периодически умирают точки. две отдали в серис НАГ, одну умершую после вскрыл, подключился к консоли. загрузчик ar7240 говорит, что битая прошивка:
Hit any key to stop autoboot:  0
## Booting image at 9f050000 ...
  Image Name:   MIPS Ubiquiti Linux-2.6.15-5.2
  Created:      2012-10-12  21:03:38 UTC
  Image Type:   MIPS Linux Kernel Image (lzma compressed)
  Data Size:    729764 Bytes = 712.7 kB
  Load Address: 80002000
  Entry Point:  80002000
  Verifying Checksum at 0x9f050040 ...Bad Data CRC
пытался восстановить ее той же версией, версией младше и версией AirOS. Ячейка памяти, на которой всегда запинается неизменна:
ar7240> urescue
Setting default IP 192.168.1.20
Starting TFTP server...
Using eth0 (192.168.1.20), address: 0x81000000
Waiting for connection: /
Receiving file from 192.168.1.1:38442
Received 5187007 bytes
Firmware Version: BZ.ar7240.v2.2.5.1080.120224.0850
Setting U-Boot environment variables
Copying partition 'kernel' to flash memory:
       erasing range 0x9F050000..0x9F10FFFF: ............ done
Erased 12 sectors
       writing to address 0x9f050000, length 0x000c0000 ...
write addr: 9f050000
Copying partition 'rootfs' to flash memory:
       erasing range 0x9F150000..0x9F58FFFF: .................................................................... done
Erased 68 sectors
       writing to address 0x9f150000, length 0x00440000 ...
write addr: 9f150000
Firmware update complete.
Resetting...
U-Boot 1.1.4-gb387d959 (Dec  8 2011 - 10:16:49)
Board: Ubiquiti Networks AR7241 board (e512-6.0101)
DRAM:  64 MB
Flash:  8 MB
*** Warning - bad CRC, using default environment
BOARD IS NOT CALIBRATED!!!
Net:   eth0, eth1
  Created:      2012-02-24  16:55:55 UTC
  Data Size:    730087 Bytes = 713 kB
ar7240>
ar7240> urescue
Waiting for connection: -
Receiving file from 192.168.1.1:59542
Received 6670691 bytes
Firmware Version: BZ.ar7240.v5.3.7782.110301.2247
Erased 12 sectors
       erasing range 0x9F150000..0x9F6EFFFF: .......................................................................................... done
Erased 90 sectors
       writing to address 0x9f150000, length 0x005a0000 ...
Resetting...
DRAM:  64 MB
Flash:  8 MB
Net:   eth0, eth1
  Created:      2011-03-02   4:52:48 UTC
  Data Size:    771979 Bytes = 753.9 kB
ar7240>
Все это наводит на мысль, что серия точек с битой памятью идет с завода...
Многие сталкиваются с такой проблемой и не только с юнифай. Обычные наносы могут криво устанавливать прошивку, после чего картинки и интерфейс отображаются не правильно. В итоге оборудование на помойку.
Тут скорее дело в кривизне рук, и если работает -- нефига трогать.
Наносы лечились по тфтп.
Брак возможен всюду, в соседнюю ветку про тик 751 достаточно заглянуть.
Оборудование, которое стоит 100 уе не может быть абсолютно без брака.
Сейчас просчитываю вариант собственной железячки на тех же Азеросах, даже на приличных объёмах дешевле 200 никак ничего хорошего не получается (на нормальных компонентах и ВЧ фильтрами).
За эти деньги CPE ваймакса можно покупать.
Я просчитываю именно базы и именно WiFi с интегрированной 120град антенной мимо. Ввиду WiFox это может быть очень интересно, при этом софт -- OpenWRT урезанная до минимума, чтоб получить макс. производительность + Web-морда с поддержкой продвинутых настроек MadWiFi+WiFox+hostapd+Возможно, внешняя синхронизация по серверу (аналог AirSync), в будующем, и всё это дело под чистой GPL v2.
Но, да, дороговато....
