Есть сервер под управление FreeBSD
c0# uname -a
FreeBSD c0.eurasiastar.kz 8.2-STABLE-201105 FreeBSD 8.2-STABLE-201105 #0: Fri Jul 22 13:28:32 ALMT 2011
c 18:00 до 24:00 имеет такую петрушку:
c0# top -aSCHIP
last pid:  4796;  load averages:  8.81,  7.86,  5.32    up 0+06:51:55  18:16:57
118 processes: 14 running, 73 sleeping, 31 waiting
CPU 0:  0.0% user,  0.0% nice,  100% system,  0.0% interrupt,  0.0% idle
CPU 1:  0.0% user,  0.0% nice, 87.9% system,  2.1% interrupt,  9.9% idle
CPU 2:  0.0% user,  0.0% nice, 90.1% system,  0.7% interrupt,  9.2% idle
CPU 3:  0.0% user,  0.0% nice,  100% system,  0.0% interrupt,  0.0% idle
Mem: 413M Active, 13M Inact, 316M Wired, 88K Cache, 63M Buf, 1214M Free
Swap: 4025M Total, 4025M Free
 PID USERNAME PRI NICE   SIZE    RES STATE   C   TIME    CPU COMMAND
   0 root     -68    0     0K   384K CPU2    2  15:51 98.14% {igb3 que}
   0 root     -68    0     0K   384K CPU0    0  15:58 95.12% {igb3 que}
   0 root     -68    0     0K   384K -       3  15:55 90.87% {igb3 que}
   0 root     -68    0     0K   384K RUN     1  15:10 81.69% {igb3 que}
  11 root     171 ki31     0K    64K RUN     1 368:46  9.03% {idle: cpu1}
  11 root     171 ki31     0K    64K RUN     0 368:30  7.76% {idle: cpu0}
  11 root     171 ki31     0K    64K RUN     2 370:18  7.47% {idle: cpu2}
  11 root     171 ki31     0K    64K RUN     3 372:55  7.37% {idle: cpu3}
   0 root     -68    0     0K   384K -       1   1:27  1.22% {igb2 que}
   0 root     -68    0     0K   384K -       1   1:28  1.12% {igb2 que}
   0 root     -68    0     0K   384K -       1   1:27  1.12% {igb2 que}
   0 root     -68    0     0K   384K CPU1    3   1:27  0.83% {igb2 que}
  12 root     -68    -     0K   576K RUN     0  12:03  0.49% {irq266: igb2:que
  12 root     -68    -     0K   576K WAIT    3  11:33  0.49% {irq269: igb2:que
  12 root     -68    -     0K   576K RUN     2  12:07  0.44% {irq268: igb2:que
  12 root     -68    -     0K   576K RUN     1  12:19  0.39% {irq267: igb2:que
соответственно у людей лагает интернет. Интерфейс igb3 смотрит на шейпер, остальные в мир.
c0# vmstat -i
interrupt                          total       rate
irq20: atapci1                      8398          0
irq23: ehci0 ehci1                 62133          2
cpu0: timer                     49835766       1999
irq261: igb1:que 0               1798316         72
irq262: igb1:que 1               1005980         40
irq263: igb1:que 2               1410148         56
irq264: igb1:que 3               1471862         59
irq265: igb1:link                      2          0
irq266: igb2:que 0             209826778       8420
irq267: igb2:que 1             212835784       8541
irq268: igb2:que 2             211722125       8496
irq269: igb2:que 3             209561907       8410
irq270: igb2:link                      2          0
irq271: igb3:que 0             209033136       8388
irq272: igb3:que 1             208383214       8362
irq273: igb3:que 2             207672087       8334
irq274: igb3:que 3             205888459       8262
irq275: igb3:link                      2          0
irq276: re0                        48939          1
cpu3: timer                     49835653       1999
cpu1: timer                     49835654       1999
cpu2: timer                     49835654       1999
Total                         1880071999      75450
c0# netstat -w1 -i igb3
           input        (Total)           output
  packets  errs idrops      bytes    packets  errs      bytes colls
    91161     0     0   54145144      87580     0   55120697     0
    94313     0     0   57339454      92424     0   58726545     0
    93183     0     0   56893475      88471     0   58589499     0
    92358     0     0   55801508      89498     0   57925661     0
Что я не так наконфигурил? в другое время проблем нет.
