Господа, возникла проблема с подятием VPN на Cisco ASA 5505. Точнее, добавления к уже существующему каналу ещё одного канала к другому офису.
Конфиг такой:
nat (inside,outside) source static inside-net inside-net destination static GO-nets GO-nets description NoNAT
access-list 100 extended permit ip 192.168.235.0 255.255.255.240 172.16.0.0 255.255.0.0
access-list 100 extended permit ip 192.168.235.0 255.255.255.240 192.168.2.0 255.255.255.0
access-list 100 extended permit ip 192.168.235.0 255.255.255.240 192.168.3.0 255.255.255.0
access-list 100 extended permit ip 192.168.235.0 255.255.255.240 172.17.0.0 255.255.0.0
access-list 100 extended permit ip 192.168.235.0 255.255.255.240 192.168.32.0 255.255.254.0
access-list 100 extended permit ip 192.168.235.0 255.255.255.240 192.168.1.0 255.255.255.0
access-list 101 extended permit ip 192.168.212.0 255.255.255.240 192.168.38.0 255.255.254.0 (добавляю access-list)
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption des
hash sha
group 2
lifetime 86400
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto ipsec security-association lifetexitime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 20 match address 100
crypto map outside_map 20 set peer з.з.з.з х.х.х.х
crypto map outside_map 20 set transform-set myset
--- добавляю crypto-map
crypto map outside_map 30 match address 101
crypto map outside_map 30 set peer щ.щ.щ.щ
crypto map outside_map 30 set transform-set myset
crypto map outside_map 30 set nat-t-disable
crypto map outside_map interface outside
tunnel-group х.х.х.х type ipsec-l2l
tunnel-group х.х.х.х ipsec-attributes
pre-shared-key ****
tunnel-group з.з.з.з type ipsec-l2l
tunnel-group з.з.з.з ipsec-attributes
pre-shared-key ***
Добавляю этот tunnel-group
tunnel-group щ.щ.щ.щ type ipsec-l2l
tunnel-group щ.щ.щ.щ ipsec-attributes
pre-shared-key ****
!!!!Enable for DMZ-host
crypto map outside_map 20 set nat-t-disable
end
В итоге никакие пакеты IKE не приходят на щ.щ.щ.щ
Что я сделал не так??
sh crypto isakmp sa
Active SA: 1
Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1 IKE Peer: x.x.x.x
Type : L2L Role : initiator
Rekey : no State : MM_ACTIVE
т.е. только до одного офиса, а того, который я добавляю и в помине нет.
Edited by fomik2
