a-zazell Posted September 20, 2012 Posted September 20, 2012 Здравствуйте, имеется $ uname -a FreeBSD SERVER 8.2-RELEASE FreeBSD 8.2-RELEASE #0: Sat Oct 8 16:37:12 MSD 2011 root@nat.bisv.ru:/usr/obj/usr/src/sys/20111006 amd64 # dmesg | grep aacu0 aacu0: <Adaptec RAID Controller> mem 0xfac00000-0xfadfffff irq 30 at device 0.0 on pci4 aacu0: Enable Raw I/O aacu0: Enable 64-bit array aacu0: New comm. interface enabled aacu0: [iTHREAD] aacu0: Adaptec 2405, aac driver 2.4.1-18284 aacp0: <SCSI Passthrough Bus> on aacu0 aacp1: <SCSI Passthrough Bus> on aacu0 aacp2: <SCSI Passthrough Bus> on aacu0 aacd0: <RAID 1 (Mirror)> on aacu0 aacd1: <Volume> on aacu0 Второй день как, при архивации Sep 20 06:00:00 server sudo: backup : TTY=unknown ; PWD=/backup ; USER=root ; COMMAND=/usr/bin/tar -czLf 20120920060000.server.tgz -T backup.conf Sep 20 06:01:01 server kernel: aacu0: COMMAND 0xffffff80011d3958 TIMEOUT AFTER 48 SECONDS Sep 20 06:01:01 server kernel: aacu0: COMMAND 0xffffff80011cb618 TIMEOUT AFTER 33 SECONDS Sep 20 06:01:01 server kernel: aacu0: COMMAND 0xffffff80011d8110 TIMEOUT AFTER 33 SECONDS Sep 20 06:01:01 server kernel: aacu0: COMMAND 0xffffff80011cb258 TIMEOUT AFTER 31 SECONDS Sep 20 06:01:21 server kernel: aacu0: COMMAND 0xffffff80011d3958 TIMEOUT AFTER 68 SECONDS Sep 20 06:01:21 server kernel: aacu0: COMMAND 0xffffff80011cb618 TIMEOUT AFTER 53 SECONDS Sep 20 06:01:21 server kernel: aacu0: COMMAND 0xffffff80011d8110 TIMEOUT AFTER 53 SECONDS ... ... Sep 20 06:02:35 server kernel: aacd1: hard error cmd=read 91489791-91489814 Sep 20 06:02:35 server kernel: g_vfs_done():aacd1s1d[READ(offset=46842740736, length=12288)]error = 5 Sep 20 06:02:35 server kernel: aacd1: hard error cmd=read 91489823-91489846 Sep 20 06:02:35 server kernel: g_vfs_done():aacd1s1d[READ(offset=46842757120, length=12288)]error = 5 Sep 20 06:02:35 server kernel: aacd1: hard error cmd=read 91489855-91489878 Sep 20 06:02:35 server kernel: g_vfs_done():aacd1s1d[READ(offset=46842773504, length=12288)]error = 5 Sep 20 06:02:35 server kernel: aacd1: hard error cmd=read 91489887-91489910 ... И на данный момент сыпется Sep 20 09:32:02 server kernel: aacu0: COMMAND 0xffffff80011d8638 TIMEOUT AFTER 56 SECONDS Sep 20 09:32:02 server kernel: aacu0: COMMAND 0xffffff80011d3688 TIMEOUT AFTER 56 SECONDS Sep 20 09:32:02 server kernel: aacu0: COMMAND 0xffffff80011cb1e0 TIMEOUT AFTER 56 SECONDS Sep 20 09:32:02 server kernel: aacu0: COMMAND 0xffffff80011d9178 TIMEOUT AFTER 56 SECONDS Проблема с зеркалом или дополнительным диском для бэкапов, не пойму? # mount /dev/aacd0s1a on / (ufs, local) devfs on /dev (devfs, local, multilabel) /dev/aacd0s1e on /tmp (ufs, local, soft-updates) /dev/aacd0s1f on /usr (ufs, local, soft-updates) /dev/aacd0s1d on /var (ufs, local, soft-updates) /dev/aacd1s1d on /backup (ufs, local, soft-updates) Кто сталкивался? Нужна помошь, спасибо! Вставить ник Quote
a-zazell Posted September 20, 2012 Author Posted September 20, 2012 Снова завалился, снял диск backup, пока не ругается больше. Есть в логах Sep 20 10:12:21 fsck: /dev/aacd0s1f: 249176 files, 1693748 used, 225292359 free (44839 frags, 28155940 blocks, 0.0% fragmentation) Sep 20 10:12:21 fsck: /dev/aacd0s1f: 249176 files, 1693748 used, 225292359 free (44839 frags, 28155940 blocks, 0.0% fragmentation) Sep 20 10:12:41 fsck: /dev/aacd0s1d: 1066 files, 6949 used, 6072842 free (578 frags, 759033 blocks, 0.0% fragmentation) Sep 20 10:12:41 fsck: /dev/aacd0s1d: 1066 files, 6949 used, 6072842 free (578 frags, 759033 blocks, 0.0% fragmentation) Видимо после жесткого ребута чекает. Вставить ник Quote