Самый большой юмор в том что шейпера на этой машине нет, в файрволле одна строка - allow any to any, машина занимается тем, что принимает фуллвью от двух операторов связи, анонсит наши сети и т.п. Т.е. сос стороны маршрутизации-тупой форфардинг пакетов по табличке, больше ничего
dev.igb.0.%desc: Intel(R) PRO/1000 Network Connection version - 2.2.3
dev.igb.0.%driver: igb
dev.igb.0.%location: slot=0 function=0
dev.igb.0.%pnpinfo: vendor=0x8086 device=0x1526 subvendor=0x8086 subdevice=0xa06c class=0x020000
dev.igb.0.%parent: pci4
dev.igb.0.nvm: -1
dev.igb.0.enable_aim: 1
dev.igb.0.flow_control: 3
dev.igb.0.rx_processing_limit: 100
dev.igb.0.link_irq: 0
dev.igb.0.dropped: 0
dev.igb.0.tx_dma_fail: 0
dev.igb.0.rx_overruns: 0
dev.igb.0.watchdog_timeouts: 0
dev.igb.0.device_control: 12583489
dev.igb.0.rx_control: 0
dev.igb.0.interrupt_mask: 0
dev.igb.0.extended_int_mask: 2147483648
dev.igb.0.tx_buf_alloc: 0
dev.igb.0.rx_buf_alloc: 0
dev.igb.0.fc_high_water: 58976
dev.igb.0.fc_low_water: 58960
dev.igb.0.queue0.interrupt_rate: 0
dev.igb.0.queue0.txd_head: 0
dev.igb.0.queue0.txd_tail: 0
dev.igb.0.queue0.no_desc_avail: 0
dev.igb.0.queue0.tx_packets: 0
dev.igb.0.queue0.rxd_head: 0
dev.igb.0.queue0.rxd_tail: 0
dev.igb.0.queue0.rx_packets: 0
dev.igb.0.queue0.rx_bytes: 0
dev.igb.0.queue0.lro_queued: 0
dev.igb.0.queue0.lro_flushed: 0
dev.igb.0.queue1.interrupt_rate: 0
dev.igb.0.queue1.txd_head: 0
dev.igb.0.queue1.txd_tail: 0
dev.igb.0.queue1.no_desc_avail: 0
dev.igb.0.queue1.tx_packets: 0
dev.igb.0.queue1.rxd_head: 0
dev.igb.0.queue1.rxd_tail: 0
dev.igb.0.queue1.rx_packets: 0
dev.igb.0.queue1.rx_bytes: 0
dev.igb.0.queue1.lro_queued: 0
dev.igb.0.queue1.lro_flushed: 0
dev.igb.0.queue2.interrupt_rate: 0
dev.igb.0.queue2.txd_head: 0
dev.igb.0.queue2.txd_tail: 0
dev.igb.0.queue2.no_desc_avail: 0
dev.igb.0.queue2.tx_packets: 0
dev.igb.0.queue2.rxd_head: 0
dev.igb.0.queue2.rxd_tail: 0
dev.igb.0.queue2.rx_packets: 0
dev.igb.0.queue2.rx_bytes: 0
dev.igb.0.queue2.lro_queued: 0
dev.igb.0.queue2.lro_flushed: 0
dev.igb.0.queue3.interrupt_rate: 0
dev.igb.0.queue3.txd_head: 0
dev.igb.0.queue3.txd_tail: 0
dev.igb.0.queue3.no_desc_avail: 0
dev.igb.0.queue3.tx_packets: 0
dev.igb.0.queue3.rxd_head: 0
dev.igb.0.queue3.rxd_tail: 0
dev.igb.0.queue3.rx_packets: 0
dev.igb.0.queue3.rx_bytes: 0
dev.igb.0.queue3.lro_queued: 0
dev.igb.0.queue3.lro_flushed: 0
dev.igb.0.mac_stats.excess_coll: 0
dev.igb.0.mac_stats.single_coll: 0
dev.igb.0.mac_stats.multiple_coll: 0
dev.igb.0.mac_stats.late_coll: 0
dev.igb.0.mac_stats.collision_count: 0
dev.igb.0.mac_stats.symbol_errors: 0
dev.igb.0.mac_stats.sequence_errors: 0
dev.igb.0.mac_stats.defer_count: 0
dev.igb.0.mac_stats.missed_packets: 0
dev.igb.0.mac_stats.recv_no_buff: 0
dev.igb.0.mac_stats.recv_undersize: 0
dev.igb.0.mac_stats.recv_fragmented: 0
dev.igb.0.mac_stats.recv_oversize: 0
dev.igb.0.mac_stats.recv_jabber: 0
dev.igb.0.mac_stats.recv_errs: 0
dev.igb.0.mac_stats.crc_errs: 0
dev.igb.0.mac_stats.alignment_errs: 0
dev.igb.0.mac_stats.coll_ext_errs: 0
dev.igb.0.mac_stats.xon_recvd: 0
dev.igb.0.mac_stats.xon_txd: 0
dev.igb.0.mac_stats.xoff_recvd: 0
dev.igb.0.mac_stats.xoff_txd: 0
dev.igb.0.mac_stats.total_pkts_recvd: 0
dev.igb.0.mac_stats.good_pkts_recvd: 0
dev.igb.0.mac_stats.bcast_pkts_recvd: 0
dev.igb.0.mac_stats.mcast_pkts_recvd: 0
dev.igb.0.mac_stats.rx_frames_64: 0
dev.igb.0.mac_stats.rx_frames_65_127: 0
dev.igb.0.mac_stats.rx_frames_128_255: 0
dev.igb.0.mac_stats.rx_frames_256_511: 0
dev.igb.0.mac_stats.rx_frames_512_1023: 0
