Aksel Posted November 8, 2012 Posted November 8, 2012 Имеем абонентское кольцо. Приходит на два ASR 9010. Коммутаторы доступа D-link 3526. Поднято управление (vlan 10): interface GigabitEthernet0/5/0/17.10 l2transport description MANAGEMENT RING-906 encapsulation dot1q 10 rewrite ingress tag pop 1 symmetric l2vpn bridge group RING_MGMT bridge-domain RING_906 interface GigabitEthernet0/5/0/17.10 storm-control multicast pps 1 storm-control broadcast pps 500 ! neighbor xx.xxx.xxx.111 pw-id 15906 ! routed interface BVI20906 interface BVI20906 vrf MGMT ipv4 address 10.128.35.3 255.255.255.0 router vrrp interface BVI20906 address-family ipv4 vrrp 35 priority 150 address 10.128.35.1 Поднят igmp multicast в двух вланах (30 и 31) interface GigabitEthernet0/5/0/17.30 l2transport encapsulation dot1q 30 rewrite ingress tag pop 1 symmetric mtu 1518 ipv4 access-group IPTV ingress ipv4 access-group IPTV egress ! interface GigabitEthernet0/5/0/17.31 l2transport encapsulation dot1q 31 rewrite ingress tag pop 1 symmetric mtu 1518 ipv4 access-group IPTV_MEGATV_IN ingress ipv4 access-group IPTV_MEGATV egress ! l2vpn bridge group multi bridge-domain multi igmp snooping profile customer interface GigabitEthernet0/5/0/17.30 split-horizon group l2vpn bridge group multi bridge-domain MEGATV igmp snooping profile customer_megafon interface GigabitEthernet0/5/0/17.31 split-horizon group Поднята схема vlan per switch, с терминирование на BRAS`e (pppoe). (vlan 101- 150) interface GigabitEthernet0/5/0/17.906101 l2transport encapsulation dot1q 101 rewrite ingress tag pop 1 symmetric ethernet-services access-group IPOE_IN ingress ethernet-services access-group IPOE egress ! .................. interface GigabitEthernet0/5/0/17.906150 l2transport encapsulation dot1q 150 rewrite ingress tag pop 1 symmetric ethernet-services access-group IPOE_IN ingress ethernet-services access-group IPOE egress ! l2vpn bridge group IPOE bridge-domain S-7 interface GigabitEthernet0/3/0/1.20007 storm-control multicast pps 1 storm-control broadcast pps 100 ! interface GigabitEthernet0/5/0/17.906101 storm-control multicast pps 1 storm-control broadcast pps 500 split-horizon group ..................... interface GigabitEthernet0/5/0/17.906150 storm-control multicast pps 1 storm-control broadcast pps 500 split-horizon group ! neighbor xx.xxx.xxx.103 pw-id 40007 ! neighbor xx.xxx.xxx.104 pw-id 40007 ! neighbor xx.xxx.xxx.111 pw-id 40007 ! routed interface BVI40007 Дальше идет само STP. interface GigabitEthernet0/5/0/17.999 l2transport description MSTP CTRL RING-906 encapsulation dot1q 999 ! spanning-tree mstag STP_RING_906 interface GigabitEthernet0/5/0/17.999 name STP_RING_906 revision 5 bridge-id 0000.0000.0906 instance 0 root-id 0000.0000.0906 root-priority 4096 ! Настройки на другом ASRe идентичные этим (только порты разные и все впринципе). Настройка коммутатора доступа: config stp version mstp config stp maxage 6 maxhops 20 forwarddelay 4 txholdcount 3 fbpdu enable config stp priority 32768 instance_id 0 config stp mst_config_id name STP_RING_906 revision_level 5 enable stp config stp ports 1-23 externalCost auto hellotime 2 edge true p2p auto state disable config stp ports 1-24 fbpdu disable config stp ports 1-24 restricted_role true config stp ports 1-24 restricted_tcn true config stp mst_ports 1-26 instance_id 0 internalCost auto priority 128 config stp ports 24 externalCost auto hellotime 2 edge true p2p auto state enable config stp ports 25-26 externalCost auto hellotime 2 edge false p2p auto state enable config stp ports 25-26 fbpdu enable config stp ports 25-26 restricted_role false config stp ports 25-26 restricted_tcn false И так сам вопрос. После заведения интерфейсов для STP, его конфигурирование на коммутаторах и ASR`e, оно сходится. Петли нет, абоненты работают. Все отлично. Но есть одно НО, на ASR`e !!!единоразово!!! появляется сообщение: Oct 25 22:04:49 xx.xxx.xxx.xxx 59048: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.931 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906102 and msti: 0 Oct 25 22:04:49 xx.xxx.xxx.xxx 59048: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.931 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906102 and msti: 0 Oct 25 22:04:49 xx.xxx.xxx.xxx 59049: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.932 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906103 and msti: 0 Oct 25 22:04:49 xx.xxx.xxx.xxx 59049: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.932 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906103 and msti: 0 Oct 25 22:04:49 xx.xxx.xxx.xxx 59050: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.932 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906104 and msti: 0 Oct 25 22:04:49 xx.xxx.xxx.xxx 59050: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.932 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906104 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59051: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.934 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906105 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59051: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.934 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906105 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59052: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.935 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906106 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59052: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.935 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906106 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59053: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.936 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906107 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59053: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.936 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906107 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59054: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.937 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906108 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59054: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.937 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906108 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59055: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.938 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906109 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59055: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.938 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906109 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59056: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.939 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906110 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59056: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.939 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906110 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59057: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.940 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906111 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59057: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.940 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906111 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59058: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.941 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906112 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59058: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.941 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906112 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59059: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.942 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906113 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59059: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.942 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906113 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59060: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.943 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906114 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59060: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.943 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906114 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59061: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.943 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906115 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59061: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.943 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906115 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59062: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.944 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906127 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59062: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.944 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906127 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59063: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.944 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906128 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59063: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.944 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906128 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59064: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.945 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906129 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59064: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.945 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906129 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59065: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.945 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906130 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59065: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.945 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906130 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59066: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.946 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906131 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59066: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.946 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906131 