Не могу заставить нормально работать NFGroup на Windows. При запуске в базу агрегированную инфу прекрасно добавляет, затем висит, пока не снимешь вручную. В логе следующее:
Sat Oct 20 22:52:25 2012 ctlthr : ---- begin ----
Sat Oct 20 22:52:25 2012 ctlthr : NFgroup v.2010071101 (Free) compiled @ x86-Windows-6.0 (C) OOO
Sat Oct 20 22:52:25 2012 ctlthr : Main   config path : nfgroup.conf
Sat Oct 20 22:52:25 2012 ctlthr : Scheme config path : C:\netflow\schemes.conf
Sat Oct 20 22:52:25 2012 ctlthr : Db     config path : C:\netflow\db.conf
Sat Oct 20 22:52:25 2012 ctlthr : Input directory fullpath: D:\netflow\out.1
Sat Oct 20 22:52:25 2012 ctlthr : Configured schemes number : 5 [ SourceNode [0], DestNode [1], HostMatrix [2], RawFlows [3], DetailASMatrix [4] ]
Sat Oct 20 22:52:25 2012 ctlthr : Current aggregation scheme : HostMatrix [2]
Sat Oct 20 22:52:25 2012 ctlthr : Use statistics : 0
Sat Oct 20 22:52:25 2012 ctlthr : db_config[db_host] : localhost
Sat Oct 20 22:52:25 2012 ctlthr : db_config[db_name] : netflower
Sat Oct 20 22:52:25 2012 ctlthr : db_config[db_user] : netflower
Sat Oct 20 22:52:25 2012 ctlthr : db_config[db_password] : ***
Sat Oct 20 22:52:25 2012 ctlthr : Connecting to database ...
Sat Oct 20 22:52:25 2012 ctlthr : Connected succesfully
Sat Oct 20 22:52:25 2012 ctlthr : Source directory files number : 2
Sat Oct 20 22:52:25 2012 thr  0 : Processing source file number 1 of 2
Sat Oct 20 22:52:25 2012 thr  0 : Opening source file : ***.20121017230001-20121018000001
Sat Oct 20 22:52:25 2012 thr  0 : KeySize[8] : ValSize[16] : DataSize[46]
Sat Oct 20 22:52:25 2012 thr  0 : Init cache ...
Sat Oct 20 22:52:25 2012 thr  0 : Init cache finished
Sat Oct 20 22:52:25 2012 thr  0 : Inserting data ...
Sat Oct 20 22:52:25 2012 thr  0 : Executing SQL : CREATE table netflow (begin_datetime timestamp(14), end_datetime timestamp(14), source_device varchar(15), source_addr varchar(15), dest_addr varchar(15), packets INT, octets BIGINT, flows INT )
Sat Oct 20 22:52:29 2012 thr  0 : Inserting data finished
Sat Oct 20 22:52:29 2012 thr  0 : Dumping data
Содержимое NFgroup.conf вот:
scheme_config_fullpath =	"C:\netflow\schemes.conf"
input_dir_name = 		"D:\netflow\out.1"
output_dir_name = 		"D:\netflow\out.2"
log_file_name = 		"D:\netflow\log\NFgroup.log"
threads_number =                1
max_arows_number =		5000000
aggregation_scheme =		"HostMatrix"
compression_type = 		bzip2
compression_level = 		9
storage_driver =		mysql
db_config_fullpath =            "C:\netflow\db.conf"
В out.2 создает файл с именем таким же, как в out.1, размером 0 байт, ничего в него не пишет.
bzip2 установлен, в переменную среды PATH путь до него прописан... Не понимаю, что нужно еще.
Edited by Барагоз