dev.igb.0.mac_stats.rx_frames_1024_1522: 0
dev.igb.0.mac_stats.good_octets_recvd: 0
dev.igb.0.mac_stats.good_octets_txd: 0
dev.igb.0.mac_stats.total_pkts_txd: 0
dev.igb.0.mac_stats.good_pkts_txd: 0
dev.igb.0.mac_stats.bcast_pkts_txd: 0
dev.igb.0.mac_stats.mcast_pkts_txd: 0
dev.igb.0.mac_stats.tx_frames_64: 0
dev.igb.0.mac_stats.tx_frames_65_127: 0
dev.igb.0.mac_stats.tx_frames_128_255: 0
dev.igb.0.mac_stats.tx_frames_256_511: 0
dev.igb.0.mac_stats.tx_frames_512_1023: 0
dev.igb.0.mac_stats.tx_frames_1024_1522: 0
dev.igb.0.mac_stats.tso_txd: 0
dev.igb.0.mac_stats.tso_ctx_fail: 0
dev.igb.0.interrupts.asserts: 0
dev.igb.0.interrupts.rx_pkt_timer: 0
dev.igb.0.interrupts.rx_abs_timer: 0
dev.igb.0.interrupts.tx_pkt_timer: 0
dev.igb.0.interrupts.tx_abs_timer: 0
dev.igb.0.interrupts.tx_queue_empty: 0
dev.igb.0.interrupts.tx_queue_min_thresh: 0
dev.igb.0.interrupts.rx_desc_min_thresh: 0
dev.igb.0.interrupts.rx_overrun: 0
dev.igb.0.host.breaker_tx_pkt: 0
dev.igb.0.host.host_tx_pkt_discard: 0
dev.igb.0.host.rx_pkt: 0
dev.igb.0.host.breaker_rx_pkts: 0
dev.igb.0.host.breaker_rx_pkt_drop: 0
dev.igb.0.host.tx_good_pkt: 0
dev.igb.0.host.breaker_tx_pkt_drop: 0
dev.igb.0.host.rx_good_bytes: 0
dev.igb.0.host.tx_good_bytes: 0
dev.igb.0.host.length_errors: 0
dev.igb.0.host.serdes_violation_pkt: 0
dev.igb.0.host.header_redir_missed: 0
dev.igb.1.%desc: Intel(R) PRO/1000 Network Connection version - 2.2.3
dev.igb.1.%driver: igb
dev.igb.1.%location: slot=0 function=1
dev.igb.1.%pnpinfo: vendor=0x8086 device=0x1526 subvendor=0x8086 subdevice=0xa06c class=0x020000
dev.igb.1.%parent: pci4
dev.igb.1.nvm: -1
dev.igb.1.enable_aim: 1
dev.igb.1.flow_control: 3
dev.igb.1.rx_processing_limit: 100
dev.igb.1.link_irq: 2
dev.igb.1.dropped: 0
dev.igb.1.tx_dma_fail: 0
dev.igb.1.rx_overruns: 0
dev.igb.1.watchdog_timeouts: 0
dev.igb.1.device_control: 1488978497
dev.igb.1.rx_control: 67141634
dev.igb.1.interrupt_mask: 4
dev.igb.1.extended_int_mask: 2147483679
dev.igb.1.tx_buf_alloc: 0
dev.igb.1.rx_buf_alloc: 0
dev.igb.1.fc_high_water: 58976
dev.igb.1.fc_low_water: 58960
dev.igb.1.queue0.interrupt_rate: 18181
dev.igb.1.queue0.txd_head: 3058
dev.igb.1.queue0.txd_tail: 3058
dev.igb.1.queue0.no_desc_avail: 0
dev.igb.1.queue0.tx_packets: 2318658
dev.igb.1.queue0.rxd_head: 3775
dev.igb.1.queue0.rxd_tail: 3774
dev.igb.1.queue0.rx_packets: 40639
dev.igb.1.queue0.rx_bytes: 16117177
dev.igb.1.queue0.lro_queued: 0
dev.igb.1.queue0.lro_flushed: 0
dev.igb.1.queue1.interrupt_rate: 5494
dev.igb.1.queue1.txd_head: 3866
dev.igb.1.queue1.txd_tail: 3866
dev.igb.1.queue1.no_desc_avail: 0
dev.igb.1.queue1.tx_packets: 1767960
dev.igb.1.queue1.rxd_head: 2101
dev.igb.1.queue1.rxd_tail: 2100
dev.igb.1.queue1.rx_packets: 2101
dev.igb.1.queue1.rx_bytes: 173324
dev.igb.1.queue1.lro_queued: 0
dev.igb.1.queue1.lro_flushed: 0
dev.igb.1.queue2.interrupt_rate: 62500
dev.igb.1.queue2.txd_head: 3331
dev.igb.1.queue2.txd_tail: 3331
dev.igb.1.queue2.no_desc_avail: 0
dev.igb.1.queue2.tx_packets: 2088195
dev.igb.1.queue2.rxd_head: 826
dev.igb.1.queue2.rxd_tail: 825
dev.igb.1.queue2.rx_packets: 826
dev.igb.1.queue2.rx_bytes: 87226
dev.igb.1.queue2.lro_queued: 0
dev.igb.1.queue2.lro_flushed: 0
dev.igb.1.queue3.interrupt_rate: 111111
dev.igb.1.queue3.txd_head: 1262
dev.igb.1.queue3.txd_tail: 1262
dev.igb.1.queue3.no_desc_avail: 0
dev.igb.1.queue3.tx_packets: 2372828
dev.igb.1.queue3.rxd_head: 900
dev.igb.1.queue3.rxd_tail: 899
dev.igb.1.queue3.rx_packets: 900
dev.igb.1.queue3.rx_bytes: 91905
dev.igb.1.queue3.lro_queued: 0
dev.igb.1.queue3.lro_flushed: 0
