Блокировка веб ресурса
533 members have voted
  1. 1. Для блокировка используем
Блокировка сайтов провайдерами маневры с DNS
2018-04-19 00:21:18 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 01:01:15 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 01:41:13 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 02:20:46 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 03:21:42 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 03:40:46 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 04:21:12 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 04:40:45 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 05:21:41 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 05:41:12 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 06:21:42 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 07:21:41 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 07:41:23 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 08:20:46 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 09:01:17 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 09:41:21 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 10:01:17 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 10:40:46 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 11:01:18 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 11:41:46 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 12:20:45 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 12:41:16 | INFO  | main  | Version Dump: 2.3. OK
2018-04-19 13:41:12 | INFO  | main  | Version Dump: 2.3. OK
Обработка пользовательского списка исключений же
if( defined($EX_IPS{$ip}) )
# print "Excluding ip ".$ip.": match excluded ip in DB.\n";
$MAIL_EXCLUDES .= "Excluding ip ".$ip.": match excluded ip in DB.\n";
$logger->debug("Excluding ip ".$ip);
next;
Share this post
Link to post
Share on other sites
8 минут назад, myth сказал:
Нет. Следующий блок. где ZAP_OLD_IPS
Share this post
Link to post
Исправлено поведение zapret.pl при обнаружении пустого ip.
Share this post
Link to post
Подскажите, как СКАТ блокирует подсети? ICMP должны проходить?
Например сеть 91.108.4.0/22. Есть хост 91.108.4.10, который у оператора со СКАТом отвечает на ICMP но выдаёт заглушку при обращении через WEB. А как он с другими сетевыми портами поступает? Блочит?
Share this post
Link to post
Аналогично с zapret.pl:
2018-04-19 13:41:38 | ERROR | main  | Eval: Can't call method "binip" on an undefined value at /usr/local/scripts/zapret/zapret.pl line 867.
2018-04-19 13:41:58 | INFO  | main  | Load iterations: 1, resolved domains ipv4: 0, resolved domains ipv6: 0
2018-04-19 13:41:58 | INFO  | main  | Added: domains: 1, urls: 2, IPv4 ips: 2, IPv6 ips: 0, subnets: 0, records: 3
2018-04-19 13:41:58 | INFO  | main  | Deleted: old domains: 15633, old urls: 13661, old ips: 58781, old only ips: 835, old subnets: 20, old records: 28162
Самое плохое в последней строчке. Похоже скрипт пропустил все, что после возникновения ошибки и почистил БД.
4 минуты назад, max1976 сказал:
Пока писал, исправлено )) Спасибо.
Share this post
Link to post
24 минуты назад, max1976 сказал:
Спасибо, все работает
Share this post
Link to post
29 минут назад, max1976 сказал:
Спасибо.
Было бы неплохо для таких случаев иметь возможность парсинга локального файла реестра.
Share this post
Link to post
Если кому-то интересно, я выложил новую версию zapret.pl. Из кода удален функционал резолвинга доменов. Переделан алгоритм разбора xml, работы с реестром, что существенно сократило время обработки реестра. Можно ставить в крон вызов скрипта каждые 10 минут, что позволит оперативно обновлять БД. Теперь, при возникновении нештатных ситуаций с реестром, не будет очистки БД.
Edited by max1976
Share this post
Link to post
Сделал скриптик, который считает статистику по дампу.
