Called Party Number i = 0xC1, '0'
Called Party Number i = 0xC1, '1'
Sending Complete
Nov 29 11:13:07: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x800D
Cause i = 0x809C - Invalid number format (incomplete number)
Nov 29 11:13:07: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x000D
Номер на который звоним 67301.
Конфиг:
isdn switch-type primary-net5
translation-rule 1
Rule 0 ^90 0
Rule 1 ^91 1
Rule 2 ^92 2
Rule 3 ^93 3
Rule 4 ^94 4
Rule 5 ^95 5
Rule 6 ^96 6
Rule 7 ^97 7
Rule 8 ^98 8
Rule 9 ^99 9
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
interface Serial0/0/0:15
no ip address
encapsulation hdlc
load-interval 30
isdn overlap-receiving
isdn incoming-voice voice
isdn calling-party-num network-provided
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
dial-peer voice 100 pots
destination-pattern 9T
translate-outgoing called 1
clid network-number 4167301
port 0/0/0:15
forward-digits all
Помогите справится с проблемой! Буду признателен ;-)
Обращались в нашу ТП с похожей проблемой при стыке МС-240 с CISCO (к сожалению не знаю модель CISCO).
При наборе overlap CISCO всегда отбивала с причиной "incomplete number".
Заработало когда на МС-240 настроили набор enblock. Попробуйте сделать так же.
п.с. а еще в логе не видать calling-номера. его действительно нет в вызове? или CISCO его просто не печатает?
п.п.с. если МС-240 под вашим управлением, то можете обратиться в ТП "ЭЛТЕКС":
тел. 8 (383) 272-83-31 доб. 3019
anna.zhadovets@eltex.nsk.ru
Edited by Bokrenok