dev.igb.1.mac_stats.excess_coll: 0
dev.igb.1.mac_stats.single_coll: 0
dev.igb.1.mac_stats.multiple_coll: 0
dev.igb.1.mac_stats.late_coll: 0
dev.igb.1.mac_stats.collision_count: 0
dev.igb.1.mac_stats.symbol_errors: 0
dev.igb.1.mac_stats.sequence_errors: 0
dev.igb.1.mac_stats.defer_count: 0
dev.igb.1.mac_stats.missed_packets: 0
dev.igb.1.mac_stats.recv_no_buff: 0
dev.igb.1.mac_stats.recv_undersize: 0
dev.igb.1.mac_stats.recv_fragmented: 0
dev.igb.1.mac_stats.recv_oversize: 0
dev.igb.1.mac_stats.recv_jabber: 0
dev.igb.1.mac_stats.recv_errs: 0
dev.igb.1.mac_stats.crc_errs: 0
dev.igb.1.mac_stats.alignment_errs: 0
dev.igb.1.mac_stats.coll_ext_errs: 0
dev.igb.1.mac_stats.xon_recvd: 1494
dev.igb.1.mac_stats.xon_txd: 0
dev.igb.1.mac_stats.xoff_recvd: 1494
dev.igb.1.mac_stats.xoff_txd: 0
dev.igb.1.mac_stats.total_pkts_recvd: 44476
dev.igb.1.mac_stats.good_pkts_recvd: 41477
dev.igb.1.mac_stats.bcast_pkts_recvd: 0
dev.igb.1.mac_stats.mcast_pkts_recvd: 0
dev.igb.1.mac_stats.rx_frames_64: 697
dev.igb.1.mac_stats.rx_frames_65_127: 6678
dev.igb.1.mac_stats.rx_frames_128_255: 21560
dev.igb.1.mac_stats.rx_frames_256_511: 4053
dev.igb.1.mac_stats.rx_frames_512_1023: 2417
dev.igb.1.mac_stats.rx_frames_1024_1522: 6072
dev.igb.1.mac_stats.good_octets_recvd: 16456112
dev.igb.1.mac_stats.good_octets_txd: 4806700701
dev.igb.1.mac_stats.total_pkts_txd: 8547009
dev.igb.1.mac_stats.good_pkts_txd: 8547009
dev.igb.1.mac_stats.bcast_pkts_txd: 32
dev.igb.1.mac_stats.mcast_pkts_txd: 0
dev.igb.1.mac_stats.tx_frames_64: 1713901
dev.igb.1.mac_stats.tx_frames_65_127: 3233987
dev.igb.1.mac_stats.tx_frames_128_255: 356576
dev.igb.1.mac_stats.tx_frames_256_511: 148912
dev.igb.1.mac_stats.tx_frames_512_1023: 195555
dev.igb.1.mac_stats.tx_frames_1024_1522: 2898078
dev.igb.1.mac_stats.tso_txd: 36
dev.igb.1.mac_stats.tso_ctx_fail: 0
dev.igb.1.interrupts.asserts: 7175982
dev.igb.1.interrupts.rx_pkt_timer: 44463
dev.igb.1.interrupts.rx_abs_timer: 0
dev.igb.1.interrupts.tx_pkt_timer: 0
dev.igb.1.interrupts.tx_abs_timer: 44465
dev.igb.1.interrupts.tx_queue_empty: 8546831
dev.igb.1.interrupts.tx_queue_min_thresh: 0
dev.igb.1.interrupts.rx_desc_min_thresh: 0
dev.igb.1.interrupts.rx_overrun: 0
dev.igb.1.host.breaker_tx_pkt: 0
dev.igb.1.host.host_tx_pkt_discard: 0
dev.igb.1.host.rx_pkt: 2
dev.igb.1.host.breaker_rx_pkts: 0
dev.igb.1.host.breaker_rx_pkt_drop: 0
dev.igb.1.host.tx_good_pkt: 178
dev.igb.1.host.breaker_tx_pkt_drop: 0
dev.igb.1.host.rx_good_bytes: 16647344
dev.igb.1.host.tx_good_bytes: 4806700701
dev.igb.1.host.length_errors: 0
dev.igb.1.host.serdes_violation_pkt: 0
dev.igb.1.host.header_redir_missed: 0
dev.igb.2.%desc: Intel(R) PRO/1000 Network Connection version - 2.2.3
dev.igb.2.%driver: igb
dev.igb.2.%location: slot=0 function=0
dev.igb.2.%pnpinfo: vendor=0x8086 device=0x1526 subvendor=0x8086 subdevice=0xa06c class=0x020000
dev.igb.2.%parent: pci5
dev.igb.2.nvm: -1
dev.igb.2.enable_aim: 1
dev.igb.2.flow_control: 3
dev.igb.2.rx_processing_limit: 100
dev.igb.2.link_irq: 2
dev.igb.2.dropped: 0
dev.igb.2.tx_dma_fail: 0
dev.igb.2.rx_overruns: 0
dev.igb.2.watchdog_timeouts: 0
dev.igb.2.device_control: 1488978497
dev.igb.2.rx_control: 67141634
dev.igb.2.interrupt_mask: 4
dev.igb.2.extended_int_mask: 2147483668
dev.igb.2.tx_buf_alloc: 0
dev.igb.2.rx_buf_alloc: 0
dev.igb.2.fc_high_water: 58976
dev.igb.2.fc_low_water: 58960
dev.igb.2.queue0.interrupt_rate: 15873
dev.igb.2.queue0.txd_head: 2912
dev.igb.2.queue0.txd_tail: 2912
dev.igb.2.queue0.no_desc_avail: 0
dev.igb.2.queue0.tx_packets: 325381004
