Появилась новая трабла, теперь микротик не хочет отдавать данные для мониторинга MRTG по snmp.
Причем параметры считываются cfgmaker'ом нормально, а вот данные уже не отображаются:
[sergej@MIK] > snmp prin
enabled: yes
contact: Sergej
engine-id:
trap-target: 0.0.0.0
trap-community: public
trap-version: 2
trap-generators:
[sergej@MIK] > snmp community print
Flags: * - default
# NAME ADDRESSES
0 * public 192.168.0.1/32
а вот вывод запуска mrtg:
2012-09-07 08:41:46: WARNING: Can not determine ifNumber for public@192.168.0.12: ref: 'Name' key: 'ether1-gateway'
2012-09-07 08:41:46: WARNING: Can not determine ifNumber for public@192.168.0.12: ref: 'Name' key: 'ether2-master-local'
2012-09-07 08:41:46: WARNING: Can not determine ifNumber for public@192.168.0.12: ref: 'Name' key: 'wlan1'
2012-09-07 08:41:46: ERROR: Target[192.168.0.12_ether1-gateway][_IN_] ' $target->[0]{$mode} ' did not eval into defined data
2012-09-07 08:41:46: ERROR: Target[192.168.0.12_ether1-gateway][_OUT_] ' $target->[0]{$mode} ' did not eval into defined data
2012-09-07 08:41:46: ERROR: Target[192.168.0.12_ether2-master-local][_IN_] ' $target->[1]{$mode} ' did not eval into defined data
2012-09-07 08:41:46: ERROR: Target[192.168.0.12_ether2-master-local][_OUT_] ' $target->[1]{$mode} ' did not eval into defined data
2012-09-07 08:41:46: ERROR: Target[192.168.0.12_wlan1][_IN_] ' $target->[2]{$mode} ' did not eval into defined data
2012-09-07 08:41:46: ERROR: Target[192.168.0.12_wlan1][_OUT_] ' $target->[2]{$mode} ' did not eval into defined data
До этого стояло и работало все
