Заменили 3750 на 6506 sup32, почемуто в port-ch1 скорость не поднимается выше 1 gbit/s, там 4 линка, с другой стороны dlink 3100-24ts. До замены циски всё работало. Просветлился по port-channel, ничего нового не узнал и проблему не могу решить. Есть идеи?
upgrade fpd auto
version 12.2
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
service udp-small-servers
service counters max age 10
service unsupported-transceiver
hostname sw-core
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip vrf gw-02
rd 65512:1
import ipv4 unicast map GLOB-TO-GW-02
ip vrf gw-03
rd 65512:3
no ip domain-lookup
ip domain-name int.goodnet.su
vtp mode transparent
mls ip multicast flow-stat-timer 9
no mls flow ip
no mls flow ipv6
no mls acl tcam share-global
mls cef error action freeze
redundancy
keepalive-enable
mode sso
main-cpu
auto-sync running-config
spanning-tree mode pvst
spanning-tree extend system-id
no spanning-tree vlan 1-4094
system jumbomtu 1500
system flowcontrol bus auto
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
no errdisable detect cause gbic-invalid
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
interface Port-channel1
description to ag-01
switchport
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 2-50,100-140,201-203,401
switchport mode trunk
switchport nonegotiate
lacp max-bundle 4
interface Port-channel2
description to sw-core-02
switchport
interface GigabitEthernet3/1
description to ag-01-1
switchport
channel-protocol lacp
channel-group 1 mode active
interface GigabitEthernet3/2
description to ag-01-2
switchport
interface GigabitEthernet3/3
description to ag-01-3
switchport
interface GigabitEthernet3/4
description to ag-01-4
switchport
sh int po1
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 0016.9dc7.87d3 (bia 0016.9dc7.87d3)
Description: to ag-01
MTU 1500 bytes, BW 4000000 Kbit, DLY 10 usec,
reliability 255/255, txload 0/255, rxload 0/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is off
Members in this channel: Gi3/1 Gi3/2 Gi3/3 Gi3/4
ARP type: ARPA, ARP Timeout 04:00:00
Last input never, output never, output hang never
Last clearing of "show interface" counters 02:55:06
Input queue: 0/2000/691666/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 670438000 bits/sec, 105494 packets/sec
5 minute output rate 987188000 bits/sec, 116928 packets/sec
873631867 packets input, 696338472484 bytes, 0 no buffer
Received 3054453 broadcasts (1343179 multicasts)
0 runts, 0 giants, 0 throttles
2 input errors, 0 CRC, 0 frame, 691666 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
0 input packets with dribble condition detected
957632330 packets output, 1022758454090 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 PAUSE output
0 output buffer failures, 0 output buffers swapped out
sh etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
1 Po1(SU) LACP Gi3/1(P) Gi3/2(P) Gi3/3(P)
Gi3/4(P)
2 Po2(SD) LACP Gi3/5(D) Gi3/6(D) Gi3/7(D)
Gi3/8(D)
Edited by babay951
port-channel load-balance src-dst-ip не стоял, поставил - не помогло.
Разнёс по портам, эффект есть. Сейчас не 1 gbit/s, а 1.2 gbit/s, но опять уперлось.
Трафик льется равномерно по всем четырем
sh mod
Mod Ports Card Type Model Serial No.
3 48 48 port 10/100/1000mb EtherModule WS-X6148-GE-TX SAL100194T0
4 48 48 port 10/100/1000mb EtherModule WS-X6148-GE-TX SAL1002AAJ5
6 9 Supervisor Engine 32 8GE (Active) WS-SUP32-GE-3B SAL1108HCWQ
Mod MAC addresses Hw Fw Sw Status
3 0016.9dc7.87d0 to 0016.9dc7.87ff 1.1 7.2(1) 8.6(0.259)CA Ok
4 0016.c748.bb38 to 0016.c748.bb67 1.1 7.2(1) 8.6(0.259)CA Ok
6 0017.e018.9ff0 to 0017.e018.9ffb 4.5 12.2(18r)SX2 12.2(33)SRA2 Ok
Mod Sub-Module Model Serial Hw Status
6 Policy Feature Card 3 WS-F6K-PFC3B SAL1107HA1D 2.3 Ok
6 Cat6k MSFC 2A daughterboard WS-F6K-MSFC2A SAL1108HDAM 4.0 Ok
Mod Online Diag Status
3 Pass
4 Pass
6 Pass
Edited by babay951
zhenya Спасибо добрый человек за указанное направление. За полчаса до часа пик всё сделали.
нашёл эту доку
http://img.nag.ru/projects/setup/227/77b4fd0e8d4491b97e6840f5de1d5ced.pdf
Проблема в модулях WS-X6148-GE-TX они не прокачивают на порт шанелях больше гига
Взяв 3 медиаконвертера, 6 sfp и 1 медный патчкорд я подключился к модулю
WS-SUP32-GE-3B
И скорость на портшанеле попёрла.
Ну реально - вынос мозга.
Подскажите что купить вместо WS-X6148-GE-TX ? Чтобы не было проблем с превышением объёма подписки с etherchannel.
Edited by babay951
WS-X6516-GE-TX не имеет таких ограничений(1 gbit/s на etherchannel), но в ней мало портов. Более многопортовые адекватные карты для sup 32 подсказать не могу, ибо сами пока не нашли
Я вот думаю это проблема только с etherchannel или весь модуль WS-X6148-GE-TX больше гига не прокачивает?
Во время обнаружения проблемы у меня было 2 portchannel и у каждого скорость была как раз по половинке 500мбит/с .
Модуль больше прокачает. Проблемы с etherchannel на этом модуле.
The WS-X6148-GE-TX and WS-X6148V-GE-TX switching modules do not support more than
1 Gbps of traffic per EtherChannel.
Что купить - делайте выводы из доки ниже :)
Link to cisco doc
Удачи :)
Edited by alanw