dev.igb.2.queue0.rxd_head: 681
dev.igb.2.queue0.rxd_tail: 641
dev.igb.2.queue0.rx_packets: 406815362
dev.igb.2.queue0.rx_bytes: 351281822188
dev.igb.2.queue0.lro_queued: 0
dev.igb.2.queue0.lro_flushed: 0
dev.igb.2.queue1.interrupt_rate: 16666
dev.igb.2.queue1.txd_head: 1885
dev.igb.2.queue1.txd_tail: 1885
dev.igb.2.queue1.no_desc_avail: 0
dev.igb.2.queue1.tx_packets: 331249906
dev.igb.2.queue1.rxd_head: 3673
dev.igb.2.queue1.rxd_tail: 3205
dev.igb.2.queue1.rx_packets: 408329350
dev.igb.2.queue1.rx_bytes: 350190635641
dev.igb.2.queue1.lro_queued: 0
dev.igb.2.queue1.lro_flushed: 0
dev.igb.2.queue2.interrupt_rate: 16666
dev.igb.2.queue2.txd_head: 948
dev.igb.2.queue2.txd_tail: 948
dev.igb.2.queue2.no_desc_avail: 0
dev.igb.2.queue2.tx_packets: 332904404
dev.igb.2.queue2.rxd_head: 447
dev.igb.2.queue2.rxd_tail: 434
dev.igb.2.queue2.rx_packets: 404586931
dev.igb.2.queue2.rx_bytes: 348782605591
dev.igb.2.queue2.lro_queued: 0
dev.igb.2.queue2.lro_flushed: 0
dev.igb.2.queue3.interrupt_rate: 5586
dev.igb.2.queue3.txd_head: 3621
dev.igb.2.queue3.txd_tail: 3621
dev.igb.2.queue3.no_desc_avail: 0
dev.igb.2.queue3.tx_packets: 324329288
dev.igb.2.queue3.rxd_head: 3693
dev.igb.2.queue3.rxd_tail: 3691
dev.igb.2.queue3.rx_packets: 394374764
dev.igb.2.queue3.rx_bytes: 341014496777
dev.igb.2.queue3.lro_queued: 0
dev.igb.2.queue3.lro_flushed: 0
dev.igb.2.mac_stats.excess_coll: 0
dev.igb.2.mac_stats.single_coll: 0
dev.igb.2.mac_stats.multiple_coll: 0
dev.igb.2.mac_stats.late_coll: 0
dev.igb.2.mac_stats.collision_count: 0
dev.igb.2.mac_stats.symbol_errors: 0
dev.igb.2.mac_stats.sequence_errors: 0
dev.igb.2.mac_stats.defer_count: 36308
dev.igb.2.mac_stats.missed_packets: 847461
dev.igb.2.mac_stats.recv_no_buff: 638
dev.igb.2.mac_stats.recv_undersize: 0
dev.igb.2.mac_stats.recv_fragmented: 0
dev.igb.2.mac_stats.recv_oversize: 0
dev.igb.2.mac_stats.recv_jabber: 0
dev.igb.2.mac_stats.recv_errs: 0
dev.igb.2.mac_stats.crc_errs: 0
dev.igb.2.mac_stats.alignment_errs: 0
dev.igb.2.mac_stats.coll_ext_errs: 0
dev.igb.2.mac_stats.xon_recvd: 721595
dev.igb.2.mac_stats.xon_txd: 0
dev.igb.2.mac_stats.xoff_recvd: 721595
dev.igb.2.mac_stats.xoff_txd: 0
dev.igb.2.mac_stats.total_pkts_recvd: 1614951280
dev.igb.2.mac_stats.good_pkts_recvd: 1612660908
dev.igb.2.mac_stats.bcast_pkts_recvd: 0
dev.igb.2.mac_stats.mcast_pkts_recvd: 0
dev.igb.2.mac_stats.rx_frames_64: 156352064
dev.igb.2.mac_stats.rx_frames_65_127: 336505244
dev.igb.2.mac_stats.rx_frames_128_255: 109487666
dev.igb.2.mac_stats.rx_frames_256_511: 53627880
dev.igb.2.mac_stats.rx_frames_512_1023: 43979689
dev.igb.2.mac_stats.rx_frames_1024_1522: 912708364
dev.igb.2.mac_stats.good_octets_recvd: 1397631556649
dev.igb.2.mac_stats.good_octets_txd: 485266669884
dev.igb.2.mac_stats.total_pkts_txd: 1313862140
dev.igb.2.mac_stats.good_pkts_txd: 1313862140
dev.igb.2.mac_stats.bcast_pkts_txd: 37
dev.igb.2.mac_stats.mcast_pkts_txd: 0
dev.igb.2.mac_stats.tx_frames_64: 461570481
dev.igb.2.mac_stats.tx_frames_65_127: 434944211
dev.igb.2.mac_stats.tx_frames_128_255: 82754807
dev.igb.2.mac_stats.tx_frames_256_511: 42641675
dev.igb.2.mac_stats.tx_frames_512_1023: 28598240
dev.igb.2.mac_stats.tx_frames_1024_1522: 263352726
dev.igb.2.mac_stats.tso_txd: 0
dev.igb.2.mac_stats.tso_ctx_fail: 0
dev.igb.2.interrupts.asserts: 904473678
dev.igb.2.interrupts.rx_pkt_timer: 1614056936
dev.igb.2.interrupts.rx_abs_timer: 0
dev.igb.2.interrupts.tx_pkt_timer: 0
dev.igb.2.interrupts.tx_abs_timer: 1614102712
dev.igb.2.interrupts.tx_queue_empty: 1313835117
