Доброго времени суток!
Поставили новый модуль WS-X6748-GE-TX в 6509, скроссировали с se600. На 6500 int vlan c /30, на se600 бинд на интерфейс. Пробую пинговать противоположенный адрес - потери!
cisco6500#ping
Protocol [ip]:
Target IP address: 192.168.15.130
Repeat count [5]: 20
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Type escape sequence to abort.
Sending 20, 100-byte ICMP Echos to 192.168.15.130, timeout is 2 seconds:
Success rate is 60 percent (12/20), round-trip min/avg/max = 1/1/1 ms
se600#ping
Target IP address: 192.168.15.129
ICMP datagram size [36]:
Timeout in seconds [1]:
PING 192.168.15.129 (192.168.15.129): source 192.168.15.130, 36 data bytes,
timeout is 1 second
----192.168.15.129 PING Statistics----
20 packets transmitted, 14 packets received, 30.0% packet loss
round-trip min/avg/max/stddev = 0.926/2.383/6.455/1.649 ms
На интерфейсах ошибок нет
sh int gi9/1
GigabitEthernet9/1 is up, line protocol is up (connected)
 Hardware is C6k 1000Mb 802.3, address is 0011.9370.3214 (bia 0011.9370.3214)
 Description: se600 e3/1
 MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
    reliability 255/255, txload 1/255, rxload 1/255
 Encapsulation ARPA, loopback not set
 Keepalive set (10 sec)
 Full-duplex, 1000Mb/s, media type is 10/100/1000BaseT
 input flow-control is off, output flow-control is off
 Clock mode is auto
 ARP type: ARPA, ARP Timeout 04:00:00
 Last input never, output 00:00:00, output hang never
 Last clearing of "show interface" counters 01:16:08
 Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
 Queueing strategy: fifo
 Output queue: 0/40 (size/max)
 5 minute input rate 0 bits/sec, 0 packets/sec
 5 minute output rate 0 bits/sec, 0 packets/sec
    736 packets input, 76463 bytes, 0 no buffer
    Received 490 broadcasts (411 multicasts)
    0 runts, 0 giants, 0 throttles
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
    0 watchdog, 0 multicast, 0 pause input
    0 input packets with dribble condition detected
    2545 packets output, 228374 bytes, 0 underruns
    0 output errors, 0 collisions, 0 interface resets
    0 babbles, 0 late collision, 0 deferred
    0 lost carrier, 0 no carrier, 0 PAUSE output
    0 output buffer failures, 0 output buffers swapped out
sh port counters 3/1
Port            Type
3/1             ethernet
packets sent       : 96037328           bytes sent         : 58355295128
packets recvd      : 72510137           bytes recvd        : 70258633284
send packet rate   : 0.13               send bit rate      : 98.66
recv packet rate   : 0.58               recv bit rate      : 377.57
rate refresh interval : 60 seconds
Пробовали менять пачкорды, подключать ноутбук - брас с ноутом работает нормально, пинги проходят шустро, а вот на циске потери.
В чем может быть дело? Что можно посмотреть? Или вернуть модуль поставщику?
Модуль:
Mod Ports Card Type                              Model              Serial No.
 9   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL083221CS
Mod MAC addresses                       Hw    Fw           Sw           Status
 9  0011.9370.3214 to 0011.9370.3243   2.9   12.2(14r)S5  12.2(33)SXH2 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
 9  Centralized Forwarding Card WS-F6700-CFC       SAL08290QE0  2.1    Ok
Mod  Online Diag Status
 9  Pass
Брас работает нормально, это показали опыты с ноутбуком. Затык именно в циске.
Slot                : 3                 Type                : ge4-20-port
Serial No           : F101D4409D0KWJ    Hardware Rev        : 01
EEPROM id/ver       : 0x5a/4            Mfg Date            : 14-NOV-2009
HubFpga rev         : 0xa               HubFpga file rev    : 0xf
SpiFpga rev         : 0x0               SpiFpga file rev    : N/A
IPPA memory         : 2048 MB           EPPA memory         : 2048 MB
Voltage 1.200V      : 1.196 (-0%)       Voltage 1.200V      : 1.201 (+0%)
Voltage 1.200V      : 1.201 (+0%)       Voltage 1.250V      : 1.245 (-0%)
Temperature         : NORMAL (55 C)
Card Status         : HW initialized    POD Status          : Success
ODD Status          : Not Available
Fail LED            : Off               Active LED          : On
Standby LED         : Invalid
Chass Entitlement   : All (0x0)
Ports Entitled      : All
Active Alarms       : NONE
Port                : 1                 SFP / Media Type    : T / Cat5
CLEI code           :                   RedbackApproved     : No
SFP Serial No       : AGM121823BW
Port                : 2                 SFP / Media Type    : T / Cat5
SFP Serial No       : AGM121823BL
Port                : 3                 SFP / Media Type    : T / Cat5
SFP Serial No       : MTC15240CJH
Port                : 4                 SFP / Media Type    : T / Cat5
SFP Serial No       : MTC15240CFU
Port                : 5                 SFP / Media Type    : T / Cat5
SFP Serial No       : MTC15240CDU
Port                : 6                 SFP / Media Type    : T / Cat5
SFP Serial No       : MTC15240BZY
Port                : 7                 SFP / Media Type    : T / Cat5
SFP Serial No       : MTC15240E18
Port                : 8                 SFP / Media Type    : T / Cat5
SFP Serial No       : MTC15240E6V
Port                : 9                 SFP / Media Type    : T / Cat5
SFP Serial No       : MTC15240C0M
Пере грузите FPGA на карте у вас версия не соответствует.
Уж точно не помню но толи reload FPGA то ли upgrade FPGA ну slot 3 там указать. Карта перегружаться будет.
После чего hub fpga rev и hub fpga file rev. Должны
Edited by config