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59067: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.946 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906132 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59067: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.946 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906132 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59068: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.947 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906133 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59068: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.947 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906133 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59069: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.948 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906134 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59069: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.948 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906134 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59070: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.948 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906135 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59070: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.948 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906135 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59071: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.949 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906136 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59071: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.949 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906136 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59072: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.950 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906137 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59072: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.950 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906137 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59073: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.950 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906138 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59073: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.950 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906138 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59074: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.951 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906139 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59074: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.951 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906139 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59075: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.952 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906140 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59075: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.952 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906140 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59076: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.952 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906116 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59076: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.952 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906116 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59077: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.953 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906117 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59077: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.953 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906117 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59078: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.953 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906118 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59078: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.953 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906118 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59079: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.954 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906119 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59079: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.954 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906119 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59080: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.955 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906120 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59080: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.955 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906120 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59081: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.956 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906121 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59081: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.956 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906121 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59082: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.957 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906122 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59082: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.957 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906122 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59083: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.958 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906123 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59083: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.958 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906123 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59084: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.959 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906124 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59084: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.959 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906124 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59085: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.959 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906125 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59085: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.959 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-8 (BD ID: 7) for interface GigabitEthernet0_5_0_17.906125 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59086: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.961 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906141 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59086: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.961 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906141 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59087: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.962 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906142 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59087: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.962 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906142 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59088: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.962 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906143 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59088: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.962 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906143 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59089: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.963 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906144 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59089: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.963 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906144 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59090: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.964 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906145 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59090: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.964 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906145 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59091: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.965 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906146 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59091: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.965 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906146 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59092: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.966 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906147 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59092: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.966 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906147 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59093: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.967 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906148 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59093: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.967 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906148 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59094: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.968 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906149 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59094: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.968 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906149 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59095: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.969 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906150 and msti: 0 Oct 25 22:04:50 xx.xxx.xxx.xxx 59095: ASR9K.VES RP/0/RSP0/CPU0:Oct 25 22:04:49.969 : l2vpn_mgr[1124]: %L2-L2VPN-4-BD_MST_LOOP : Potential MST forwarding loop in Bridge Domain S-7 (BD ID: 6) for interface GigabitEthernet0_5_0_17.906150 and msti: Эти сообщения чисто информативные? Либо это самом деле что то опасное. Как тогда это лечить? Заранее спасибо за ответ. з.ы. спойлер не нашел чей-то... Вставить ник Quote