Статистика по дампу
  Сводка по URL:
  - всего записей: 58627
  - наиболее длинный URL: 1133
  - протокол HTTP: всего 50721; порты 80 81 888 8001 8080 8081
  - протокол HTTPS: всего 7894; порты 443 16869
  - другие протоколы: всего 12; newcamd525
  - top-10 доменов: vidoevo.com myvido1.com exyi.com agaclip.com viduba.com molodegka.xyz graniru.info paktune.pk voroniny-online.pw pixiv.net
  Сводка по доменам:
  - всего доменов: 68318
  - из них с маской: 3641
  - top-10 доменов без маски: sl.pt googleusercontent.com bcdl.rocks bkfind.space amazonaws.com ru.com bookolimp.site sl-reverse.com graniru.info sexros.net
  - top-10 доменов с маской: bkfind.space ru.com olimp9b55.gdn olimp6301.site olimpa88c.site olimpa89a.top olimp98b4.top olimp656f.top olimp58e8.top olimp4859.top
  Сводка по IP-адресам:
  - всего адресов: 2612
  - top-10 для адресов: 188.42.196 185.49.71 188.42.189 185.106.140 185.82.210 173.0.153 188.124.247 87.117.232 185.164.174 125.209.252
  - всего подсетей: 61
  - top-10 для подсетей:
      34.192.0.0/10
      52.192.0.0/11
      35.192.0.0/12
      35.208.0.0/12
      35.224.0.0/12
      52.64.0.0/12
      54.144.0.0/12
      54.160.0.0/12
      34.240.0.0/13
      34.248.0.0/13
  - общий размер подсетей: 18197760
Сам скрипт под спойлером.
Скрытый текст
Для работы скрипта нужен сам дамп в XML, и пакет xmlstarlet.
#!/bin/bash
### Работа с дампом - статистика
ERDI_XML="/usr/bin/xmlstarlet"
DUMP="путь-к-дампу/dump_last.xml"
echo "Дамп: $DUMP (байт `stat --format='%s' $DUMP`, строк `wc --lines $DUMP | cut -d' ' -f1`)"
# | sed -e 's/\(.*\)/\U\1/' | xargs idn --quiet -u --no-tld
echo "Формируются списки из дампа..."
echo "- список адресов (list-url.txt)"
"${ERDI_XML}" select -T -t -m "/reg:register/content[not(@blockType) and url]" \
 -v "url" -n "$DUMP" \
 | sort -u | awk '{ print length, $0 }' | sort -nr | cut -d" " -f2- \
 > list-url.txt
echo "- список доменов (list-domain.txt)"
"${ERDI_XML}" select -T -t -m "/reg:register/content[@blockType='domain']" \
 -v "domain" -n "$DUMP" \
 | idn --quiet | sed 's/\(.*\)/\L\1/' \
 | sed 's/\.$//' \
 > list-domain.txt
echo "- список доменов с маской (list-mask.txt)"
"${ERDI_XML}" select -T -t -m "/reg:register/content[@blockType='domain-mask']" \
 | sed 's/\.$//' \
 > list-mask.txt
echo "- список IP-адресов (list-ip.txt)"
"${ERDI_XML}" select -T -t -m "/reg:register/content[@blockType='ip' and ip]" \
 -v "ip" -n "$DUMP" \
 | sort -V -u \
 > list-ip.txt
echo "- список IP-подсетей (list-net.txt)"
"${ERDI_XML}" select -T -t -m "/reg:register/content[@blockType='ip' and ipSubnet]" \
 -v "ipSubnet" -n "$DUMP" \
 | sort -V -u \
 > list-net.txt
echo "Статистика по дампу"
echo "  Сводка по URL: "
echo "  - всего записей: `wc --lines list-url.txt | cut -d' ' -f1`"
echo "  - наиболее длинный URL: `head -n 1 list-url.txt | wc --chars`"
echo "  - протокол HTTP: всего `grep -c -E '^http://' list-url.txt`; порты `grep -E '^http://[^/]+:[0-9]+' list-url.txt | grep -E -o '^http://[^/]+:[0-9]+' | cut -d':' -f3 | sort -u -n | tr '\n' ' '`"
echo "  - протокол HTTPS: всего `grep -c -E '^https://' list-url.txt`; порты `grep -E '^https://[^/]+:[0-9]+' list-url.txt | grep -E -o '^https://[^/]+:[0-9]+' | cut -d':' -f3 | sort -u -n | tr '\n' ' '`"
echo "  - другие протоколы: всего `grep -c -E -v '^https?://' list-url.txt`; `grep -E -v '^https?://' list-url.txt | grep -E -o '^.+://' | cut -d':' -f1 | sort -u | tr '\n' ' '`"
echo "  - top-10 доменов: `grep -E -o '^https?://[^/]+' list-url.txt | cut -d':' -f2 | cut -c3- | cut -d'.' -f2- | grep -F '.' | sort | uniq -c | sort -nr | head -n 10 | cut -c9- | tr '\n' ' '`"
