Данные cisco
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(1)T, RELEASE SOFTWARE (fc1)
через радиус передаю атрибуты для шейпинга
lcp:interface-config#1=rate-limit input 64000 12000 24000 conform-action transmit exceed-action drop
и
lcp:interface-config#1=rate-limit output 64000 12000 24000 conform-action transmit exceed-action drop
но скорость не режется
на циске
Cisco2921#sh int vi4 rate-limit
дебаг с циски
*Oct 31 09:31:38.855: RADIUS:  Vendor, Cisco       [26]  109
*Oct 31 09:31:38.855: RADIUS:   Cisco AVpair       [1]   103 "lcp:interface-config#1=rate-limit output 64000 12000 24000 conform-action transmit exceed-action drop"
*Oct 31 09:31:38.855: RADIUS:  Framed-Compression  [13]  6   VJ TCP/IP Header Compressi[1]
*Oct 31 09:31:38.855: RADIUS:  Framed-Protocol     [7]   6   PPP                       [1]
*Oct 31 09:31:38.855: RADIUS:  Service-Type        [6]   6   Framed                    [2]
*Oct 31 09:31:38.855: RADIUS:  Vendor, Cisco       [26]  12
*Oct 31 09:31:38.855: RADIUS:  Ascend-Max-Time     [194] 6
*Oct 31 09:31:38.855: RADIUS:   00 00 0E 10
*Oct 31 09:31:38.855: RADIUS:  Unsupported         [230] 6
*Oct 31 09:31:38.855: RADIUS:   00 00 01 2C                 [ ,]
*Oct 31 09:31:38.855: RADIUS:  Acct-Interim-Interva[85]  6   90
*Oct 31 09:31:38.855: RADIUS:  Vendor, Cisco       [26]  108
*Oct 31 09:31:38.855: RADIUS:   Cisco AVpair       [1]   102 "lcp:interface-config#1=rate-limit input 64000 12000 24000 conform-action transmit exceed-action drop"
если вручную прописать, то шейпинг работает.
interface Virtual-Template1
 rate-limit output 1024000 128000 256000 conform-action transmit exceed-action drop
 rate-limit input 512000 128000 256000 conform-action transmit exceed-action drop
Edited by u.s.s.r