dev.igb.2.interrupts.tx_queue_min_thresh: 0
dev.igb.2.interrupts.rx_desc_min_thresh: 0
dev.igb.2.interrupts.rx_overrun: 0
dev.igb.2.host.breaker_tx_pkt: 0
dev.igb.2.host.host_tx_pkt_discard: 0
dev.igb.2.host.rx_pkt: 46872
dev.igb.2.host.breaker_rx_pkts: 0
dev.igb.2.host.breaker_rx_pkt_drop: 0
dev.igb.2.host.tx_good_pkt: 27028
dev.igb.2.host.breaker_tx_pkt_drop: 0
dev.igb.2.host.rx_good_bytes: 1397724022043
dev.igb.2.host.tx_good_bytes: 485266670479
dev.igb.2.host.length_errors: 0
dev.igb.2.host.serdes_violation_pkt: 0
dev.igb.2.host.header_redir_missed: 0
dev.igb.3.%desc: Intel(R) PRO/1000 Network Connection version - 2.2.3
dev.igb.3.%driver: igb
dev.igb.3.%location: slot=0 function=1
dev.igb.3.%pnpinfo: vendor=0x8086 device=0x1526 subvendor=0x8086 subdevice=0xa06c class=0x020000
dev.igb.3.%parent: pci5
dev.igb.3.nvm: -1
dev.igb.3.enable_aim: 1
dev.igb.3.flow_control: 3
dev.igb.3.rx_processing_limit: 100
dev.igb.3.link_irq: 2
dev.igb.3.dropped: 0
dev.igb.3.tx_dma_fail: 0
dev.igb.3.rx_overruns: 0
dev.igb.3.watchdog_timeouts: 0
dev.igb.3.device_control: 1488978497
dev.igb.3.rx_control: 67141634
dev.igb.3.interrupt_mask: 4
dev.igb.3.extended_int_mask: 2147483664
dev.igb.3.tx_buf_alloc: 0
dev.igb.3.rx_buf_alloc: 0
dev.igb.3.fc_high_water: 58976
dev.igb.3.fc_low_water: 58960
dev.igb.3.queue0.interrupt_rate: 12987
dev.igb.3.queue0.txd_head: 918
dev.igb.3.queue0.txd_tail: 987
dev.igb.3.queue0.no_desc_avail: 34818
dev.igb.3.queue0.tx_packets: 405607554
dev.igb.3.queue0.rxd_head: 3568
dev.igb.3.queue0.rxd_tail: 3567
dev.igb.3.queue0.rx_packets: 385945072
dev.igb.3.queue0.rx_bytes: 124695654987
dev.igb.3.queue0.lro_queued: 0
dev.igb.3.queue0.lro_flushed: 0
dev.igb.3.queue1.interrupt_rate: 16129
dev.igb.3.queue1.txd_head: 1088
dev.igb.3.queue1.txd_tail: 1088
dev.igb.3.queue1.no_desc_avail: 9805
dev.igb.3.queue1.tx_packets: 408372264
dev.igb.3.queue1.rxd_head: 3729
dev.igb.3.queue1.rxd_tail: 3727
dev.igb.3.queue1.rx_packets: 333123216
dev.igb.3.queue1.rx_bytes: 120984517063
dev.igb.3.queue1.lro_queued: 0
dev.igb.3.queue1.lro_flushed: 0
dev.igb.3.queue2.interrupt_rate: 100000
dev.igb.3.queue2.txd_head: 2611
dev.igb.3.queue2.txd_tail: 2957
dev.igb.3.queue2.no_desc_avail: 8
dev.igb.3.queue2.tx_packets: 404602839
dev.igb.3.queue2.rxd_head: 467
dev.igb.3.queue2.rxd_tail: 437
dev.igb.3.queue2.rx_packets: 335159734
dev.igb.3.queue2.rx_bytes: 120823353481
dev.igb.3.queue2.lro_queued: 0
dev.igb.3.queue2.lro_flushed: 0
dev.igb.3.queue3.interrupt_rate: 13888
dev.igb.3.queue3.txd_head: 2886
dev.igb.3.queue3.txd_tail: 2904
dev.igb.3.queue3.no_desc_avail: 115236
dev.igb.3.queue3.tx_packets: 394399983
dev.igb.3.queue3.rxd_head: 3709
dev.igb.3.queue3.rxd_tail: 3708
dev.igb.3.queue3.rx_packets: 326794877
dev.igb.3.queue3.rx_bytes: 121904845448
dev.igb.3.queue3.lro_queued: 0
dev.igb.3.queue3.lro_flushed: 0
dev.igb.3.mac_stats.excess_coll: 0
dev.igb.3.mac_stats.single_coll: 0
dev.igb.3.mac_stats.multiple_coll: 0
dev.igb.3.mac_stats.late_coll: 0
dev.igb.3.mac_stats.collision_count: 0
dev.igb.3.mac_stats.symbol_errors: 0
dev.igb.3.mac_stats.sequence_errors: 0
dev.igb.3.mac_stats.defer_count: 613906
dev.igb.3.mac_stats.missed_packets: 968271
dev.igb.3.mac_stats.recv_no_buff: 530
dev.igb.3.mac_stats.recv_undersize: 0
dev.igb.3.mac_stats.recv_fragmented: 0
dev.igb.3.mac_stats.recv_oversize: 0
dev.igb.3.mac_stats.recv_jabber: 0
dev.igb.3.mac_stats.recv_errs: 0
dev.igb.3.mac_stats.crc_errs: 0
dev.igb.3.mac_stats.alignment_errs: 0
dev.igb.3.mac_stats.coll_ext_errs: 0
