Добрый день, форумчане!
После запуска IPTV в продакшен.
резко нагрузились Циски 3750G.
Особенно процесс: Mwheel Process
Что это за гадость и как её приготовить.
CPU utilization for five seconds: 85%/7%; one minute: 54%; five minutes: 50%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
321 62212611 24877967 2500 24.44% 6.87% 7.60% 0 Mwheel Process
205 253756359 952878061 266 18.05% 16.88% 17.13% 0 IP Input
325 21770765 17569211 1239 10.70% 5.50% 2.60% 0 SNMP ENGINE
323 9817335 34751589 282 5.27% 2.57% 1.17% 0 IP SNMP
320 12745197 10037502 1269 3.99% 1.50% 1.82% 0 PIM Process
9 77407369 176984927 437 3.51% 2.99% 3.31% 0 ARP Input
324 3711066 17519109 211 1.43% 0.72% 0.37% 0 PDU DISPATCHER
219 15344969 36109618 424 1.11% 0.88% 0.90% 0 Spanning Tree
319 8867434 6434903 1378 1.11% 0.75% 0.69% 0 IGMP Input
112 5764026 4493296 1282 0.63% 0.32% 0.40% 0 hl3mm
145 2768041 59210653 46 0.63% 0.31% 0.28% 0 Hulc LED Process
sh ver?
C3750G#sh ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE, R
ELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2010 by Cisco Systems, Inc.
Compiled Sat 07-Aug-10 22:45 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE
(fc1)
C3750G uptime is 4 weeks, 4 days, 3 hours, 47 minutes
System returned to ROM by power-on
System image file is "flash:/c3750-ipservicesk9-mz.122-55.SE/c3750-ipservicesk9-
mz.122-55.SE.bin"
This product contains cryptographic features and is subject to United
to comply with U.S. and local laws, return this product immediately.
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C3750G-24TS (PowerPC405) processor (revision F0) with 131072K bytes of
memory.
Processor board ID CAT0834Y15M
Last reset from power-on
81 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:XXXXXXXXXX
Motherboard assembly number : 73-7058-10
Power supply part number : 341-0045-01
Motherboard serial number : CAT0834053P
Power supply serial number : PHI081802W8
Model revision number : F0
Motherboard revision number : A0
Model number : WS-C3750G-24TS-S
System serial number : CAT0834Y15M
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 28 WS-C3750G-24TS 12.2(55)SE C3750-IPSERVICESK9-M
Configuration register is 0xF