echo "  Сводка по доменам: "
echo "  - всего доменов: `wc --lines list-domain.txt list-mask.txt | tail -n 1 | grep -E -o '[0-9]+'`"
echo "  - из них с маской: `wc --lines list-mask.txt | cut -d' ' -f1`"
echo "  - top-10 доменов без маски: `rev list-domain.txt | cut -d'.' -f1-2 | rev | sort | uniq -c | sort -nr | head -n 10 | cut -c9- | tr '\n' ' '`"
echo "  - top-10 доменов с маской: `rev list-mask.txt | cut -d'.' -f1-2 | rev | sort | uniq -c | sort -nr | head -n 10 | cut -c9- | tr '\n' ' '`"
echo "  Сводка по IP-адресам: "
echo "  - всего адресов: `wc --lines list-ip.txt | cut -d' ' -f1`"
echo "  - top-10 для адресов: `cut -d'.' -f1-3 list-ip.txt | sort -V | uniq -c | sort -nr | head -n 10 | cut -c9- | tr '\n' ' '`"
echo "  - всего подсетей: `wc --lines list-net.txt | cut -d' ' -f1`"
echo "  - top-10 для подсетей: "
sort -n -t'/' -k2 list-net.txt | head -n 10 | sed  's/^/      /'
echo "  - общий размер подсетей: `cut -d'/' -f2 list-net.txt | awk '{s+=2^(32-$1)}END{print s}'`"
Скрипт вначале выгружает разные типы записей в разные файлы, а затем по ним получает статистику.
Share this post
Link to post
Перешел на dev ветку, потестю
Наверное, так лучше $logger->info("Starting RKN at ".(localtime()));
Share this post
Link to post
Работает, действительно, намного быстрее
Share this post
Link to post
Тоже клон гита сделал, но потестить пока не могу. Мне ресурс выгрузки vigruzki.rkn.gov.ru уже второй день недоступен ни через один аплинк :)
Share this post
Link to post
44 минуты назад, big-town сказал:
А пальчиком РКН еще не грозил? А то у мена была похожая ситуация года два назад.
Share this post
Link to post
4 минуты назад, arhead сказал:
А мы уже ученые. Сделал скрины трэйсера и отослал в обл. отделение РКН, где явно видно что проблемы не у меня. Интернет ломал не я ;).
Edited by big-town
Share this post
Link to post
2 часа назад, max1976 сказал:
Спасибо за труд, а в zapret.sql появились изменения и лучше БД новую залить?
Share this post
Link to post
Только что, hsvt сказал:
Можно в новую, а можно и текущую обновить:
alter table zap2_records add column hash varchar(60) NULL;
CREATE INDEX record_id_idx ON zap2_domains(record_id);
CREATE INDEX record_id_idx ON zap2_only_ips(record_id);
CREATE INDEX record_id_idx ON zap2_urls(record_id);
CREATE INDEX record_id_idx ON zap2_subnets(record_id);
Share this post
Link to post
Еще надо:
ALTER TABLE zap2_domains CHANGE COLUMN `domain` `domain` varchar(255) DEFAULT NULL;
Share this post
Link to post
8 минут назад, SokolovS сказал:
Еще надо:
Зачем оно изначально varchar(255) DEFAULT NULL
| Field        | Type            | Null | Key | Default           | Extra          |
| id           | int(6) unsigned | NO   | PRI | NULL              | auto_increment |
| date_add     | timestamp       | NO   |     | CURRENT_TIMESTAMP |                |
| record_id    | int(6) unsigned | NO   | MUL | NULL              |                |
| domain       | varchar(255)    | NO   |     | NULL              |                |
| domain_fixed | varchar(60)     | NO   |     | NULL              |                |
Share this post
Link to post
5 минут назад, big-town сказал:
См. определение таблицы:
https://github.com/max197616/zapret/blob/master/zapret.sql
И у вас в колонке Null стоит NO.
Edited by SokolovS
Share this post
Link to post
Извиняюсь, на размер смотрел, упустил из виду NULL.
Share this post
Link to post
3 часа назад, max1976 сказал:
Если в конфиге переменная our_blacklist закомментирована, то в логе будет ошибка открытия файла.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