dev.igb.3.mac_stats.xon_recvd: 29126148
dev.igb.3.mac_stats.xon_txd: 0
dev.igb.3.mac_stats.xoff_recvd: 29126149
dev.igb.3.mac_stats.xoff_txd: 0
dev.igb.3.mac_stats.total_pkts_recvd: 1381949319
dev.igb.3.mac_stats.good_pkts_recvd: 1322800309
dev.igb.3.mac_stats.bcast_pkts_recvd: 1525
dev.igb.3.mac_stats.mcast_pkts_recvd: 3
dev.igb.3.mac_stats.rx_frames_64: 463344840
dev.igb.3.mac_stats.rx_frames_65_127: 438360169
dev.igb.3.mac_stats.rx_frames_128_255: 83193750
dev.igb.3.mac_stats.rx_frames_256_511: 42791980
dev.igb.3.mac_stats.rx_frames_512_1023: 28792805
dev.igb.3.mac_stats.rx_frames_1024_1522: 266316765
dev.igb.3.mac_stats.good_octets_recvd: 490196767861
dev.igb.3.mac_stats.good_octets_txd: 1397815165902
dev.igb.3.mac_stats.total_pkts_txd: 1612957876
dev.igb.3.mac_stats.good_pkts_txd: 1612957874
dev.igb.3.mac_stats.bcast_pkts_txd: 8403
dev.igb.3.mac_stats.mcast_pkts_txd: 0
dev.igb.3.mac_stats.tx_frames_64: 156366735
dev.igb.3.mac_stats.tx_frames_65_127: 336678657
dev.igb.3.mac_stats.tx_frames_128_255: 109483742
dev.igb.3.mac_stats.tx_frames_256_511: 53622749
dev.igb.3.mac_stats.tx_frames_512_1023: 43978452
dev.igb.3.mac_stats.tx_frames_1024_1522: 912827542
dev.igb.3.mac_stats.tso_txd: 22138
dev.igb.3.mac_stats.tso_ctx_fail: 0
dev.igb.3.interrupts.asserts: 853342016
dev.igb.3.interrupts.rx_pkt_timer: 1380921641
dev.igb.3.interrupts.rx_abs_timer: 0
dev.igb.3.interrupts.tx_pkt_timer: 0
dev.igb.3.interrupts.tx_abs_timer: 1380950983
dev.igb.3.interrupts.tx_queue_empty: 1612913748
dev.igb.3.interrupts.tx_queue_min_thresh: 0
dev.igb.3.interrupts.rx_desc_min_thresh: 0
dev.igb.3.interrupts.rx_overrun: 0
dev.igb.3.host.breaker_tx_pkt: 0
dev.igb.3.host.host_tx_pkt_discard: 0
dev.igb.3.host.rx_pkt: 51830
dev.igb.3.host.breaker_rx_pkts: 0
dev.igb.3.host.breaker_rx_pkt_drop: 0
dev.igb.3.host.tx_good_pkt: 44140
dev.igb.3.host.breaker_tx_pkt_drop: 0
dev.igb.3.host.rx_good_bytes: 493919888886
dev.igb.3.host.tx_good_bytes: 1397815173100
dev.igb.3.host.length_errors: 0
dev.igb.3.host.serdes_violation_pkt: 0
dev.igb.3.host.header_redir_missed: 0
проблема в кривых драйверах igb
сетевая карта как не работала так и не работает
меняй freebsd на 7.4 сетевуху на em
и драйвера от yandex
и будет тебе счастье
странно. У меня работает. и 8.2 и 9.0.... ЧЯДН ?
нетграфов нет ? фаервол какой ?
всякая фигня что показывает:
hw.igb.rxd
hw.igb.txd
kern.ipc.nmbclusters
net.isr.*
net.inet.ip.fastforwarding
net.route.netisr_maxqlen
ну и вообще, что тюнилось ?
файрволл стоит ipfw. у него одно правило - allow any to any. Нетграфа нет. Система скорее всего вообще не тюнилась, но утверждать не могу потому как ставил и настраивал систему не я, мне лишь разгребать проблемы.
c0# sysctl hw.igb.rxd
sysctl: unknown oid 'hw.igb.rxd'
c0# sysctl hw.igb.txd
sysctl: unknown oid 'hw.igb.txd'
c0# sysctl kern.ipc.nmbclusters
kern.ipc.nmbclusters: 204800
c0# sysctl net.isr
net.isr.numthreads: 1
net.isr.maxprot: 16
net.isr.defaultqlimit: 256
net.isr.maxqlimit: 10240
net.isr.bindthreads: 0
net.isr.maxthreads: 1
net.isr.direct: 1
net.isr.direct_force: 1
c0# sysctl net.inet.ip.fastforwarding
net.inet.ip.fastforwarding: 0
c0# sysctl net.route.netisr_maxqlen
net.route.netisr_maxqlen: 256
P.S. Включил сейчас net.inet.ip.fastforwarding, посмотрим как себя система поведет
P.P.S. Есть 6509 с sup720-3b. Может туда утащить BGP? У меня 2 аплинка, но один по сути не используется. остается один, порезать FV до /24? Циска сейчас занимается машрутизацией локального трафика, гигабита 2 всего. Создать vrf, вынести туда маршрутизатор с bgp?
