имеем 2 свича des 1210-28 и 3200-28
оба хочу завести на opt 82, 1210-28 заводится на ура с такими параметрами -
class "vlan2011_port1"
match if (
binary-to-ascii(10, 16, "",  substring(option agent.circuit-id, 4, 2)) = "1"
and substring(option agent.remote-id, 2, 15) = "10.0.104.11"
pool {
range 10.34.1.33;
allow members of "vlan2011_port1";
на этих рабьотает хорошо, а вот 3200-28 не пускает, мб у кого есть circuit-id remote-id Для них? или как расшифровать пакет?
я бы сам разобрался но в пакетах не шлется данных о opt 82
Running as user "root" and group "root". This could be dangerous.
Capturing on eth3.1999
Frame 1 (342 bytes on wire, 342 bytes captured)
   Arrival Time: Nov 13, 2012 07:06:14.331491000
   [Time delta from previous captured frame: 0.000000000 seconds]
   [Time delta from previous displayed frame: 0.000000000 seconds]
   [Time since reference or first frame: 0.000000000 seconds]
   Frame Number: 1
   Frame Length: 342 bytes
   Capture Length: 342 bytes
   [Frame is marked: False]
   [Protocols in frame: eth:ip:udp:bootp]
Ethernet II, Src: cc:b2:55:7a:6b:80 (cc:b2:55:7a:6b:80), Dst: ac:16:2d:a4:2f:75 (ac:16:2d:a4:2f:75)
   Destination: ac:16:2d:a4:2f:75 (ac:16:2d:a4:2f:75)
       Address: ac:16:2d:a4:2f:75 (ac:16:2d:a4:2f:75)
       .... ...0 .... .... .... .... = IG bit: Individual address (unicast)
       .... ..0. .... .... .... .... = LG bit: Globally unique address (factory default)
   Source: cc:b2:55:7a:6b:80 (cc:b2:55:7a:6b:80)
       Address: cc:b2:55:7a:6b:80 (cc:b2:55:7a:6b:80)
   Type: IP (0x0800)
Internet Protocol, Src: 10.0.104.15 (10.0.104.15), Dst: 10.0.104.1 (10.0.104.1)
   Version: 4
   Header length: 20 bytes
   Differentiated Services Field: 0x00 (DSCP 0x00: Default; ECN: 0x00)
       0000 00.. = Differentiated Services Codepoint: Default (0x00)
       .... ..0. = ECN-Capable Transport (ECT): 0
       .... ...0 = ECN-CE: 0
   Total Length: 328
   Identification: 0x0144 (324)
   Flags: 0x00
       0.. = Reserved bit: Not Set
       .0. = Don't fragment: Not Set
       ..0 = More fragments: Not Set
   Fragment offset: 0
   Time to live: 30
   Protocol: UDP (0x11)
   Header checksum: 0xb651 [correct]
       [Good: True]
       [bad : False]
   Source: 10.0.104.15 (10.0.104.15)
   Destination: 10.0.104.1 (10.0.104.1)
User Datagram Protocol, Src Port: bootpc (68), Dst Port: bootps (67)
   Source port: bootpc (68)
   Destination port: bootps (67)
   Length: 308
   Checksum: 0xc8da [validation disabled]
       [Good Checksum: False]
       [bad Checksum: False]
Bootstrap Protocol
   Message type: Boot Request (1)
   Hardware type: Ethernet
   Hardware address length: 6
   Hops: 1
   Transaction ID: 0xa52429e1
   Seconds elapsed: 0
   Bootp flags: 0x0000 (Unicast)
       0... .... .... .... = Broadcast flag: Unicast
       .000 0000 0000 0000 = Reserved flags: 0x0000
   Client IP address: 0.0.0.0 (0.0.0.0)
   Your (client) IP address: 0.0.0.0 (0.0.0.0)
   Next server IP address: 0.0.0.0 (0.0.0.0)
   Relay agent IP address: 10.0.104.15 (10.0.104.15)
   Client MAC address: 3c:97:0e:05:3e:68 (3c:97:0e:05:3e:68)
   Client hardware address padding: 00000000000000000000
   Server host name not given
   Boot file name not given
   Magic cookie: (OK)
   Option: (t=53,l=1) DHCP Message Type = DHCP Discover
       Option: (53) DHCP Message Type
       Length: 1
       Value: 01
   Option: (t=61,l=7) Client identifier
       Option: (61) Client identifier
       Length: 7
       Value: 013C970E053E68
   Option: (t=12,l=10) Host Name = "tel-kom-nk"
       Option: (12) Host Name
       Length: 10
       Value: 74656C2D6B6F6D2D6E6B
   Option: (t=60,l=8) Vendor class identifier = "MSFT 5.0"
       Option: (60) Vendor class identifier
       Length: 8
       Value: 4D53465420352E30
   Option: (t=55,l=12) Parameter Request List
       Option: (55) Parameter Request List
       Length: 12
       Value: 010F03062C2E2F1F2179F92B
       1 = Subnet Mask
       15 = Domain Name
       3 = Router
       6 = Domain Name Server
       44 = NetBIOS over TCP/IP Name Server
       46 = NetBIOS over TCP/IP Node Type
       47 = NetBIOS over TCP/IP Scope
       31 = Perform Router Discover
       33 = Static Route
       121 = Classless Static Route
       249 = Private/Classless Static Route (Microsoft)
       43 = Vendor-Specific Information
   End Option
   Padding
match if (
pool {
range 10.34.1.33;
У меня 3200-28 работает следующим образом:
class "10.0.1.23:p1" {
match if binary-to-ascii (10, 8, "", suffix( option agent.circuit-id, 1)) = "1"
and binary-to-ascii(10, 8, ".", packet(24, 4)) = "10.0.1.23";
pool {
range 192.168.12.5;
allow members of "10.0.1.23:p1";
