ACL (собирал в кучу с разных форумов)
Может еще чего добавить?
// - ACL
delete access_profile all
// - Deny Multicast traffic
create cpu access_profile ip destination_ip_mask 240.0.0.0 profile_id 1
config cpu access_profile profile_id 1 add access_id 1 ip destination_ip 224.0.0.0 port 1-28 deny
enable cpu_interface_filtering
// — Deny broadcasts
create access_profile ethernet destination_mac ff-ff-ff-ff-ff-ff ethernet_type profile_id 2
config access_profile profile_id 2 add access_id auto_assign ethernet destination_mac ff-ff-ff-ff-ff-ff ethernet_type 0x806 port 1-28 permit
config access_profile profile_id 2 add access_id auto_assign ethernet destination_mac ff-ff-ff-ff-ff-ff ethernet_type 0x800 port 1-28 deny
// - ICMP
create access_profile ip source_ip_mask 255.255.240.0 destination_ip_mask 255.255.255.255 icmp profile_id 3
config access_profile profile_id 3 add access_id auto_assign ip source_ip 172.30.0.0 destination_ip 255.255.255.255 icmp port 1-28 deny
// - Deny DHCP
create access_profile ip udp src_port_mask 0xFFFF profile_id 4
config access_profile profile_id 4 add access_id auto_assign ip udp src_port 67 port 1-28 deny
config access_profile profile_id 4 add access_id auto_assign ip udp src_port 68 port 1-28 permit
create access_profile ip udp dst_port_mask 0xFFFF profile_id 5
config access_profile profile_id 5 add access_id auto_assign ip udp dst_port 68 port 1-28 deny
config access_profile profile_id 5 add access_id auto_assign ip udp dst_port 67 port 1-28 permit
// - Deny netbios
create access_profile ip tcp dst_port_mask 0xFFFF profile_id 6
config access_profile profile_id 6 add access_id auto_assign ip tcp dst_port 135 port 1-28 deny
config access_profile profile_id 6 add access_id auto_assign ip tcp dst_port 137 port 1-28 deny
config access_profile profile_id 6 add access_id auto_assign ip tcp dst_port 138 port 1-28 deny
config access_profile profile_id 6 add access_id auto_assign ip tcp dst_port 139 port 1-28 deny
config access_profile profile_id 6 add access_id auto_assign ip tcp dst_port 445 port 1-28 deny
config access_profile profile_id 6 add access_id auto_assign ip tcp dst_port 1900 port 1-28 deny
config access_profile profile_id 6 add access_id auto_assign ip tcp dst_port 2869 port 1-28 deny
create access_profile ip udp dst_port_mask 0xFFFF profile_id 7
config access_profile profile_id 7 add access_id auto_assign ip udp dst_port 135 port 1-28 deny
config access_profile profile_id 7 add access_id auto_assign ip udp dst_port 137 port 1-28 deny
config access_profile profile_id 7 add access_id auto_assign ip udp dst_port 138 port 1-28 deny
config access_profile profile_id 7 add access_id auto_assign ip udp dst_port 139 port 1-28 deny
config access_profile profile_id 7 add access_id auto_assign ip udp dst_port 445 port 1-28 deny
config access_profile profile_id 7 add access_id auto_assign ip udp dst_port 1900 port 1-28 deny
config access_profile profile_id 7 add access_id auto_assign ip udp dst_port 2869 port 1-28 deny
// — Deny IPv6 EtherType
create access_profile ethernet ethernet_type profile_id 8
config access_profile profile_id 8 add access_id auto_assign ethernet ethernet_type 0x86dd port 1-28 deny
// — Deny all
create access_profile ethernet source_mac 00-00-00-00-00-00 profile_id 9
config access_profile profile_id 9 add access_id auto_assign ethernet source_mac 00-00-00-00-00-00 port 1-28 deny
Edited by rozix
Девятый профиль перекрывает восьмой, а вообще подобных тем на наге сам видел не менее 3-х штук =)
У винды семерки появился хоме каталог, мы его тоже поблочили
Edited by pppoetest