Edited by breusovok
Да уж, ну и юмор.
Выкиньте тогда вообще фаерволы, будет ещё меньше нагрузки на проц.
Нужно чтобы ядро было собрано без ipfw и pf, руками/через rc.d скрипты фары не запускать.
Нет, это временно, потом файер будет. а hw.igb.max_interrupt_rate=128000 и hw.igb.rx_process_limit=4096 можно просто через sysctl изменить? а то боевую железяку не хочу ребутить пока. А какие проблемы будут с fastforwarding=1, если на машине нет и не будет ната, и почти нет файрволла?
Edited by breusovok
hw.* к сожалению в рантайме не изменяются.
проблем не будет никаких, netisr thread вообще станет незаметен :)
Пока что стоит
net.isr.direct: 1
net.inet.ip.fastforwarding: 1
Два часа, полет нормальный. 73 Kpps, 300 Mbit, LA на уровне 0,2 - 0,3, CPU занято на уровне 10%. больше всего dummynet кушает. Жду 18:00 чтобы посмотреть наргрузку в час пик, при возникновении проблем повырубаю все из списка.
Чтобы разгрузить потоки прерываний можно:
net.isr.direct_force: 0
net.isr.direct: 0
сделать.
сделал. ноль эмоций. сейчас LA 5.5, cpu загрузка 55% на каждое ядро. Количество пакетов/объем трафика увеличился максимум на 5-10 процентов. такое ощущение, что где-то стоит таймер, который включает что-то...
119 processes: 13 running, 75 sleeping, 31 waiting
CPU 0:  0.0% user,  0.0% nice, 57.1% system,  6.0% interrupt, 36.8% idle
CPU 1:  0.0% user,  0.0% nice, 59.4% system,  4.5% interrupt, 36.1% idle
CPU 2:  0.0% user,  0.0% nice, 61.7% system,  7.9% interrupt, 30.5% idle
CPU 3:  0.0% user,  0.0% nice, 51.5% system,  6.4% interrupt, 42.1% idle
Mem: 415M Active, 13M Inact, 302M Wired, 72K Cache, 17M Buf, 1225M Free
 PID USERNAME PRI NICE   SIZE    RES STATE   C   TIME   WCPU COMMAND
   0 root     -68    0     0K   384K CPU2    0  11:14 58.50% {igb3 que}
   0 root     -68    0     0K   384K CPU1    3  11:16 57.86% {igb3 que}
   0 root     -68    0     0K   384K CPU3    2  11:15 56.64% {igb3 que}
   0 root     -68    0     0K   384K -       2  11:38 55.08% {igb3 que}
  11 root     171 ki31     0K    64K RUN     3 726:19 42.92% {idle: cpu3}
  11 root     171 ki31     0K    64K RUN     2 721:33 41.16% {idle: cpu2}
  11 root     171 ki31     0K    64K RUN     1 719:49 40.38% {idle: cpu1}
  11 root     171 ki31     0K    64K RUN     0 718:02 37.99% {idle: cpu0}
  12 root     -44    -     0K   576K WAIT    0   1:04 14.79% {swi1: netisr 0}
  12 root     -32    -     0K   576K WAIT    0   3:26  0.59% {swi4: clock}
  12 root     -68    -     0K   576K RUN     2  15:04  0.49% {irq268: igb2:que
  12 root     -68    -     0K   576K RUN     1  14:55  0.44% {irq267: igb2:que
  12 root     -68    -     0K   576K RUN     3  14:12  0.39% {irq269: igb2:que
   0 root     -68    0     0K   384K -       0   1:57  0.34% {dummynet}
  12 root     -68    -     0K   576K WAIT    0  14:30  0.29% {irq266: igb2:que
  12 root     -68    -     0K   576K WAIT    0  14:21  0.10% {irq271: igb3:que
   0 root     -68    0     0K   384K -       0   1:56  0.10% {igb2 que}
   0 root     -68    0     0K   384K -       0   1:47  0.10% {igb2 que}
   0 root     -68    0     0K   384K -       0   1:48  0.05% {igb2 que}
   0 root     -68    0     0K   384K -       0   1:45  0.05% {igb2 que}
Edited by breusovok
Такая же беда, каждый вечер без изменений трафика и pps, штормит пару часов, а потом "что-то" пропадает также резко, как и появилось.
А давно началось? у меня середина августа, но не так явно, не было деградации сервиса. Все же подумываю о переходе на циску.
Кстати столкнулся с такими же перегрузками по вечерам.
hw.igb.max_interrupt_rate=128000 помогло, думаю, что при хорошей шине можно и повыше поднять.
выключать fastforwarding и isr.direct есть смысл только при условии, если у netisr тредов > 1,
в противном случае очередь сядет на одно из ядер, чем серьезно ограничится производительность.
Причина перегрузок до сих пор не совсем понятна,
заметил, что есть корелляция с количеством PPS (1,5х увеличение), и исходящим от клиентов траффиком (практически до всей доступной полосы).
Есть мнение, что виновато P2P онлайн-ТВ (parom.tv, sopcast), час пик приходится на спортивные события (футбол, бокс).
Западная Украина, если что.
